Old 04-25-2014, 10:25 AM   #4551
fenton
Originally Posted by Jac View Post
Summary, I'm very happy with the torque between 3-5K its what the car really needed. Would love to keep it going past 6K but here's hoping the 1.5 dump pack helps. Horsepower isn't all that impressive but who cares when you have all that torque on tap that low in the range. AFRs are still a bit scary but I'm thinking with more fuel i should be making more power.
Let me know if you have any questions. I'm planning to hit the dyno again once i get my 1.5 dump pack and will likely ask Shiv for an e-tune to clean-up my AFRs.
Results look right in line with the TQ250 with standard dump pack.
This is exactly why the 1.5 dump addition exists. It helps that fall off on the top. You should hit over 210 just by adding the 1.5 conversion. As shiv said the other day, the AFR spike down low could very well be contamination.
Thanks for posting all the results and your thoughts
fenton is offline   Reply With Quote
Old 04-25-2014, 10:25 AM   #4552
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by robwbright View Post
Maybe I misunderstood this, too.
In the pics fenton posted, there appear to be 4 batteries on the tray. Is there a different tray to fit the 5th battery?
The 2 smaller 9 AH batteries are placed on their side with the bottom of each towards each other. By doing this the batteries are almost the same size as 1 of the regular dump pack batteries.
Edit finding or making a picture really quickly.
Installed Mods:
Old 04-25-2014, 10:27 AM   #4553
fenton
Originally Posted by Stormalong View Post
In the pictures posted yesterday of the 1.5 dump pack I only saw 4 batteries. Where is the 5th?
Hey guys. The picture that i posted with the phantom conversion adapter has two batteries butted up against each other.
All 5 batteries fit in the new battery tray.
Attachment 76060
Old 04-25-2014, 10:29 AM   #4554
Sojhinn
Sojhinn's Avatar
Attachment 76060
Yeah using this picture you can see that the two smaller batteries are on their sides. These two batteries are taped together. And the plastic piece on top puts them in series.
Installed Mods:
Old 04-25-2014, 10:30 AM   #4555
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Attachment 76060
Underneath the Phantom sticker?
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-25-2014, 10:30 AM   #4556
fenton
Originally Posted by Urmyson View Post
To the guys running the 1.5 pack. Is it a noticeable difference like "oh wow" or "I think I feel it"?
It is a noticeable difference. It just keeps pulling. Both Bu-tang and Rob noticed a difference in my car.
Shiv noticed a difference as well when he did his dual dump conversion.
Old 04-25-2014, 10:31 AM   #4557
robwbright
BTW, thanks to everyone for being so helpful and not flaming obvious ignorance.
This is the first time I've ever done any significant engine mods to a car, so...
2006 Saab 9-3 2.0t
Old 04-25-2014, 10:32 AM   #4558
Sojhinn
Sojhinn's Avatar
No worries it's what we do. Hopefully between Fenton and myself it was cleared up.
Installed Mods:
Old 04-25-2014, 10:32 AM   #4559
Sojhinn
Sojhinn's Avatar
Btw- I highly recommend the 1.5 pack.
Installed Mods:
Old 04-25-2014, 10:34 AM   #4560
raven1231
i
As promised, here's my detailed dyno report. All on 93 octane, 4th gear pulls + catted front pipe and catback exhaust.
First things first, ESC vs. stock + stock map (both with front pipe/CBE/intake filter)
LOVE the 50% torque gain in the dip
Hate the drop off towards 7K rpm, really rewards you for keeping it between 3-5K
u
The Phantom ESC was hitting about 4.5psi peak boost, then dropping to 0.5-1psi higher in the rpm range.
Next up i tested SPM (Super Pursuit Mode turns off throttle switch) vs. stock to see if I'd actually gain/lose anything with drag reduction only. I did.
ESC Super Pursuit Mode (red) vs. stock + stock map (both with front pipe/CBE/intake filter)
Was surprised to see peak numbers were pretty much the exact same with SPM actually producing less low end torque until 4K.
Next i wanted to see how the ESC would perform with an aftermarket intake filter
ESC vs. ESC w/K&N Filter (both with front pipe/CBE)
Nice gains! almost 10hp and 10tq higher in the rpm range.
Although my AFRs started to get a bit scary with the filter. Although this was with the dynojet exhaust sniffer, not OFT data logging.
What is stock map ? Shiv's or the factory map?
Old 04-25-2014, 10:37 AM   #4561
fenton
Yes see attached
Sent from my HTC One using Tapatalk
Old 04-25-2014, 10:37 AM   #4562
robwbright
I considered just going single dump pack and getting an OFH sooner... but I think I'll go 1.5.
Any thoughts on whether the gains are better/worse with 1.5 and no OFH vs. 1.0 and OFH?
2006 Saab 9-3 2.0t
Old 04-25-2014, 10:39 AM   #4563
robwbright
Yes see attached
Attachment 76178
Got it. Yea - I looked at the pic several times and only saw 4 batteries... LOL.
I see now that the thing with the sticker on it is actually connected to the side (actually the top) of the smaller batteries.
2006 Saab 9-3 2.0t
Old 04-25-2014, 10:40 AM   #4564
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Loaded question. I would recommend both. I guess the person that would be best to answer this @nlowell when he gets the 1.5 pack or he and I can do a side by side drag race again. Since he has the ofh and I have the 1.5 pack currently.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
