Old 04-24-2014, 12:58 AM   #1
Gofrs
Drives: White out
Powered subwoofer under driverseat
I was wondering of any has tried this? I have the small sound ordnance sub coming in tomorrow and I really want try putting it under the seat. I obviously would pump the seat as high as it will go. Has anyone successfully put a compact powered sub under the seat of their car?
http://www.crutchfield.com/S-5Qgu1Ae...nce-B-8PT.html
Gofrs is offline   Reply With Quote
Old 04-24-2014, 09:45 AM   #2
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
You do realize how close to the floor the seats are, right? I have this all-in-one sub http://www.sonicelectronix.com/item_...NVX-QBUS8.html, which is even smaller than the one you linked to, and I still don't think it would fit under the seat.
Also, just a head up, an 8" sub is pretty useless in the trunk (just throwing this out there since you probably can't fit anything under the seat). I wish I'd have gone with a 10". I upgraded the door speakers/dynamatted the doors, and they sound so much better than stock that a sub really isn't needed (for my tastes, at least), but even with stock speakers, the door speakers drowned out the 8" sub in the trunk.
Prog is offline   Reply With Quote
Old 04-24-2014, 10:15 AM   #3
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
10" Rockford Fosgate powered sub in the trunk is decent sounding.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-24-2014, 10:26 AM   #4
wparsons
wparsons's Avatar
No chance you're getting that under the seat. The floor isn't flat at all, and the seat rails will be in the way (even with the seat all the way up).
Depending on how tall you are you could put it behind the seat though.
flickr
Old 04-24-2014, 11:03 AM   #5
Gofrs
Drives: White out
Damn it I knew it would be a stretch. I'm about 5'6 do you think it would work begins the seat? If it was in the trunk you guys don't think it will sound too good?
Old 04-24-2014, 11:17 AM   #6
wootwoot
Drives: FRS
No way it can happen. I considered it when doing my audio. It wouldn't even work with a 6" shallow mount sub.
Quality will be much better in the trunk. No sense in going through all the trouble just to make your butt vibrate.
Old 04-24-2014, 11:24 AM   #7
Prog
Prog's Avatar
Go with a 10"+ sub and put it in the trunk. You won't hear that 8" one over your door speakers if it's back there.
Old 04-24-2014, 03:00 PM   #8
frslee
Just drive it
Drives: 13' FR-S
I have 8" enlosed/pre-powered subwoofer in the trunk. It provides plenty of bass with nice settings.
frslee is offline   Reply With Quote
Old 04-24-2014, 03:09 PM   #9
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
No chance it'll work, and you won't even have the air volume for it to move sound effectively.
Also, that compact sub is discontinued...
A 10" sub in the trunk will do quite nicely, and with fiberglass corner enclosure won't take up much of your trunk room either.
I've got a JL 10W3v3 and it's excellent (being powered at 300 Wrms @ 2ohms).
^GT5 Replay Photo Mode^
Old 04-24-2014, 06:53 PM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've got an alpine pdx v9 under the passenger seat.. at 2-1/2" tall, it is still pushing it a little, and i already cut out the foam below the carpet.. a 3-1/2" tall sub definitely won't fit..
Old 04-24-2014, 11:04 PM   #11
Gofrs
Drives: White out
well i just got the sub in. It fits under the seat no problem. i just need to get it installed to see if it sounds good under there.
i also just got in these
http://www.crutchfield.com/p_107DB65...651.html?tp=95
what do you guys think is the best way to power them? crutch field told me i could just plug and play. how should i set the settings for them?
Old 04-24-2014, 11:18 PM   #12
gramicci101
Off Topic
You replaced the door speakers? The door speakers run at 2 ohms. Your speakers are 4 ohms, and are getting about half the power that the original speakers were getting. You could replace the sub amp with this one, run it bridged at 90x2 @ 4 ohms, and really bring those 6.5s to life. You could run another of those amps at 45x4 for your dash and rear speakers, as well.
Old 04-24-2014, 11:20 PM   #13
soundman98
soundman98's Avatar
also the door speakers are fed a sub signal only, so the coaxials you bought are 1/2 useless in that location.
Old 04-24-2014, 11:24 PM   #14
gramicci101
Off Topic
It's a pain trying to locate a 6.5" woofer that isn't a part of a component set or a two or three way coax. I asked kicker if they could sell me just the woofer from their component set, and they said no.
audio, bass, speakers, sub box, subwoofer
IS-F Powered FRS xn7485 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 01-08-2014 07:45 PM
FS: Sound Ordnance B-8P Powered Subwoofer sdshores08 Audio/Visual, Electronics, Infotainment, NAV 3 09-09-2013 06:58 PM
Review of my JL Audio PWM110-JXWXv2 powered subwoofer ysr50guy Electronics | Audio | NAV | Infotainment 27 04-01-2013 01:46 AM
V8 powered BRZ! Hawk77FT AUSTRALIA 4 12-28-2012 03:48 AM
