Drives: None
Error code P0171 P0170 and P171b came up
So I recently installed my avo turbo and it was all working good up till 3 weeks later when error codes p0171 and p0170 popped up. I than refreshed the the ecu and the light was gone for a good 7hrs and the the p0171 came on, and this morning the P0171, P0170, and P171b came up. Its basically saying my car is running lean and rich. When I installed the turbo I noticed the gasket that connects the over pipe to the rest of the exhaust had a slight gap in it. I highly believe this could be the issue. I cleaned the MAF sensor, checked all the vacumme lines, checked for any signs of leaks. I've been keeping an eye on the afr using the raw data display through torque and it's been acting kind of funny, like it wants to stay at 4:7:1 but every now and then goes a little lower.
Sent from my LG-D800 using Tapatalk |
#2 |
NASA SpecE30 Racer
That leak (Over Pipe to Exhaust) is post O2 sensor, so I am sure that isn't causing the problems. It should only be at 14.7:1 at idle and while cruising or at light throttle. Are you running an AVO basemap? Have you done any logs with EcuTek?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#3 | |
Drives: 4-Runner Sport - 13' BRZ SportTech
What tune do you have flashed on your car?
Top Tier Imports - Check out my build journal HERE
#4 |
Drives: None
#5 | |
Drives: None
#6 |
A code P0171 may mean that one or more of the following has happened:
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#7 | |
Drives: 2014 FRS
Hows the idle? afr 14.7 and boost at -18 is what mine says. I also have the avo base map and if anything it runs rich when getting into boost. Always goes right to 11.2 which is the lowest I think the ecu can register so probably really going lower than that. It's worth it to pull a ecutek log and you don't even need to do WOT pulls to redline to get something useful to look at. |
#8 | |
Drives: None
#9 | |
NASA SpecE30 Racer
@Sportsguy83
- King Tut
#10 | ||
I Love custom Turbo kits
Drives: Limited BRZ
(/sarcasm)
#11 | |
Drives: None
I like to live on the edge, but I also don't want to blow my engine... Anyways I just ordered some new gaskets from avo. Would it be bad to run this car for a month like this? It's my dd. as soon as I get them I'm going to install them Sent from my iPad using Tapatalk |
#12 |
NASA SpecE30 Racer
No problem. Tighten up the nuts as best you can and run it. I don't remember if they are locking nuts or not, but perhaps you could add a lock washer.
- King Tut
#13 |
That depends on what caused the gasket leak.
I mean no disrespect at all, but did you forget to tighten down a header bolt initially? If so, then your header is probably fine and once everything is re-tightened down properly it should be okay until the new gaskets arrive. If you did install it 100% correctly and it blew out a gasket that early while throwing codes, I would take a look at the header itself before anything else.
#14 | |
i had a loose bolt on my header after 5,000 miles like realy loose! hope your car is better!
| TechStream Error Code B14A1 | developer | Issues | Warranty | Recalls / TSB | 13 | 10-08-2018 07:22 AM |
| ECUtek error 37 | NickFRS | Software Tuning | 5 | 06-29-2014 04:14 PM |
| Unichip Error Code | Ingeberger | Engine, Exhaust, Transmission | 5 | 12-29-2013 01:09 PM |
| Paperwork error | Rob_g | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-24-2012 11:38 PM |
| Driver error | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 07-14-2010 07:25 PM |
