Old 04-14-2014, 10:24 PM   #309
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Kostamojen View Post
Its still an issue. More of an issue for daily drivers in varrying environmental tempuratures. The coolant coming from the block location we are using is right after the radiator pipe just past the thermostat, so i doubt the temp difference is much if any. I'm more concerned about the water pump actually pumping coolant to the cooler at all times and not getting a stagnant feed when the thermostat is closed.
What's the issue with a stagnant feed? I have had the Cusco cooler on my car for several weeks and have no issues with warmup times.
In fact, I have noticed zero difference in terms of warmup between the Cusco cooler installed, and a completely stock engine.
Stagnant feed is not a problem if it doesn't hinder or otherwise interfere/change the time it takes to warm up the oil.
-alex
Old 04-14-2014, 11:00 PM   #310
troek
troek's Avatar
Drives: 2012 Toyota 86
my cusco cooler kept my oil at 250 or less on the track, and most of the time it was a good bit under that, pretty happy with it. unless this core is a different size, should be very similar performance. the only reason i went with cusco is there was one on sale for like 400 dollars here, so it just made sense.
troek is offline   Reply With Quote
Old 04-20-2014, 10:53 PM   #311
Kostamojen
Took 6 months, but finally have proof the oil cooler does something:
[ame]http://youtu.be/VnGKGTCsca8[/ame]
Ran the same road 6 month ago without the oil cooler and again today. Both times temps were in the low 70's. I've done a bit to the car since then, but nothing in terms of power. With the tires I have now, I could actually push the car A LOT harder and I even ran it with the A/C on just to make sure I was running the car as hard as possible.
Might be hard to see the video, but the Oil temps are now running 15-20 degrees cooler. At some points the car was running 260 degrees or higher before, now they never exceed 245ed degrees. Thats a HUGE improvement IMO!
The Following User Says Thank You to Kostamojen For This Useful Post:
CARNZ (04-20-2014)
Old 04-21-2014, 01:12 AM   #312
Kostamojen
In case that video quality is too poor, here are the original two videos at full length:
Without oil cooler -
[ame="https://www.youtube.com/watch?v=xLDftVSI_BA"]Kost In-car Vid 2 - YouTube[/ame]
With oil cooler -
[ame="https://www.youtube.com/watch?v=WmtLNUlX8Ew"]Best Road Ever - YouTube[/ame]
Old 04-21-2014, 12:24 PM   #313
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
^^ these are taken with OEM radiator, correct?
I've taken my logs with stock radiator at track events this weekend (OEM oil cooler received but not installed yet) and seen the temps rose up to 266 degrees!! Hopefully, the oem oil cooler help reducing those temps down
glamcem is offline   Reply With Quote
Old 04-21-2014, 12:54 PM   #314
Kostamojen
Stock radiator yes. Only other engine mods are the TRD intake and TRD catback and were used in both vids.
Old 04-23-2014, 10:37 AM   #315
Dezoris
Dezoris's Avatar
Just a side note if you are running these solutions and have tuning, lower the fan activation point from 212F down to 200F. It will drop your oil temps aroun 10 extra degrees. If you don't, running the AC will activate those fans and will keep coolant temps/oil temps lower.
The Following 5 Users Say Thank You to Dezoris For This Useful Post:
86ft.lb (08-01-2014), CxG (04-25-2016), M1K3 (04-23-2014), smbstyle (04-23-2014), whataboutbob (07-13-2014)
Old 04-24-2014, 04:01 AM   #316
Guillaume
Guillaume's Avatar
Drives: Exige S 240
That works wonders when stuck in traffic, indeed.
Guillaume is offline   Reply With Quote
Old 04-26-2014, 01:36 AM   #317
Dezoris
Dezoris's Avatar
Originally Posted by normancw View Post
That's great. How is this done? Through Ecutek?
Yes through pro version or any tuner can set it to that by request.
The Following User Says Thank You to Dezoris For This Useful Post:
CxG (04-25-2016)
Old 04-30-2014, 11:51 AM   #318
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
way for me to forget the center bolt. paying shipping twice sucks
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 04-30-2014, 10:01 PM   #319
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Finished up my install tonight that I started Sunday. Was a bit more of a PIA than I had hoped for. Just one of those days (Sunday) where nothing went smoothly.
Main problem was I ended up with a piece of 1/2 hydraulic hose instead of heater hose. (co-worker gave me a piece) No wonder it wouldn't fit over the new vertical pipe.
Anyway everything went smoothly tonight. Wanted to point out a coupe things.
First the new 1/2 hose coming out of the head sits very close to the header. I decided to put some heat sleeve over it to make sure it doesn't get too hot. I ended up using the rest on the 3/8 line as a barrier for the shield next to the cooler and the frame rail.
Secondly, I didn't like how the heater hose on the rear fit up to the new pipe (as has been stated). I decided to try and bend it up to gain some clearance. I found a socket that fit inside the new pipe, then I clamped that in the vice. I then used my body weight to push against the new pipe. I was able to bend (straighten) it a fair amount before the pipe started doing funny things. This then allowed the hose to fit just right without kinking (as shown)
Anyway thanks everyone for this thread. (Im going to MID-O) in a month so we'll see how this thing works.
cruizin01 is offline   Reply With Quote
The Following 2 Users Say Thank You to cruizin01 For This Useful Post:
CxG (04-25-2016), jcw99 (01-17-2015)
Old 05-01-2014, 09:51 AM   #320
Grip Ronin
The Mechanic
Grip Ronin's Avatar
so i ordered from Heuberger Subaru's Online Parts. i dont trust sites that dont accept paypal but its the only decent priced way to get them. funny to see my credit card info was stolen a week after the purchase and caught in Oklahoma before any expensive purchases were made. this is a card that is only used on paypal no place else...
IG-Joey_Soul
Old 05-01-2014, 11:26 AM   #321
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I just ordered from Subaru online parts because I wanted the BRZ trunk liner for my FRS as well. I think their prices are comparable (no tax to CA, but $20 ground ship). Another forum member confirmed fitment with the Kraftwerks supercharger kit so I'm going to try to do the same. Going to use the "T" splitter variant of the install instructions. Hopefully I can install by just removing the idler pulley instead of the entire KW S/C plate.
mit_peid is offline   Reply With Quote
Old 05-01-2014, 11:08 PM   #322
iDerek
iDerek's Avatar
Drives: Subaru BRZ
Send a message via MSN to iDerek
anyone using this OEM kit with SC or Turbo? if so, how is the temps holding up?
An idea should be like a skirt, long enough to cover the details and short enough to keep everyone's attention.
iDerek is offline   Reply With Quote
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
