Old 04-22-2014, 01:03 PM   #1
qqzj
Drives: MDX, Camry
How would you shift from 4 to 5?
Method 1: up -> right -> up.
Method 2: push the shifter toward up-right direction in one single stroke.
What is the theoretically correct approach? Or, under what kind of situations, one approach is better than the other? Thanks.
qqzj is offline   Reply With Quote
Old 04-22-2014, 01:09 PM   #2
irucremmi
Drives:
You thinking too much, just do it.
irucremmi is offline   Reply With Quote
The Following 17 Users Say Thank You to irucremmi For This Useful Post:
Advan-Emotion (04-30-2014), BRZ21 (04-22-2014), extrashaky (04-22-2014), Ganthrithor (04-23-2014), IloveBaldEagles (04-26-2014), kdmBRZ (04-23-2014), MagicBobert (04-25-2014), Marchy (04-22-2014), mjh712 (04-23-2014), robwbright (04-22-2014), SkAsphalt (04-22-2014), soundman98 (04-23-2014), speedy07 (04-23-2014), Squishy86 (04-22-2014), tinma (04-26-2014), wrb (04-22-2014), _______ (04-23-2014)
Old 04-22-2014, 01:09 PM   #3
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
stroke it neatly.
BRZtoni is offline   Reply With Quote
The Following User Says Thank You to BRZtoni For This Useful Post:
Old 04-22-2014, 01:09 PM   #4
TM
TM's Avatar
Drives: DGM BRZ 6MT
The same way I shift from 2 to 3.
TM is offline   Reply With Quote
Old 04-22-2014, 01:10 PM   #5
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
There's a 5th gear?!
The Following 2 Users Say Thank You to tahdizzle For This Useful Post:
Churnobyl (04-22-2014), SkAsphalt (04-22-2014)
Old 04-22-2014, 01:16 PM   #6
sklimo
The Following 2 Users Say Thank You to sklimo For This Useful Post:
CenCali86 (04-22-2014), meWant (04-26-2014)
Old 04-22-2014, 01:28 PM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
The Following 3 Users Say Thank You to Turbo95eg6 For This Useful Post:
dbrandt01 (04-22-2014), mfbmike (04-22-2014), SirBrass (04-22-2014)
Old 04-22-2014, 01:28 PM   #8
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I just do method 2. I don't think about it, I just do it.
^GT5 Replay Photo Mode^
Old 04-22-2014, 01:36 PM   #9
tracerit
Drives: '13 SSM BRZ Limited 6MT
2-3 and 4-5 are completely different for me as well. I feel like I have to go high rpm and throw it in faster and harder than usual whereas 2-3 just kind of goes in. i kind of feel there's not enough time to go up right up with 4-5, the gearing seems "close"
tracerit is offline   Reply With Quote
Old 04-22-2014, 01:41 PM   #10
SirBrass
SirBrass's Avatar
Just push straight up with a slightly rightward slant. It's harder to describe than to do. You just DO it (that's what she said). Don't overthink it.
Then again, I've got mtec spring in. That makes it ridiculously easy to change gears in the lateral direction (2-3, 3-2, 4-5, 5-4, etc). I just think it, move the arm and hand, and bam it goes into the correct gate. Don't overthink it or overdo it, let the springs to their work and you just guide them.
This isn't like rev-matching, folks. It's not even like going from a dead stop. There's not really an art to it. You just shift.
The Following User Says Thank You to SirBrass For This Useful Post:
go2brz (04-22-2014)
Old 04-22-2014, 01:52 PM   #11
qqzj
Drives: MDX, Camry
2->3 is easy b/c the shifter has a natural tendency to go to the neutral position. So I simply push the shifter up w/ a very slight pause in between and the shift can be completed flawlessly. However, I need to fight this tendency when shift from 4->5. I know my question seems trivial to some, but to me, if there are two approaches, one has to be better than the other.
Your observation about the limited amount of time is legit. The RPM differs by about 30% 2->3, but only 20% 4->5. As the engine is losing the speed when you let off the gas and clutch in, 2->3 gives you more time than 4->5.
Old 04-22-2014, 06:36 PM   #12
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I do method 1. Then again, I'm a bit odd. I also rev match up shifts - which usually just requires probably timing of releasing the gas pedal and speed of shifting, but when the engine is cold the revs drop quickly between shifts and I end up doing a slight blip on the upshift. Again, I'm a bit odd. I'll shift 1-2 in two "clicks" - ie slight pause in between gears. I don't like just ripping it out of first and jamming it in second in one move. Even when I'm shifting fast I'll acknowledge the pause between gears.
ashtray is offline   Reply With Quote
Old 04-22-2014, 06:41 PM   #13
dbrandt01
Drives: none
I just do it, I mean I push up and I guess it goes to fifth. I don't even pay attention or even look at the shift knob. I just shift.
dbrandt01 is offline   Reply With Quote
Old 04-22-2014, 06:46 PM   #14
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Now that I think of it I think I do Method 1
Alltezza is offline   Reply With Quote
Shift resistance amaciose Engine, Exhaust, Transmission 2 12-06-2013 08:53 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
Shift Knob Zoomryder Issues | Warranty | Recalls / TSB 5 04-09-2013 08:39 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
Shift Knob yomchi1989 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2012 09:19 PM
