Old 04-22-2014, 01:29 PM   #141
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Reflex View Post
Will try that later. Thanks for the suggestion!
If that does not work, would a group loop isolator help? Or what other things could I do?
Two options:
http://www.radioshack.com/product/in...ductId=2062214
But you are going to need one rca to male headphone adapter for this. Plus you can get it right now, and return it easily if it does not work.
Reviews are great for this and it does not look like it affects sound quality.
Next up is this bad boy:
[ame="http://www.amazon.com/PAC-Ground-Isolator-3-5-Applications/dp/B001EAQTRI/ref=cm_cr_pr_product_top"]Amazon.com: PAC Ground Loop Isolator for 3.5 MM Applications: Automotive[/ame]
Cheap. Good reviews, but a few people complained it reduced sound quality. Not sure if this is true.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Reflex (04-22-2014)
Old 04-22-2014, 01:42 PM   #142
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Sojhinn View Post
Two options:
I have that PAC piece. I didn't notice any reduced sound quality.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
Reflex (04-22-2014), Sojhinn (04-22-2014)
Old 04-22-2014, 01:44 PM   #143
Sojhinn
Sojhinn's Avatar
Cool thanks for the heads up.
Installed Mods:
Old 04-22-2014, 02:38 PM   #144
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Genomaxter View Post
How good are the head unit control apps with other brands beside Sony? I planned to use an Aurdino to replicate the IR remote sequence for turning on the App Control automatically when the Nexus turns on. I dont want to push any buttons for the head unit itself to use it. Basically, I want the Nexus to control all the radio functions of the head unit.
Not good. You have to press a button on the head unit to activate pairing EVERY time you want to use the app to control the head unit. Not exactly convenient for a Nexus install with a hidden head unit. This is true with both Sony's and JVC's offerings. If there's something else out there that doesn't have this limitation, it's news to me.
Prog is offline   Reply With Quote
Old 04-22-2014, 02:40 PM   #145
Sojhinn
Sojhinn's Avatar
Actually the remote can do it. Hence the reason for the adruino. It's just series of key hits to make the nexus connect to the headunit.
Installed Mods:
Old 04-22-2014, 03:42 PM   #146
Prog
Prog's Avatar
Is this a recent improvement? When I did my tablet install back in November/December, every source I found said you had to press the button on the head unit itself for the Sony units.
Old 04-22-2014, 04:46 PM   #147
Sojhinn
Sojhinn's Avatar
Im sure on your search you found this link about a guy who installed the nexus 7 in his tacoma. He kept trying different ways of enabling the program with the remote and couldn't figure it out. Well someone else did, and to top that off he made an adruino board to hit the same series of hits, and its now all automated.
http://www.mp3car.com/worklogs/15586...-tacoma-7.html
Installed Mods:
Old 04-22-2014, 04:54 PM   #148
Prog
Prog's Avatar
Oh, I either misread or I'm misunderstanding. I thought you guys meant you could use the Sony remote that comes with the head unit to do this.
Old 04-22-2014, 04:55 PM   #149
Sojhinn
Sojhinn's Avatar
Actually you can but it does get messy if you don't hit the right series of buttons. (It requires a down and right I believe) so you would need to be good at doing it right every time.
Installed Mods:
Old 04-22-2014, 05:02 PM   #150
Prog
Prog's Avatar
Pretty cool that people are figuring out ways around these limitations.
Although, it's incredibly stupid of Sony to require a physical button press for something like this in the first place.
Old 04-22-2014, 05:10 PM   #151
Sojhinn
Sojhinn's Avatar
I agree on both counts.
Installed Mods:
Old 04-22-2014, 06:25 PM   #152
ratters
Drives:
I've got a JVC KD-X250BT head unit hidden behind my Nexus 7. I don't need to press any button to activate the pairing, I can just connect through my tablet.
Although the JVC app isn't very good, it does everything I need (change source, volume, eq)
Sent from my C6903 using Tapatalk
ratters is offline   Reply With Quote
Old 04-22-2014, 06:25 PM   #153
Sojhinn
Sojhinn's Avatar
Which app did you download? I can't get one to work.
Installed Mods:
Old 04-23-2014, 05:08 AM   #154
ratters
Drives:
JVC Smart Music Control
To connect to your head unit, you need to go into 'Media', then bring up the menu, click 'Connect' then select your head unit (JVC Unit).
A toast message should come up saying 'Connected to car receiver' or something. Then you can use the gestures to control your head unit.
TBH its a pretty shitty app, but at least I can control my head unit through it
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Nexus 7 in FR-S/BRZ DjDATZ Electronics | Audio | NAV | Infotainment 4 06-09-2013 08:10 PM
Nexus 7 Car Audio DIY thejevans Electronics | Audio | NAV | Infotainment 32 05-10-2013 03:55 PM
How easy/difficult is it to keep WRB "clean"? ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 32 06-17-2012 10:17 PM
