Old 04-21-2014, 02:12 PM   #43
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Originally Posted by Reaper View Post
Lightweight flywheel makes it worse.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
This. I've never owned a vehicle with a lightweight flywheel before, but I can tell you it is VERY loud. At one point I thought something was wrong with my engine until I pushed the clutch in and the sound went away.
blackfireball5 is offline   Reply With Quote
Old 04-21-2014, 03:44 PM   #44
FRSupra
FRSupra's Avatar
Originally Posted by rmjjensen View Post
There's a known rattling of the throw out bearing in the transmission (if you have a manual). Mine rattles and a lot of others have this rattle sound ...there's a bunch of threads on it.
Do you notice it when you're idling? If you do, press the clutch - did the sound go away?? If so, you've also got some throw out bearing rattle.
Thank you for this. I was in a couple threads about this awhile back, but no one had come to a conclusion yet, I was not aware.
Do you have a link?
FRSupra is offline   Reply With Quote
Old 04-21-2014, 03:52 PM   #45
FRS-D
Drives: 10 Series FRS(0218)
Not sure if anyone has touched on this, I used to hear a bit of a rattle at times until I installed kartboy transmission bushing, rear shift bushing and mtec springs. Of the three I would assume the transmission bushing may of helped with this.
FRS-D is offline   Reply With Quote
Old 05-23-2018, 02:50 PM   #46
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
I just replaced my clutch/flywheel/TOB due to a TOB failure and now I’m experiencing the same rattling under very low RPM on throttle conditions. I suspect it’s either the clutch springs or TOB that are somehow different in design or tolerances.
Prior to this maintenance my car would lug normally without any rattling just the normal engine lugging sound you’d expect from a manual.
(2013 BRZ 72000mi, exedy OEM clutch kit & flywheel)
AlexTheGreek is offline   Reply With Quote
Old 05-23-2018, 08:16 PM   #47
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
So what I've learned from this thread, 6th gear is useless unless if you're on the highway
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 05-23-2018, 08:23 PM   #48
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You can use sixth gear around town.
Just use it for cruise purposes when you aren't putting a load on the engine.
At any point if you need to pick up speed, grab a lower gear.
Old 05-23-2018, 08:30 PM   #49
highway7
Drives: FRS 2013
Yes I have this as well, replaced original clutch with exedy OEM clutch kit and 2017+ OEM TOB. Before I would hear the lugging, now I hear the lugging in addition to a very unique rattling (To me sounds more like a constant grind / growl) for a split second. However clutch is fine and doesn't slip or anything. Just another noise to add to the list...
highway7 is offline   Reply With Quote
Old 05-23-2018, 10:17 PM   #50
Some say that about 5th also ……
VoltsFRS2013 (05-26-2018)
Old 05-29-2018, 08:23 PM   #51
re-animator
i could be wrong but i believe 6th is basically an overdrive in our cars (as in many other cars) that is there for highway efficiency only. i don't use it on surface streets and it is pointless to accelerate in 6th even on the freeway, unless you like using only a portion of the car's available power. Sidenote: people cruising at 3k rpm/70mph in 6th gear then trying to accelerate without downshifting are hitting the torque dip AND using an overdrive gear hence reviewers and people who test drive a car come back bUT tHe 86 iZ sO sLoWw!!1!
re-animator is offline   Reply With Quote
The Following User Says Thank You to re-animator For This Useful Post:
VoltsFRS2013 (05-30-2018)
Old 05-30-2018, 10:53 AM   #52
VoltsFRS2013
LMAOO.
I usually just shift around 2200-2500 so it rebounds me back somewhere near 1900 when im just putting around with it. Although, I'd usually put the car into upper gears sooner which I supposed "lugged" the engine and I didn't realize it was bad for it. Welp, lesson learned Car feels fast enough for me though. I love it.
Old 05-30-2018, 01:59 PM   #53
LMAOO.
Not to be ah tellen you how to drive your car ……. but, you may consider spinning that puppy up a few more RPMs before shifting. Even ol grandpa humfrz spins his up to about 4,000 before shifting ……
Tcoat (05-30-2018), VoltsFRS2013 (05-30-2018)
Old 05-30-2018, 02:09 PM   #54
You are wearing your engine out driving at high RPMs. I thought that was established a wile back. You need to keep them below 2000 at all times so it lasts.
humfrz (05-30-2018), VoltsFRS2013 (05-30-2018)
Old 05-30-2018, 02:48 PM   #55
Well, I must admit that makes sense. If I drive at 2,000 rpms, then I could drive twice as far than if I drive at 4,000 RPM …… because of half the wear on the engine. And then, if I would install light weight pulleys …….
Old 05-30-2018, 07:59 PM   #56
VoltsFRS2013
LOL really? whoops.
I have my shift light at 4k LMAO i was kinda under the impression that low rpm guuuud
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
