Old 06-21-2013, 07:42 PM   #1
topazsparrow
Drives: slow
Low RPM rattle when "lugging"?
It's a long story, but I bought my car with 149 km's on it so I know it's been test driven.
Everything seems fine on the car except that at low speeds & rpm the engine can sound quite rattly. Anywhere around 1000 - 2000 rpm if you load the engine it starts sound pretty bad. I've got less than 1000 km on the car and I'm hoping it's just a new engine thing until it breaks in.
Has anyone else experience this?
my old 240sx would shake a bit and otherwise complain when lugged like that, but never make such a rattle.
topazsparrow is offline   Reply With Quote
Old 06-21-2013, 07:49 PM   #2
whaap
whaap's Avatar
Lugging, hypermiling or what ever it's called is not good for you engine. I've never lugged mine so I can't answer your question. Think of it as riding a multi-speed bicycle. When you come to the hill it gets pretty damn tough to peddle unless you change gears. The same thing is happening to your engine when you lug.
whaap is offline   Reply With Quote
Old 06-21-2013, 08:15 PM   #3
5th 86
Drives: 2013 BRZ SPORT TECH
Yep hes right, i dont even like going under 3000rpm if i dont have to, never mind 2 or 1000
5th 86 is offline   Reply With Quote
Old 06-21-2013, 08:16 PM   #4
topazsparrow
Drives: slow
I'm aware of this
It does happen though. stop and go traffic, taking off slowly from a stop, etc etc.
Anyone experience anything like that?
Old 06-21-2013, 08:19 PM   #5
5th 86
Are u talking starting from a stop or slowing down in a high gear?
Old 06-21-2013, 08:23 PM   #6
Tromatic
I'd suspect a problem with the operator, not the engine.
Tromatic is offline   Reply With Quote
Old 06-21-2013, 08:25 PM   #7
5th 86
All subaru engines sound like tractors, its just a characteistic, i would try and meet up with someone in your area and listen to there 86.
Old 06-21-2013, 08:30 PM   #8
topazsparrow
Drives: slow
not noticeable from a stop as I'm usually above 2k rpm in 1st gear when taking off.
It's mostly in 2nd gear when moving really slowly (stop and go traffic) and I'm too lazy to shift into 1st. It's fine until you load the engine then it's noisy.
I'm not sure why everyone has an opinion on what I SHOULD be doing when I'm simply asking if anyone else has run across this.
Old 06-21-2013, 08:31 PM   #9
topazsparrow
Drives: slow
That's really not helpful at all.
I'm asking if anyone else can hear a rattle when loading the engine at low RPM's... I'm not asking for driving advice. I know you're not suppose to lug any motor.
Old 06-21-2013, 08:36 PM   #10
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Mine rattles at low rpm's, high rpm's, at idle, lugging, cruising, hell, sometimes I can hear it rattling even when it's not running.
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 06-21-2013, 08:39 PM   #11
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
There's a known rattling of the throw out bearing in the transmission (if you have a manual). Mine rattles and a lot of others have this rattle sound ...there's a bunch of threads on it.
Do you notice it when you're idling? If you do, press the clutch - did the sound go away?? If so, you've also got some throw out bearing rattle.
rmjjensen is offline   Reply With Quote
Old 06-21-2013, 08:46 PM   #12
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I understand what you're saying. I worried about it first too because the cars with MT I had before never made this noise. I made a thread about it too. It's normal. I heard 370Z making the same noise. I just don't go below 2200 anymore.
Sigh-on-Rice is offline   Reply With Quote
Old 06-21-2013, 09:02 PM   #13
topazsparrow
Drives: slow
nah, Idle is quiet (after the cat is warmed up) and having the clutch in or out makes no difference. It's only under load.
Old 06-21-2013, 09:46 PM   #14
OrbitalEllipses
Drives: Attitude
You other helpful posters couldn't just tell him it's flywheel or clutch chatter? Personally, I don't take the car under 2K rpm very often except for 1st gear starts and occasionally in 2nd, which is most often when you'll hear the chatter.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 04:52 AM
