Old 04-16-2014, 09:29 PM   #169
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@Figo I see that you've got the DBA dual drilled rotors for your conversion. Do you mind giving me the part numbers for both front and rear rotors please?
Fizz is offline   Reply With Quote
Old 04-17-2014, 03:57 AM   #170
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I would only go with OEM STI caliper bolts personally, but a quality Grade 8 bolt would be an okay replacement. Perhaps a search on NASIOC or some Subaru parts sites will net you the length, thread size, and thread pitch.
Can you confirm if the caliper mounting bolts require washers? I've read somewhere that it does, but when I went to my local Subaru dealer to order those bolts, he said no washers required.
Old 04-17-2014, 04:16 AM   #171
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Also, what's the correct sequence for bleeding/flushing brakes on the FRS? Do you start with the caliper which is furthest away from MC first...as per normal? (i.e. RR, RL, FR, FL)?
Reason being, the Subaru WRX guys say it should be FR, RL, FL, RR instead. Anyone heard of this before?
Old 04-17-2014, 04:26 AM   #172
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Here's a little sneak peak of what's to come....
The Following User Says Thank You to Fizz For This Useful Post:
chanomatik (04-17-2014)
Old 04-17-2014, 10:01 AM   #173
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't remember the bolts having washers with them. I prefer to always get the fluid going to the rear first during a bleed/flush, so I always do the traditional furthest away.
Fizz (04-17-2014)
Old 04-17-2014, 03:03 PM   #174
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Thanks. Could you take a couple of shots showing the back of the caliper where the banjo connects. Which bleeders and stainless lines did you get?
By the way.....just wanted to make sure that 05 calipers are the same as 04 yes? Just the rotors are different....?
On the back the brake line connection is just like oem FR-S and BRZ. I got Stoptech FR-S/BRZ steal lines front and rear. You can also get STI brake lines they are a little bit shorter. For bleeders, I swapped the front and used OEM STI one.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
Fizz (04-17-2014)
Old 04-17-2014, 04:21 PM   #175
OrbitalEllipses
Drives: Attitude
Don't remember any washers with my STI Brembos.
Be careful with lines: Impreza lines mount to the strut in the opposite orientation from ours - we come from the top of the strut to the bottom whereas the Impreza comes from the bottom to the top. This will cause issues with kinking and I have first-hand confirmation of that from when I installed my AP BBK.
Fizz (04-17-2014)
Old 04-17-2014, 04:59 PM   #176
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
The Following User Says Thank You to chanomatik For This Useful Post:
drewbot (08-20-2014)
Old 04-17-2014, 05:04 PM   #177
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
^^^^ fired
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 04-17-2014, 05:20 PM   #178
King Tut
NASA SpecE30 Racer
King Tut's Avatar
TIL: Orbital is Drake. Will you be attending any Spurs games this playoffs?
The Following 2 Users Say Thank You to King Tut For This Useful Post:
chanomatik (04-17-2014), Fizz (04-17-2014)
Old 04-17-2014, 05:20 PM   #179
OrbitalEllipses
Drives: Attitude
Go away Jimmy.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
chanomatik (04-17-2014), drewbot (08-20-2014)
Old 04-17-2014, 05:35 PM   #180
dabocx
dabocx's Avatar
Drives: Scion FRS
I need more photos of these mounted!
Im not sure if ill get these before or after I get new wheels but I think they should fit even with my 17X8 +32 Work CR Kais
dabocx is offline   Reply With Quote
Old 04-17-2014, 08:55 PM   #181
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
I have 25mm spacers all around and hoping that my stock wheels will clear.
I've got all the pieces needed, just waiting on the last part: rear rotors - which are on back order for another month from TireRack
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 04-17-2014, 08:58 PM   #182
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Teaser via potato:
The Following User Says Thank You to Draco-REX For This Useful Post:
chanomatik (04-18-2014)
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
