Old 04-16-2014, 09:59 AM   #2297
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
I want to know if it's possible to run 17x7.5 +53, they are from STI wheels V7.
Thanks!
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 04-16-2014, 10:05 AM   #2298
Mikepage
Mikepage's Avatar
Will this fit? (width, offset and tire size Qs)
Finally I found it, it's ok it will fit. http://www.ft86club.com/forums/showthread.php?p=639521
o= FR-S =o
Old 04-16-2014, 01:21 PM   #2299
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Yeah, they'll fit, just not the ideal offset but should be fine.
We'll call that fitment "ultra-tucked".
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
Mikepage (04-16-2014)
Old 04-16-2014, 01:22 PM   #2300
Mikepage
Mikepage's Avatar
Because the wheels will be 5mm inside?
At least this is only 5mm
o= FR-S =o
Old 04-16-2014, 01:42 PM   #2301
Slick
Slick's Avatar
Yep. The factory wheels are 17x7 +48.
Yours are 7.5" wide so add 6mm to each side (6+6 is 12mm =1/2") plus the 5mm difference in offset. So you end up with a wheel that is 11mm further in on inside and 1 mm further out on outside.
The inside of your wheel is pretty much exactly where the inside is on my 18x9" +35 wheel.
So it clears, but you are close to the strut on the inside whereas you have loads of space on the outside. A better offset for that size is between +30 to +40. You can also achieve the same offset by adding bolt-on 20mm spacers, which would give you an effective +33 offset.
It's no biggie, just more of a looks/fitment/preference thing. If you like them, go for it.
Old 04-16-2014, 01:46 PM   #2302
Mikepage
Mikepage's Avatar
Thanks for the info, am not sure I will take it now :S I don't really want spacers...
But stock wheels are 7.5 also.
o= FR-S =o
Old 04-16-2014, 01:55 PM   #2303
Slick
Slick's Avatar
No, stock are 17x7".
Old 04-16-2014, 01:56 PM   #2304
Mikepage
Mikepage's Avatar
Ok my bad, thank you the info, you helped me greatly!
o= FR-S =o
Old 04-17-2014, 09:06 AM   #2305
Slick
Slick's Avatar
No problem, btw where in Canada are you located?
Old 04-17-2014, 11:03 AM   #2306
Mikepage
Mikepage's Avatar
Am in Québec,Québec why?
o= FR-S =o
Old 04-17-2014, 09:29 PM   #2307
phrosty
18x8+40 wheels, with 225/40R18 in front and 235/40R18 in back.
First -- are these proper tread widths for that wheel width? (How does one tell?)
Second -- assuming stock height/suspension, how much danger of rubbing fenders?
phrosty is offline   Reply With Quote
Old 04-18-2014, 12:40 PM   #2308
projectXTR
Drives: Sterling Silver BRZ
Curious if someone could confirm the fitment of the following as I can't find it with the search function.
F 18x8.5 +30
R 18x9.5 +40
Will be lowering the car by an inch probably.
Thanks in advance for your help !
projectXTR is offline   Reply With Quote
Old 04-23-2014, 02:13 PM   #2309
rodzomar
rodzomar's Avatar
Drives: FR-S Ultramarine
I've try searching this thread without any luck. I bought a set of Enkei Tenjin 17x9 +45 offset. I've read that these wheel have a fitment issue if your running on stock suspension or spring. But I have coilovers, so I won't be having that problem. My main concern is what tire I should buy. I was thinking on getting 235/45-17 because I want to have a taller tire, as per the Wheel Directory the 245/40-17 will fit perfectly, but that would defy the purpose of getting a taller tire. So in conclusion I haven't found anyone that could assume me that the 235/45-17 will fit. Also I wouldn't mind going for a wider tire, as long that it would be taller than the OEM tire. Any help is appreciated.
rodzomar is offline   Reply With Quote
Old 04-23-2014, 02:41 PM   #2310
Slick
Slick's Avatar
Firstly, why do you want a taller tire?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
