Old 04-16-2014, 10:45 AM   #4229
choi0706
Drives: t
i havent tried it yet but they did confirm it should work..
choi0706 is offline   Reply With Quote
Old 04-16-2014, 10:45 AM   #4230
OrbitalEllipses
Drives: Attitude
Originally Posted by Hawaiian View Post
A quick option for you, rather than taking a hammer to shape things, you can get a foil tape and cover some of the areas you think it's rubbing. The tape will scuff up quickly enough to confirm where exactly it's making contact.
You can pick some up at a hardware store in the ducting section, it's used for sealing sheet metal for furnaces.
Can't believe I never thought of that. Great post @Hawaiian!
Old 04-16-2014, 12:58 PM   #4231
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Lots of info in this thread.
How many people have been able to do this install on jack stands?
Brahsbrah is offline   Reply With Quote
Old 04-16-2014, 01:06 PM   #4232
choi0706
Drives: t
possible to do on ramps.
Old 04-16-2014, 01:06 PM   #4233
emutcfut
Drives: 2013 Argento
I have. Actually quite easy on jackstands although you may want to have someone hold the header up for you from the top while you thread a couple nuts to hold it in place.
emutcfut is offline   Reply With Quote
Old 04-16-2014, 01:07 PM   #4234
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I did the install on jackstands no problem. Actually I think if I'd removed the oil dipstick from the block at the start I wouldn't have even had to jack up the motor.
Decay107 is offline   Reply With Quote
Old 04-16-2014, 01:20 PM   #4235
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by mad_sb View Post
right on, thats a good idea for sure, I was trying to think of a good wearable marking solution that would not burn off the instant the exhaust got hot.
I'm not sure how long the adhesive will last at those temps, or if it will burn/discolor the exhaust slightly, but it should be fine on the mount.
Well, I was thinking of a soloution for @mad_sb but luckily i was working on my furnace recently otherwise it would have slipped my mind as well.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 04-16-2014, 02:35 PM   #4236
Brahsbrah
It looks like I will be going this route. If only I knew someone with a lift...
Old 04-16-2014, 03:14 PM   #4237
BlueBlazeRacer
Drives: 2014 FR-S
I havent seen any dynos posted yet. Has anyone posted the 198HP dyno yet?
BlueBlazeRacer is offline   Reply With Quote
Old 04-16-2014, 03:33 PM   #4238
Hawaiian
That guy
Hawaiian's Avatar
Ultramarine mt FR-S
P&L stage 1 turbo
Old 04-16-2014, 06:11 PM   #4239
regal
Drives: Scion FR-S/Toyota Yaris
Had to be E85 or a favorable calibrated dyno right?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-16-2014, 08:47 PM   #4240
mad_sb
Drives: 2013 Asphalt FR-S
i did and did not lift the motor at all. You just need to move your plugs an such after you remove the stock unit. I just needed one good bump with my palm to pop it into place. But I have had other long tube headers off and on several times already so I'm used to pulling guard on those face suckers and wrestling them into position.
Old 04-16-2014, 09:51 PM   #4241
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Lol nice bjj reference. I did it the same way. Just smacked it through.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 04-16-2014, 10:15 PM   #4242
xjohnx
Grip>Slip
xjohnx's Avatar
Same way i did it. Nice and easy.
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
