Old 04-15-2014, 06:38 AM   #99
adwordandi
Drives: BMW A6
Surface protection film becomes a necessity of today. It's a nice way to protect your investment.
adwordandi is offline   Reply With Quote
The Following User Says Thank You to adwordandi For This Useful Post:
GhostShield (04-15-2014)
Old 04-15-2014, 12:16 PM   #100
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Originally Posted by Boxer486 View Post
Yes, nice coat of sealant to fill in the gap before the dirt does.
Wouldn't it be more ideal to put sealant on before the wax? I'd have to work backwards after instal then. Are you saying to just apply some on the bra/paint after install?
Sounds like I'm better off just doing the full hood.
Originally Posted by billwot View Post
Question about paint protection film/clear bra?:
I just bought a '13 FR-S...9K miles, asphalt. During the test drive (the salesman let me take it by myself) I parked it and inspected it very carefully. I noticed there were maybe 10 places on the hood with small irregular blemishes in the "paint"...looked like acid rain, or maybe salt damage. I pointed it out to the salesguy (you had to look pretty close to see them). He said he would have their detail shop try to correct it, and call me. I'm a fairly car-savvy guy, and I really thought they would just buff out. (I didn't know about paint film/clear bras)
DO NOT have the dealer correct any kind of blemishes on the car! I 100% guarantee they will only temporarily mask the solution, as the blemishes will reappear with most likely a hologram effect in the clear coat.
Old 04-15-2014, 12:30 PM   #101
Turbo95eg6
Turbo95eg6's Avatar
Originally Posted by imom View Post
The other pitfalls is running into a shop that does wraps or PPF clear and razor the fuck out of your car. Forget about protecting the paint...they just fucked the owner's paint. I'm not saying your shop does this...just saying there are downside...of course there are downside with a bad detailer that burns the paint while prepping for opti coat.
Damn, I was wondering about his also. Would experience help for them not to cut up the car, or is it considered just a normal process to get nicks on the car during install?
Old 04-15-2014, 01:13 PM   #102
Boxer486
Drives: small
Yes and yes.
Boxer486 is offline   Reply With Quote
Old 04-15-2014, 01:56 PM   #103
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by GhostShield View Post
Plus got an NRA circle membership small sticker on the rear window.
What do you guys think of the
I think I want to give you my business
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Old 04-15-2014, 04:41 PM   #104
SirBrass
SirBrass's Avatar
Opti-coat and cquart are both micron-thin permanent coatings, much like the clear coat part of the paint coat, once they've had time to cure properly.
That said, I'd want both the cquartz (I'm told it looks better on dark paints than optiguard) then also the clear bra. Clear bra for the added rock chip protection, and just the cquartz for the rest of the car's protection as well.
Old 04-15-2014, 06:05 PM   #105
GhostShield
Drives: 2013 silver FRS
@GhostShield
A few questions:
Interested in only getting bumper/partial of the hood/fenders. I heard people using a toothpick to remove dirt from the line, but I don't want drag a pointy wooden object across my clear coat. Are there other options?
My friend only installs 3M so I can get a discount. If I do get a partial protection, will I see a fade after taking it off after a few years? Is 3M UV resistant enough to not cause a line?
My paint is getting corrected before instal, but would also like it waxed. Would the wax affect the clear bra, or will it be removed anyway during install? Should I not wax the front end? They just wash to prep the car, correct? What kind of solution do they spray on the car to adhere the film?
I'm also getting some chips repaired before the bra. Is there anything I should know, as far as how long to wait after getting them touched up? Will the bra take out the touch up paint if I ever take it off?
The best bet as far as wax and dirt building up on the edges of the film is to use spray wax on a micro fiber rag wrapped around your finger tip and gently work the wax/build up off the edge.
Problem with 3m is you can't use alcohol on it. If it were Suntek or XPEL I'd still use the micro fiber on my finger but alcohol would take the build up off the edge twice as fast and with less rubbing.
I def would not use the tooth pick!! No no no haha as installers after an install we do use an insulin needle to suck out any small bubbles we might have missed.
As far as fading of the paint that's not covered, it's all going to come down to how well you maintain those surfaces and how much sun your car sees. I have seen fading on cars where I remove an old PPF kit and that paint looks great but the rest is faded. Those people though DID NOT maintain their car worth a crap! So it's all in your hands.
Just wash her regularly and wax often.
As far as waxing the clear bra or putting any sealers on it, I don't on my frs and don't tell customers to. I just recommend spray waxing the clear bra after every wash. Leaves it slick and shinny.
Great thing about Suntek and XPEL to is you can clay bar it if any fallout developes on the clear bra.
As far as your paint prep, I think your right on the money. Let the touch up paint cure for a day. And during the install the installer needs to be careful not to lift the film back up on an area where the touch up is. Once he squeegees that down it needs to stay down. Because yes the film will possibly lift the touch up paint out of the chips.
Again just kinda goes back to why I stress getting clear bras on new cars ASAP or before they are even driven at all. I love having my frs full wrapped
GhostShield is offline   Reply With Quote
Old 04-15-2014, 06:07 PM   #106
GhostShield
Wax will not affect the clear bra install. The installer should wash the car very well and blast out all the cracks and crevices in the bumper. Then he should prep with a degreaser or rubbing alcohol on a micro fiber.
Old 04-15-2014, 06:09 PM   #107
GhostShield
Originally Posted by Mr. Sparkle View Post
What the car feels like doesn't matter. Opti-Coat is not slick like wax. there is no way that alcohol or a degreaser is removing opti-coat. that alcohol or degreaser may leave something behind which then temporarily changes the sheeting / beading properties but the coating is there regardless
and Ive installed Xpel film over Opti-Coat with no sticking issues because its bonded to the paint permanently (unlike a coat of wax).
we will have to agree to disagree
I see what you guys are saying about opti. It's just my personal opinion that it's not worth it. I like the slick feeling waxes or a good sealer like shine supply's daddy-o will provide.
Check out www.shinesupply.com and chemical guys if you guys haven't already. Both have great products!
Shine supply is made locally here in Ventura county California
Old 04-15-2014, 06:11 PM   #108
GhostShield
Just wanna say thanks again for the love guys! I greatly appreciate it.
Sorry I was absent for a few days. Been busy at the shop, wrenching on my frs, spending time with my family and old lady and of course chillen with the guys enjoying some cold ones!
Old 04-15-2014, 06:15 PM   #109
GhostShield
Originally Posted by jeepmor View Post
@GhostShield - nice post, convinced me about the clear bra products and which to use. Thanks.
Not a fan of that camo on that car, and I love camo, just not on my rigs. Very informative thread, thanks for fielding all the haters and keep on keepin on answering the questions.
I'm just a redneck livin in the wrong state man.
She's gunna be getting more camo real soon haha :/
Gunna do a single main camo stripe on the hood and front bumper, on the front of the roof start as a single stripe then split into a dual stripe before the antenna on the roof then continue over the trunk and rear bumper as two stripes. All of it will be outlined with a matte black stripe on each side of the camo.
I think it'll be sick and differant.
Old 04-15-2014, 07:06 PM   #110
Turbo95eg6
Turbo95eg6's Avatar
This scares me a bit… After spending $500 for a color correction I'd prefer not to let someone wash incorrectly and wipe down my clear coat with a towel and rubbing alcohol. Maybe they will let me wash it for them. Thanks for the replies.
This is the reason why I'm leaning more towards opticoat since I already have chips in the car. I guess I'll have a week to decide.
Old 04-15-2014, 08:38 PM   #111
GhostShield
Nah don't be scared about a clear bra guy prepping the paint for the install. It's all done with micro fibers, just look into the reputation of the installer you in trust your car to.
Ask him questions. And yeah you can wash the car yourself, make sure you get any bug guts off, since your doing paint correction you shouldn't need to clay it. Blast out all the cracks of the bumper while washing it.
I like it when a customer brings me a decently washed car haha save me time
Even with the chips it's still worth it to PPF. Chips are just plain ugly to look at, why be susceptible to more.
Old 04-22-2014, 09:44 PM   #112
dnieves
Drives: FR-S 10 Series
When it's time to remove the film (due to wear & tear), what's the best correct way to do it without causing any damage?
dnieves is offline   Reply With Quote
clear bra, paint protection film, thousand oaks
If you could add 1 thing to your FRS/BRZ/86 what would it be? Dazza Scion FR-S / Toyota 86 GT86 General Forum 84 10-18-2013 05:18 PM
Hows this thing Naughty AFRICA 4 01-31-2013 04:10 AM
What is this thing? ducks Issues | Warranty | Recalls / TSB 7 01-10-2013 05:54 AM
First thing you are going to do when you get your BRZ? Norcalmav23 BRZ First-Gen (2012+) — General Topics 74 04-02-2012 11:05 PM
