CANADA Canada
Old 04-15-2014, 03:38 PM   #1
sixthree
Drives: 14BRZ
First Oil Change [GTA]
Hello,
Looking to get my first oil change for my BRZ. Which subaru dealership in the GTA do you recommend getting my first oil change done?? How much does an oil change usually cost?? Closes dealership to me is markham and/or scarborough subaru but i've read some pretty bad reviews from both. Anyone have experience with downtown subaru / willowdale??
Thanks
sixthree is offline   Reply With Quote
Old 04-15-2014, 03:45 PM   #2
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
It's so easy, why don't you just do it yourself?
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-15-2014, 03:50 PM   #3
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
iGarage
drewbot is offline   Reply With Quote
The Following 2 Users Say Thank You to drewbot For This Useful Post:
chenshuo (04-15-2014), daiheadjai (05-15-2014)
Old 04-15-2014, 03:51 PM   #4
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Never went to the dealer for oil change, but I'm going to assume it'd be around $100~. Assuming they used synthetic oil, then you add labor charges. Make sure you tell them you only want oil change (synthetic), and nothing else... don't want to get hit with other random inspection, changed this for you, etc. fees.
Myv is offline   Reply With Quote
The Following User Says Thank You to Myv For This Useful Post:
sixthree (04-15-2014)
Old 04-15-2014, 04:04 PM   #5
sixthree
Drives: 14BRZ
I thought the first oil change must be changed by the dealership or the warranty is voided??
Old 04-15-2014, 04:05 PM   #6
TM
TM's Avatar
Drives: DGM BRZ 6MT
If you don't mind learning and getting your hands dirty, try doing it yourself. I did my first oil change this past weekend with this car and it took me half an hour.
Switch to the Fumoto value and all future oil change will take you less than 10 minutes.
TM is offline   Reply With Quote
Old 04-15-2014, 04:05 PM   #7
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
First oil change is free of charge on any Scion FR-S at Toyota Dealership.
You can check it out if Subaru does the same thing
bhbnuckle is offline   Reply With Quote
Old 04-15-2014, 04:13 PM   #8
Myv
Myv's Avatar
I can see the case if it's a lease? Otherwise, I don't think so...
Best to contact the sales person who sold you the car to make sure or contact Subaru of Canada.
If you do your own oil changes, make sure to write down the date you changed oil and the KM done at. Just for some tracking that you did your own services at suggested/correct intervals, in case some bs that comes up with them when you go in for warranty.
Old 04-15-2014, 04:37 PM   #9
D_Thissen
D_Thissen's Avatar
Not to thread jack, but what oil do you guys recommend?
Old 04-15-2014, 04:40 PM   #10
robwbright
Not that I am aware of. Sounds like BS the dealer told you. But I'm open to correction.
If that's the case, since I already did my first oil change, then I think I'll cancel the Electric Supercharger order and go Stage 3 turbo.
2006 Saab 9-3 2.0t
Old 04-15-2014, 04:41 PM   #11
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Maybe for an Audi or BMW, but my local Toyota does it for $60
Old 04-15-2014, 04:41 PM   #12
robwbright
Honda leases allow the lessee to do their own oil changes. Can't speak for Subaru/Toyota, but I'm on a Honda lease right now.
2006 Saab 9-3 2.0t
Old 04-15-2014, 04:47 PM   #13
robwbright
I just went Mobil 1 synthetic, but some others don't like it for some reason. I've used it in cars and motorcycles for a long time without issues. That said, I'm probably going to switch to NAPA (see Valvoline) synthetic because it's on sale for $3.49/quart right now.
If I were running a stage 2 or stage 3 turbo kit, I might be using Motul or some other really expensive oil, but I don't really think the issue with oil is breakdown - at least not in 5000-6000 miles. IMO, the primary issue with oil is when it gets dirty. A good synthetic could probably go 10,000+ miles as long as you kept it clean (see running it in a closed, low dirt environment).
But that's just my $.02 worth. YMMV
2006 Saab 9-3 2.0t
Old 04-15-2014, 04:51 PM   #14
Myv
Myv's Avatar
I use Eneos 0w-20, not the Sustina though.
That's pretty good, about like $15-20 more than the synthetic oil I user per change? $15-20 for labor, sounds fair
Yeah, have a friend who also does his own on his lease, all depends on dealership though.
Oil Change Vlady Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 01-23-2014 10:51 AM
WHAT YOU WILL NEVER CHANGE ON THIS CAR? Mikepage BRZ First-Gen (2012+) — General Topics 28 06-09-2013 11:29 AM
When will you be doing your first oil change? pr086 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 12-10-2012 04:48 PM
When to change the oil Capstan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 10-11-2012 02:41 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 09:32 PM
