Old 04-15-2014, 10:45 AM   #15
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Originally Posted by SirBrass View Post
Maybe it doesn't switch because the tS clusters aren't able to since they're not sold in non-standard-unit countries like the US.
Fixed it for you
Guillaume is offline   Reply With Quote
The Following 3 Users Say Thank You to Guillaume For This Useful Post:
AznKirby (10-16-2014), chaoskaze (07-29-2014), Cole (10-05-2015)
Old 04-15-2014, 10:52 AM   #16
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Originally Posted by Guillaume View Post
Fixed it for you
LOL
It's anything but standard but that's what we call it. Sadly as an American, my mind will never be able to perceive a mile as 1.6 km. Granted, I've memorized that 120km is about 70-80 miles.
mikeTee is offline   Reply With Quote
The Following User Says Thank You to mikeTee For This Useful Post:
86-tundra (04-15-2014)
Old 04-15-2014, 11:34 AM   #17
Mooseknuckle44
Mooseknuckle44's Avatar
For some reason we still haven't converted.
The only one I can remember is 2.54 cm is an inch. I though that was gonna be so useless but it actually turned out to be pretty darn useful in lots of measurements.
Mooseknuckle44 is offline   Reply With Quote
Old 04-15-2014, 01:37 PM   #18
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Fine by me, actually. Measuring quantity of gas by liters is as assinine as measuring quantity of gas by quarts.
Now, I WOULD be alright with doing away with inches and feet and going to centimeters and meters. Everything else? F-it. Stanard units are better.
^GT5 Replay Photo Mode^
Old 04-15-2014, 01:54 PM   #19
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I feel like this is a lot of work/money just to get "sti" on top of the one gauge I never look at anyway lol.
But hey, its the only way right now. At first I though this thread was going to be an actual Sti cluster
Old 04-15-2014, 02:04 PM   #20
SirBrass
SirBrass's Avatar
That's what I thought. But I like the backlighting on this tS cluster MUCH better than the stock BRZ cluster lighting.
Old 04-15-2014, 03:01 PM   #21
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by DaJo View Post
This means you will HAVE to go back to the dealership to get it reprogrammed so the cluster matches the ACTUAL mileage in your ECU...
The mileage for your car is stored ONLY in the cluster, not the ECU.
I would not recommend doing this swap unless you have the cluster pre-programmed with your mileage. Otherwise, this mod counts as odometer fraud if the car is ever sold and the new owner is not told in writing on the title exchange paperwork.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 04-15-2014, 03:35 PM   #22
OrbitalEllipses
Drives: Attitude
Fixed it for you
All this pictures shows is just how imperialist regimes of Europe actually were.
lol
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
Hyper4mance2k (11-07-2015), kilohercas (08-03-2015), SirBrass (04-24-2014)
Old 04-15-2014, 04:12 PM   #23
sshole
Eh, you can get away with it by taking your car to a service station and having them write down your old mileage (old cluster) and your new mileage (new cluster) and stick it on your car somewhere. I did that with an old Civic of mine that I swapped clusters to a newer one. I had 0 issues with getting that Civic inspected and selling the car to Carmax.
sshole is offline   Reply With Quote
Old 04-15-2014, 05:06 PM   #24
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by ricerocket93 View Post
1. First remove the Phillip's screw.
2. Lift the gauge cluster hood at 45 degree.
3. Pull hard the cluster surround towards you. No need to unplug the ODO Trip connector.
4. Remove the 2 screws located on top of the cluster.
5. Pull the cluster and unplug the connector.
6. Install the new cluster.
7. Reinstall the cluster connector. You will need to push the cable back into that hole.
8. Follow the instructions in reverse to reinstall everything.
As you can see, the back light is light blue. Not white or orange. The gear indicator, shift light and shift indicator works perfectly.
You don't need to stop at your Subaru dealer to pair it with onboard key radio code. It is plug and play.
As for the odometer, your car mileage will be at 0, like the picture below.
I was also unable to switch from MPH to KM/H, C to F and mp/g to km/l. The top button is now useless.
Can you post a pic of package and part id?
Trap63 is offline   Reply With Quote
Old 04-15-2014, 06:33 PM   #25
ricerocket93
As for the package, it's already recycled.
ricerocket93 is offline   Reply With Quote
The Following User Says Thank You to ricerocket93 For This Useful Post:
Trap63 (04-16-2014)
Old 04-24-2014, 01:18 AM   #26
HI
HI's Avatar
Drives: 2013 FR-S Ultramarine
What year cluster do I buy to make this work?
HI is offline   Reply With Quote
Old 10-05-2015, 03:20 AM   #27
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
Bringing this one from the dead.
Are there any problems with the immobilizer, especially those with keyless entry & go?
Rookie84 is offline   Reply With Quote
Old 10-05-2015, 11:05 AM   #28
ricerocket93
I installed the cluster into a BRZ with the immobilizer and keyless access. No issue for the past 2 years.
Rookie84 (10-05-2015)
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood JPM Coachworks DIY (Do-It-Yourself) Guides 109 05-01-2015 01:19 PM
led cluster help Grip Ronin Cosmetic Modification (Interior/Exterior/Lighting) 12 02-14-2014 12:29 PM
BRZ cluster on FRS? Shipwreck Electronics | Audio | NAV | Infotainment 6 03-07-2013 11:09 AM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
