| DIY (Do-It-Yourself) Guides For all DIYs. |
STI Cluster Install
1. First remove the Phillip's screw.
2. Lift the gauge cluster hood at 45 degree. 3. Pull hard the cluster surround towards you. No need to unplug the ODO Trip connector. 4. Remove the 2 screws located on top of the cluster. 5. Pull the cluster and unplug the connector. 6. Install the new cluster. 7. Reinstall the cluster connector. You will need to push the cable back into that hole. 8. Follow the instructions in reverse to reinstall everything. The gear indicator, shift light and shift indicator works perfectly. You don't need to stop at your Subaru dealer to pair it with onboard key radio code. It is plug and play for the model with the push start. As for the odometer, you need Subaru to but it back. If the cluster is already paired with another vehicle, I don't think you can paired it back. You will have to take it apart and transfer the face and needle to your old one. I was also unable to switch from MPH to KM/H, C to F and mp/g to km/l. The top button is now useless. Last edited by ricerocket93; 02-24-2017 at 01:54 PM. Reason: review |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Nice!
So the only problem so far is that you cannot switch from KM to Miles? Was also thinking of getting this... When you say Plug and Play, does it still read your original KM?
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
Supra Senior Member
Drives: AE86 & BRZ
sexy as phoooooooooo. Thanks man. I might have to take a stab at this.
Drives: FRS
There's a gear indicator option on the FRS so I would assume it's just turned on, but that cluster looks great! Not sure if I would do it just got the STi logo though
It will not keep your original KM. You start back to zero.
FT86Club Vancouver
This means you will HAVE to go back to the dealership to get it reprogrammed so the cluster matches the ACTUAL mileage in your ECU...
Do you think they would actually do it?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
FT86Club Vancouver
Probably, but at a cost... Lol
You know how stealerships are...
Yup.
Drives: MT Subaru BRZ '13
It's okay, just drive the amount of miles that was on your old ECU. Bam, problem solved.
#10 |
Thanks for this! I've been thinking of getting one for a while, but wasn't sure if it was PnP or not.
Has anyone contacted the dealer to see if they can change the odometer to match the vehicle? I've worked for a Toyota dealer for a number of years and remember a tech telling me that cluster odometers are independent of the ECU. I could be mistaken though
#11 |
Drives: DAT Rally Blue BRZ
Might as well get a frs gauge cluster instead or hopefully find someone with the same mileage and swap
#12 |
Drives: Grey GT
which STi cluster is that?
#13 |
FT86Club Vancouver
#14 |
Trust me, I'm the Doctor
Maybe it doesn't switch because the tS clusters aren't able to since they're not sold in standard-unit countries like the US.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| Gauge install, dash cluster light cable, Tach RPM cable help... | Sportsguy83 | Electronics | Audio | NAV | Infotainment | 99 | 08-07-2016 10:36 PM |
| How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood | JPM Coachworks | DIY (Do-It-Yourself) Guides | 109 | 05-01-2015 01:19 PM |
| led cluster help | Grip Ronin | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-14-2014 12:29 PM |
| BRZ cluster on FRS? | Shipwreck | Electronics | Audio | NAV | Infotainment | 6 | 03-07-2013 11:09 AM |
| Scratches on my Cluster. | Superhatch | BRZ First-Gen (2012+) — General Topics | 5 | 08-21-2012 07:50 AM |
