Old 04-14-2014, 11:22 AM   #99
qoncept
qoncept's Avatar
I had my first event of the season yesterday. It was 45 degrees and pouring and I was lazy so I stayed on the stock all seasons. Pretty miserable day but the driving was fun.
I doubt there are going to be many people sticking with race tires. Yesterday reminded me of how nice it was to just throw a cooler and helmet in the car and go. Dragging the trailer and changing tires gets old. Once I get through these tires I think I'll be headed to CS.
qoncept is offline   Reply With Quote
The Following 2 Users Say Thank You to qoncept For This Useful Post:
DylanFRS (04-14-2014), Thrustin (04-14-2014)
Old 04-14-2014, 01:52 PM   #100
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by qoncept View Post
I Yesterday reminded me of how nice it was to just throw a cooler and helmet in the car and go. Dragging the trailer and changing tires gets old. Once I get through these tires I think I'll be headed to CS.
That is the point i have gotten to in autocross as well. I just want to show up and drive.
DylanFRS is offline   Reply With Quote
The Following User Says Thank You to DylanFRS For This Useful Post:
qoncept (04-14-2014)
Old 04-14-2014, 03:22 PM   #101
qoncept
qoncept's Avatar
I kind of learned from the old guys.. they stay in stock class and make everything as easy as possible. I used to show up with tires thrown in the trunk, a crappy jack and a 4-way. Now I have a trailer, impact, torque wrench, gloves and a torque wrench and do it right. So it's about half as awful as it used to be. But it's really frustrating when I'm the only guy left in the parking lot at the end of the day changing tires.
Old 04-14-2014, 07:05 PM   #102
renfield90
The Stig's German cousin
Originally Posted by AustinTX View Post
Is there a significant setup change between street/race tires?
On my setup at least, I'd say yes. I get a fairly neutral car if I'm on brand new street tires, but a fairly pushy car with fresh race tires. I'm still on OEM shocks, but if I went back to race tires I'd want aftermarket shocks to try and tune some of that push out.
Is anyone planning to go to Nationals this year and run CSR?
Old 04-14-2014, 10:06 PM   #103
EN2_Squirrel
EN2_Squirrel's Avatar
I did my first prosolo over the weekend and while i was on course working noticed that the 370z was also classed in C street. It won CS and was a couple thousandths off the winning time of B street. Are the twins or even a NC miata capable of competing with it. Considering you can fit a very large tire to help with all the power. I was curious.
meant to put this under c street discussion
EN2_Squirrel is offline   Reply With Quote
Old 04-14-2014, 10:43 PM   #104
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
In my opinion, with the right tires it would depend on the course.
On a tight more technical course the twins shine. On a more open course they just don't have the lateral acceleration.
Old 04-17-2014, 02:46 PM   #105
edj
edj's Avatar
Drives: 2022 Toyota GR86
fyi, i have one new Hoosier A6 tire for sale.
see ad here: Hoosier
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 05-12-2014, 01:26 PM   #106
TrqlessWonder
Drives: 2014 FR-S
They definitely behave differently. Still way early in my car development, though. (only the r-comps, camber and alignment at the moment - 20mm whiteline coming this week.)
I unhooked the rear bar for my first r-comp event, and that felt pretty good, did fairly well. It was a non-scca club so it's a little hard to gauge my performance. I could just barely rotate the rear under power in sweepers. And it was very stable in the slalom. Although the body roll was buick-like, and the rear of the car flopped like it was the World Cup. But putting power down was not an issue. Almost can't overwhelm the hoosiers.
Made no changes other than different venue and too cold for hoosiers, so I ran on the OEM tires and...yikes. I had a real hard time keeping the back end in the back, hard time putting the tiny amount of power down, and the low-speed understeer was infuriating. And I did poorly.
Separately, I then did the NJ Tour. I won my class (of one) but I got raw-timed on sunday by a CS RX-8. Saturday, I only avoided that by a tiny margin.
Saturday I did without the rear bar, and Sunday I did with it hooked back up. Car felt better sunday, but I performed worse relative to CS. Also, was running 36-37F and 33-34R with the bar unhooked, and was down at 33/32 with it back up, and I'm still not using all of the tire. More importantly, It was in the mid-60's that weekend, and I built up NO heat in the tires. Barely above ambient. Anyone run across that?
We'll see how much the front bar helps with getting the tires working. I suspect I'll need better shocks than OE, but that's going to be an off-season thing. Anyhow, season-long TnT continues....next stop, Ralph Wilson Stadium.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 05-15-2014, 12:05 AM   #107
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
CS offset question: I have a line on some of the optional BBS wheels you could get for the WRX back in the day. Light, 17"x7". Offset is +53. You can be 6 mm from stock offset, which these would be. Thing is, 5mm more sunk is pretty much the opposite of what I'd want. So, can I run 10mm spacers and swap out my lugs for something longer and stay "stock"? Spacers are legal to correct offset... but what about lugs to allow proper thread engagement?
Second, can I run the TRD sway bar set and/or springs? I'm mostly wanting to get back into autox for fun but I'd like the very few mods I'm planning to align with stock class. Sounds like the TRD exhaust and air filter are kosher regardless.
Quentin is offline   Reply With Quote
Old 05-15-2014, 07:05 AM   #108
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Yes, extended studs are allowed in CS, and you'll need them for any spacer over 3mm.
You cannot use TRD stuff. Even first-party aftermarket parts are not allowed. You could use the RS model parts if you COMPLETELY convert if you have the matching year car. Not a cheap proposition
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-15-2014, 07:51 AM   #109
Quentin
Good to know. TRD exhaust still kosher since it is just a cat back? I'm not totally convinced on the springs anyway, but the sways would have been nice.
Old 05-15-2014, 08:06 AM   #110
Kido1986
Dodging cones
Kido1986's Avatar
Correct, the catback is fair game. You can run s straight pipe for your catback if you really want (and are masochistic), as long as it is full length.
Trust me, these cars need NO extra rear sway bar. Sway bars are for balancing, not 'stiffer is better'. This car needs more front bar, which means more rear bar would counter productive.
Check out the "C Street questions" link in my signature for more information on setup.
Old 05-15-2014, 08:37 AM   #111
Quentin
Excellent, thanks. (I have signatures and avatars hidden on this forum, so that is why I didn't notice your c-stock info.) I'm fine with the TRD exhaust. I like the OEM look.
Old 05-15-2014, 09:01 AM   #112
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
This is exactly why I went from ES to STR in my old Miata, and why I went to STX in the Toyobaru. Not changing tires at the beginning and end of every event takes away the worst part of the entire experience (except maybe working course when the FJ karts are running).
neurokinetik is offline   Reply With Quote
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 03:52 PM
Let's discuss SCCA Stock Class ayau Tracking / Autocross / HPDE / Drifting 314 04-18-2013 02:03 PM
SCCA RTR Vs C stock theredtape Tracking / Autocross / HPDE / Drifting 7 03-27-2013 03:26 PM
Motion Control Suspension Singles---SCCA Stock legal are done! Sam Strano Tracking / Autocross / HPDE / Drifting 25 01-16-2013 02:42 PM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
