Old 04-13-2014, 06:28 PM   #1
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Wheel Directory: Enkei Raijin 18x9.5 +45
Enkei Raijin's, 18x9.5 +45 squared with 255/35/18 Nitto NT555 all around. No rubbing, no clearance issues (yet!). I'm also running Cusco LCA with KW V1, lowered 1.5". Thanks to Ben at AJR for making this happen.
Gratuitous Shih Tzu Shot
Thanks for any feedback.
Scaldy is offline   Reply With Quote
Old 04-14-2014, 01:10 AM   #2
carlo1912
Drives: '11 BMW 135i, Scion FR-S (future)
Just curious, what is your current camber setup? It seems that 18x9.5 runs the best for square setup, off course with correct offset and tires.
carlo1912 is offline   Reply With Quote
Old 04-14-2014, 03:43 PM   #3
Scaldy
Scaldy's Avatar
Sorry, I wish I was more technical with the details. I do know my mechanic doesn't follow factory specs.
Old 04-15-2014, 11:20 PM   #4
PEWPEW
PEWPEW's Avatar
Drives: 10 Series FRS
PEWPEW is offline   Reply With Quote
Old 05-09-2014, 06:00 PM   #5
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Old 05-16-2014, 03:29 PM   #6
loogs
Drives: on cruise control
heres mine
18x9.5+45
265/35/18 Michelin PSS
ride is amazing. fenders were rolled slightly up front
camber is about -2.8 up front. not sure about rear but i could check if anyone wants
loogs is offline   Reply With Quote
Old 07-02-2014, 04:11 PM   #7
whiteout86monogram
Drives: 2014 monogram series whiteout fr-s
how low are you guys lowered, and what are you lowered on?
whiteout86monogram is offline   Reply With Quote
Old 07-02-2014, 05:19 PM   #8
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
These are my favorite enkei wheels right now, I wish they had them in a gold finish becuase I don't really want to paint/plastidip them. Looks amazing on both your cars.
ModalSoul37 is offline   Reply With Quote
Old 07-02-2014, 05:49 PM   #9
loogs
im on fortune auto 500 coils. not sure how much of a drop it is. probably close to 2"
Old 07-05-2014, 08:03 AM   #10
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
I'm looking at the 18x9.5 +45 all around or 18x9.0 +44 all around. There's 5.4mm difference in the poke between the tow options.
Now you've had your setup for a while are you able to advise if you've had any rubbing issues etc. I'm lowered about 1.5" on TRD coilovers.
Not sure if its afer going the narrower wheels with 5.4mm less poke or the wider wheels with a little more stretch so the side walls are angled a bit to minimise rubbing risk.
Looking at the TWS T-66F wheels that cost HEAPS so need to make the right decision.
Your feedback on rubbing issues is really important so I'd appreciate it.
nzer is offline   Reply With Quote
Old 07-05-2014, 09:11 AM   #11
loogs
he stated that he has no rubbing issues. i had small rubbing issues with the back bumper, as stated by Jive. but that rubbed itself out so no rubbing anymore. im on 265's. if youre doing 255 youll be fine. if you wanna be conservative, go 18x9 with 255
Old 07-08-2014, 09:21 PM   #12
Scaldy
Scaldy's Avatar
Still no rubbing issues. Hope that helps
Old 02-24-2015, 09:28 AM   #13
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
I'm planning on running a 18x9.5 +45 squared with 255/35/18 setup with TEIN coilovers. (and even the same car color and wheel color)
I see you are running coilovers, did you need spacers or anything to make it work?
If you are not sure if you have spacers, can you take a picture from where the wheel meets up with the brake rotors? a little on the side looking where the wheel and the brake rotors meet.
Can you please send me pictures of how the wheels are with the body? (are they a little in, flush with the body)
OnionTou is offline   Reply With Quote
Old 05-18-2015, 09:14 PM   #14
JellyForSale
That Striped FRS
JellyForSale's Avatar
Drives: 2013 Ultramarine FR-S 6MT
Been looking for rims and think I've found a perfect set for an FRS with TRD lowering springs. 18x8 seems to be the winner to me, I only have one question...
Are ANY of the Raijin colorways finished or coated? I live in the Northeast of USA and dont want another unfinished or uncoated rim. The corrosion and upkeep is too much for me daily this car if the rims cloud up every week
JellyForSale is offline   Reply With Quote
Wheel Directory: Enkei NT-03M 18x9.5 +40 Touge Factory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 140 12-08-2021 12:15 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 11:37 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 03:51 PM
Wheel Directory: Enkei Raijin 18x8.0 +40 / 18x9.5 +45 seanmc69 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-08-2013 12:38 PM
