Old 04-12-2014, 02:04 PM   #15
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I think I got it. I'll check when I get out of work before I leave. I think it should be cool by then too.
Luckrider is offline   Reply With Quote
Old 04-13-2014, 04:02 AM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
For a hot kind of smell wouldnt you also want to be checking EGT's and oil temp/psi?
Old 04-13-2014, 09:46 AM   #17
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Open the .bin in the editor and set HOTSMELL to 0
The Following 7 Users Say Thank You to SloS14 For This Useful Post:
Apoc (04-13-2014), drewbot (03-23-2016), flippy (08-13-2014), Garrett@Openflash (04-15-2014), number1Tango (04-16-2014), Sojhinn (04-13-2014), TopGearSolutions (04-21-2014)
Old 04-13-2014, 04:23 PM   #18
Kody
Drives: 2013 Subaru BRZ
Originally Posted by Sojhinn View Post
Grab a rag run it along the bottom of it. If it has oil you have an issue. Take it to the dealer please because not enough people have been doing this and they still haven't released a tsb. I had to prove to the dealer that it was leaking which was annoying. Took two days for them to fix it. (It's an easy fix though)
After taking a look at the pictures you posted, I do believe this is the cause of the smell. I took some pictures of mine so you guys could see exactly what it looks like....definitely wasn't clean looking like the picture you posted.
http://imgur.com/5xC2JJM
What I got on the paper towel after rubbing the bottom of it:
http://imgur.com/nUyeWjG
If this does indeed look like the problem then I have a couple of questions.
  1. Is it something that needs to be fixed immediately or can it wait a week or so?
  2. This is covered under warranty right? If so, should I bother flashing back to stock for this?
Kody is offline   Reply With Quote
Old 04-13-2014, 04:30 PM   #19
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
"Hot" smell coming from engine after latest OpenFlash - 1.59
It's covered by warranty and it can wait a week. I would always flash to stock before taking my car into the dealer. Just make sure you push the car (I.e. Put it under some hard loads) before going into the dealer. That way it's easier for them to spot the leak. My dealer was a bit of an idiot in regards to this even after I told them where exactly the leak was.
Edit: also mine was cleaned really recently.
Installed Mods:
Old 04-13-2014, 04:49 PM   #20
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
How long have you had your car or more specifically, how many miles are on it? I've spoken to my service dept about this, but this was some time ago and I no longer notice that "non magical" smell.
Wolfking is offline   Reply With Quote
Old 04-13-2014, 05:09 PM   #21
Sojhinn
Sojhinn's Avatar
My car has 19000 miles and it was still making this smell due to the leak. If you don't push your car hard it won't leak though. Guess I'm just mean to my car.
Installed Mods:
Old 04-13-2014, 09:46 PM   #22
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
I ruined my '98 S14 "being mean" to it! I will never do that again. I am, however a very serious driver. If I can't "drive it like I stole it" (occasionally) , then there's no point in having it!
The Following User Says Thank You to Wolfking For This Useful Post:
Old 04-13-2014, 11:03 PM   #23
fledonfoot
Drives: Asphalt FR-S
Originally Posted by Apoc View Post
--snip--
I sent logs to John Visconti who was my tuner at the time and he said it "looks good".
fledonfoot is offline   Reply With Quote
Old 04-15-2014, 12:05 AM   #24
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
It's not a huge rush, but definitely get it checked out. Yes, it's covered under warranty.
Big thread about the leaky cam plate here:
http://www.ft86club.com/forums/showthread.php?t=26197
MagicBobert is offline   Reply With Quote
The Following User Says Thank You to MagicBobert For This Useful Post:
Kody (04-15-2014)
Old 04-15-2014, 02:05 PM   #25
Kody
I've noticed that thread during my recent research, lots of good info. After reading a lot of other people's experiences trying to fix this it made me scared to go to the dealer.
I saw that Raceseng (or however you spell it) sells an aftermarket cam plate cover that seems to work very well. It makes me wonder if I should just fix this thing myself and stay away from dealer "fixes".
Old 04-15-2014, 05:07 PM   #26
MagicBobert
I'm watching mine and if it ever starts leaking I'm going to replace it with the Raceseng plate. I'm trying to do most of the maintenance and small things on the car myself and only take it to the dealer for any huge maintenance/warranty work.
"Hot" smell coming from alternator Wilso Issues | Warranty | Recalls / TSB 48 12-20-2023 12:08 PM
Can anyone elaborate on Openflash Tablet "improved drivability"? Formula Vee Software Tuning 42 03-31-2014 11:13 AM
BRZ "engine undercover" Part number Blood BRZ First-Gen (2012+) — General Topics 6 01-29-2014 01:55 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
At about 3000 Miles, Engine became quite a bit "smoother" jflogerzi Engine, Exhaust, Transmission 10 09-04-2012 12:11 AM
