Old 04-11-2014, 11:44 AM   #1023
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys,
We are working out the .csv download bug right now. Looks like it was born at the same time we finished the new realtime data display option. Hang tight
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (04-11-2014)
Old 04-11-2014, 12:07 PM   #1024
Shiv@Openflash
Drives: 2013 FRS
UPDATE: CSV download bug fixed. Just connect your OFT to OF Manager to get the update/fix
Luckrider (04-11-2014)
Old 04-11-2014, 12:42 PM   #1025
nelsmar
Originally Posted by Td-d View Post
I've added AF 3 correction, learning and rear o2 comps to the ZA1JA01C definition up on Github. I'll add to the other definitions shortly.
EDIT - added to all roms on Github
Your the man!! I honestly wasn't quite sure (nor did I check) if the shelf maps were using your def's or not. Thanks!
My flickr - Canibeat
Local magazine scout
Old 04-11-2014, 05:05 PM   #1026
D-VO
Drives: Whiteout FR-S, Evo 8 RS
I'm assuming the log that's currently on the OFT is toast then right? My .csv still won't load.
D-VO is offline   Reply With Quote
Old 04-11-2014, 05:21 PM   #1027
Shiv@Openflash
Drives: 2013 FRS
I don't know. If it's still not downloading from the OFT after the bug fix, then I think it's gone for good unfortunately.
Shiv
Old 04-11-2014, 06:01 PM   #1028
D-VO
Shiv
Ok. I'll give it another go on the way home. Thanks.
Old 04-11-2014, 06:28 PM   #1029
steve99
Drives: FT86
Shiv
Data logging works now thanks for quick fix.
confirmed any log in OFT before update cannot be read, new logs all good.
Large gauge is good, any chance of a beep/sound over settable levels would get complex though for AFR.
Old 04-11-2014, 06:30 PM   #1030
Shiv@Openflash
Drives: 2013 FRS
Yes, you will like the enhancements to the gauge display that we are working on now
Old 04-11-2014, 09:19 PM   #1031
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Interesting start up this afternoon. Warmer outside, cooler garage (car sat overnight, started around 1pm), E85 stg 2 ELH tune, perrin CAI, car started and then three pops, like someone hit the empty end of a pringles can Pop...Pop..Pop. No stutter or hesitation, car warmed up fine, then drove with no issues. Left it outside in the sun at work, left work late afternoon, normal start up.
Any ideas?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 04-11-2014, 09:27 PM   #1032
Shiv@Openflash
Drives: 2013 FRS
Any ideas?
When running E85, it's not uncommon to get some intake/exhaust pops during cold start. I get them from time to time as well. It should only be for the first few seconds of start up. After that, the car should settle into a reasonably smooth idle. Once warm, it should be perfectly smooth (like stock). Just a helluva lot quicker
Superhatch (04-11-2014)
Old 04-11-2014, 10:40 PM   #1033
Superhatch
AIM4APX
Superhatch's Avatar
I can attest to that.
Old 04-11-2014, 11:10 PM   #1034
D-VO
No problems downloading the log now! Thanks a lot!
Question: I'm not getting this IAM thing. I still have mine set .70. Sometimes it raises to .84 other times it drops as low as .27 apparently when I have knock. That's all fine, but why does the value stay there for so long? I drove for about a half an hour and it didn't move from .58 the whole ride. Is that normal or is there something wrong with the logger? Thanks.
Old 04-12-2014, 12:50 AM   #1035
radroach
Drives: car
@shiv@vishnu
I've heard that there's loud cold start on the stage 2 tune, can you talk a little bit about that? What about stage 1?
I live at an apartment and would like as normal cold start sound as possible, considering that I may also buy an OFH and a catback exhaust.
Old 04-12-2014, 02:35 AM   #1036
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's normal. The IAM won't increase until you give the car higher loads and it sees no knock.
.: Stealth 86 :.
Kodename 47 DJ:
D-VO (04-12-2014)
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
