Old 04-11-2014, 01:59 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Exclamation 2014 FRS Kickbacks
Hey,
I will try to explain the issue, but I am not good with words. So recently I bought a FRS 2014. Manual Transmission
Everything so far is stock on it. I haven't installed anything.
When I am shifting from any gear up or down the car has little kickbacks. As it's braking. I let my friend drive it and said its not normal. I will bring it to the dealer, but first I would like your help and thoughts about it!!
Mikeez is offline   Reply With Quote
Old 04-11-2014, 02:30 PM   #2
A3r0pusH
A3r0pusH's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Watch your rpms as you shift into the next gear. Depending on how fast you let out the clutch and at what point in the rev range you are, the transmission and engine rpm will sync up very harshly.
A3r0pusH is offline   Reply With Quote
The Following 3 Users Say Thank You to A3r0pusH For This Useful Post:
flippy (04-11-2014), samisons (04-11-2014), Wes (04-11-2014)
Old 04-11-2014, 03:24 PM   #3
mike the snake
I've found this car is very hard to drive and shift smoothly. I think it has to do with the clutch pedal, which affects disengagement.
There's a thread about removing the "clutch pedal spring" where everyone reports that removing this spring makes the pedal feel more like every other car. I plan to remove this spring myself.
Do a search in the DIY forum here.
Old 04-11-2014, 03:43 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Have you tried rev matching?
N1rve
Old 04-11-2014, 03:47 PM   #5
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
This probably is related to rev matching before I adjusted my clutch and started rev matching a little the car always seemed to lag between gears...now smooth as butter
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 04-11-2014, 03:50 PM   #6
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
My cousin said this to me when he first got this car. It's your shifting. Try to give it a bit of gas and release your clutch slower. Try to make your shifts as smooth as possible.
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Old 04-11-2014, 03:50 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Removing the spring in my car did help, but the clutch still sucks haha. I'm now looking into tearing open the master/slave cylinder to see if there is some sort of a delay valve or something.
Old 04-11-2014, 03:55 PM   #8
no1r
Showboater Nazi
Drives: 2014 Whiteout FR-S 6M/T
As others have said, the only solution is to work on your rev matching. Shouldn't be an issue during upshifts - the solution there is to slowly bring the engage the clutch as you slowly give it gas. Downshifting - that takes a bit more as you should learn your revs at said speed in each respective gear; it will make it easier to match as well as eliminate your jerking for the most part. As others of said, lower your pedal helps, but the fundamentals are still the same, even if you lower it and just engage the clutch after shifting, it's still going to jerk.
no1r is offline   Reply With Quote
Old 04-11-2014, 03:56 PM   #9
A3r0pusH
A3r0pusH's Avatar
There has been some talk about not being able to remove the type of cdv we have. Let us know if you find anything about that.
Sent from my HTC6435LVW using Tapatalk
Old 04-11-2014, 04:18 PM   #10
Luis_GT
It's all about knowing the engagement points of the car and how to match the RPM drop on the upshift. I get that jerking issue sometimes when I drive the M3 due to the fast dropping RPMs and very tall clutch engagement, but not on my FR-S and I have not messed with any clutch adjustments.
Old 04-11-2014, 05:02 PM   #11
Mikeez
Engineering Student
Okay guys =D thanks I will keep you updated.
Old 04-11-2014, 05:16 PM   #12
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
i remember my first manual transmission car....
driftartist is offline   Reply With Quote
Old 04-11-2014, 06:23 PM   #13
continuecrushing
Yeah, I've seen a few people say that, but I havent seen any proof of why it either isnt removable, or if there even is one to begin with.
All I know is that the clutch/lack of clutch feel in this car is by far the most hated thing, for me anyway. And I'm sure it really isnt even all that bad, but the rest of the car I love so much, so the clutch just happens to really bug me lol.
2014 86CUP presented by Winmax #4 -Chuckwalla Valley Raceway - Apr 5, 2014 (Saturday) CSG Mike Tracking / Autocross / HPDE / Drifting 128 04-17-2014 12:33 AM
2014 Winmax 86CUP #4 - Chuckwalla Valley Raceway - Apr 5, 2014 (Saturday) CSG Mike Southern California 13 03-22-2014 09:50 PM
2014 86CUP #3 - Buttonwillow Raceway Park 13CW - Feb 22, 2014 CSG Mike Tracking / Autocross / HPDE / Drifting 17 02-24-2014 09:40 PM
2014 86CUP #2 - Willlow Springs International Raceway - Feb 16, 2014 CSG Mike Southern California 14 02-17-2014 05:52 PM
2014 1st ANNUAL CENTRAL FLORIDA SUBARU MEGA MEET & GREET 2/15/2014 Opie Southeast 1 02-10-2014 05:24 PM
