Old 04-10-2014, 07:19 AM   #4173
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by Decay107 View Post
Just got a temp gun and the coated header surface closest to intake was about 250-270F. This was after about 30 minutes of (city) driving and 10 minutes of idle. Engine was on at the time. I also couldn't find any surfaces in the bay over 200F. Ambient temperature was mid 60s.
Interesting. I would say those are comparable tests from the sound of it. Also seems your surface temp is higher than mine. Doesn't rule out my suspicion that the coating is trapping and also radiating more heat at idle which makes sense if it's primary purpose is gas temps and flow. Again I don't think the black color is helping the radiation situation. Glad I didn't coat mine.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 04-10-2014, 10:14 AM   #4174
tennisfreak
Drives: 2018 BMW M240i
@Dustin you're still running the stock tune? If so how does it feel? Any noticeable bump in power and a noticeable loss in torque dip?
Old 04-10-2014, 11:23 AM   #4175
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Was your testing mostly highway? That's the only thing I can think of that may invalidate in my data. As for the difference I'm not really worried, merge collectors on my Honda CBR get up to around 340 F under similar conditions and sit much closer to plastics.
Hopefully I'll have some track data in the next few weeks (20-30min session, temp will be taken right after the cool down lap)
Decay107 is offline   Reply With Quote
Old 04-10-2014, 11:52 AM   #4176
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Dustin View Post
Just installed the rest of my 3" Nameless exhaust.
Outside vehicle
Inside vehicle normal acceleration
Inside vehicle aggressive acceleration
Holy mother of RASP!
Yikes. Might want to consider adding a few resonators to that system if you want it to sound good. That's just obnoxious the way it is.
Old 04-10-2014, 12:49 PM   #4177
FR-S Matt
The system has a resonated downpipe and a resonated midpipe. Unless you add like 4-5 more resonators, you need a quieter axleback portion.
Old 04-10-2014, 03:35 PM   #4178
FrsDuke
Fanboy
FrsDuke's Avatar
Yeah an hour on the highway but then 10 min at idle just like you. The last 10-15 min of my drive was city...
TL;DR:
-Duke
Old 04-10-2014, 04:08 PM   #4179
emutcfut
Drives: 2013 Argento
Your results got me curious and so I did some googling.
I think some of the temperature readings may be off due to the color where black will give the true temperature and reflective surfaces (uncoated) may only give an apparent temperature.
This was a good read for me, especially the part where they bake a block of metal with one side painted black and left the other side alone.
http://www.reliableplant.com/Read/14...ctual-ir-temps
emutcfut is offline   Reply With Quote
Old 04-10-2014, 05:41 PM   #4180
Craig
Craig's Avatar
Drives: Asphalt FRS
Outside vehicle
Guess I just like rasp because that sounds amazing to me
Current: Nameless Headerback- Crawford BPB - Zeta Intake Duct - Mishimoto Intake
Craig is offline   Reply With Quote
Old 04-10-2014, 07:26 PM   #4181
mad_sb
Drives: 2013 Asphalt FR-S
inside sounds ok, outside.... no sir, i don't like it. That sound is why i have a Q300.
Old 04-10-2014, 10:23 PM   #4182
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Does anyone know if the Q300 is louder than stock muffler? Or is it about the same?
Thx
Lawnik is offline   Reply With Quote
Old 04-11-2014, 10:57 AM   #4183
mad_sb
Thx
I would say it is a bit louder but has a much smoother note when paired with a block back exhaust.
Old 04-12-2014, 08:27 PM   #4184
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
I am running the 5" Nameless Axelback and am waiting for my Nameless headers and Injen intake to come in.
Anyone running a similar setup with any videos??
Brahsbrah is offline   Reply With Quote
Old 04-12-2014, 09:14 PM   #4185
FrsDuke
Fanboy
FrsDuke's Avatar
I would cancel that injen order if you can. Well established it's not a good mod.
Unless you ask beavis that is...
TL;DR:
-Duke
Old 04-12-2014, 11:54 PM   #4186
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
No tuned dyno yet
Mars2 is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
