Old 04-09-2014, 05:48 PM   #29
gramicci101
Off Topic
I was thinking more for CSG's personal track usage, since most of the other brands tend to creep randomly.
Old 04-09-2014, 05:54 PM   #30
CSG David
CSG David's Avatar
We're not hiding anything from anyone with an ultra secret spec setup. We build our cars with selected parts off the shelf and show what happens what a balanced setup can do. Each item on our car has been purchased out of pocket and tested. SPL hasn't creeped at all yet.
Old 04-09-2014, 05:59 PM   #31
gramicci101
Off Topic
I was thinking about doing my own; the only daunting part is everything must be perfectly aligned when you set the first welds. I'll probably pass on making LCAs, but I should be able to make all the underbody bracing pretty easily, and much cheaper than the brand name versions are sold for.
Old 04-09-2014, 06:00 PM   #32
CSG David
CSG David's Avatar
Wouldn't waste too much time on bracing unless you need to add weight to your car for specific race group just to add additional weight to the base of the car...
Old 04-09-2014, 06:06 PM   #33
gramicci101
Off Topic
Really? I'd have thought it would have a decent effect on chassis stiffness. That's how they're marketed, at least.
Old 04-09-2014, 06:21 PM   #34
CSG David
CSG David's Avatar
The chassis is good from the factory, spend time on track to extract the most of the car utilizing your driving techniques. It'll eventually show that alignment is a crucial piece to the equation for better performance.
Old 04-09-2014, 06:26 PM   #35
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Man I don't want to install my SPC LCAs now after reading this but ill be stuck with nothing if I don't since I wont be able to get another LCA here for the weekend install...
Decisions Decisions
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-09-2014, 06:34 PM   #36
CSG David
CSG David's Avatar
Decisions Decisions
What is your intended application/use? What is your driving experience level? What modifications have you done? What tires will you be using?
Old 04-09-2014, 06:36 PM   #37
BRZZZZZZZZZZ
Car Nut
Mostly daily driving, but I also intend to compete in at least 10 STX events for solo 2 this year and one or two lapping days at a road course. Car is also driven year round in heavy snow and rain sadly. I have done plenty of carting, auto x in other vehicles I have owned and a few lapping days in various vehicles, but I am no expert by any means. I have Raceseng camber/caster plates, Bilstein sport series shocks, RCE Yellow springs, and Eibach sway bars and will be sitting on 16x7 Volk TE37 wheels with 225/50/16 Hankook RS-3s.
Old 04-09-2014, 07:08 PM   #38
CSG David
CSG David's Avatar
If you have the SPC LCA, just run it. Check the LCA after every event to make sure it's still tight. You might want to check alignment settings every couple events to make sure it's still good. Your tires aren't R-comp or slicks status so that should reduce some potential failure. In your localized setting, a snapped LCA won't pose a danger issue to yourself or people around you since your average speed isn't very high.
The Following User Says Thank You to CSG David For This Useful Post:
Itsjusdame (04-09-2014)
Old 04-09-2014, 07:36 PM   #39
Calum
That Guy
Drives: 2013 asphalt FRS MT
Thanks for more great info CSG!
The damage to the car would suck though. Piece of mind is worth a lot to me, I think if I needed that much rear camber I'd sell the SPC's based on this thread.
About the creep, I'd suspect it's the aluminum that's creeping.
What's your opinion on slotting the stock arms? I know it was said sarcastically, but I've actually been considering it for some time. I like that the stock arms are cheap, strong enough for anything I'm going do to with them, yet weak enough that they'll sacrifice themselves before the car bends. I was really hoping to run the whiteline LCA adjustment bushing, but they stopped making them and I can't find them anywhere. Actually, I didn't pm you guys, @CSG Mike, is there any chance you guys have a set in stock? Shoot me a PM if you do, please.
Old 04-09-2014, 08:18 PM   #40
CSG Mike
CSG Mike's Avatar
Someone at the manufacturer end will get fired, if a little 2lb brace made a substantial difference on a chassis that weighs 600+ lbs.
wparsons (04-10-2014)
Old 04-09-2014, 08:24 PM   #41
gramicci101
Off Topic
A fair point. In that case I won't bother with them.
Old 04-09-2014, 08:36 PM   #42
CSG Mike
CSG Mike's Avatar
On the other hand, there are braces used to bind bushings, which may have a substantial effect
Need help deciding on Exhaust DannyFRS Engine, Exhaust, Transmission 1 02-23-2014 05:10 PM
Deciding on an exhaust JohnAyySays Engine, Exhaust, Transmission 32 12-28-2013 11:31 PM
What other car did you consider before deciding on the BRZ? txeng86 BRZ First-Gen (2012+) — General Topics 132 10-30-2013 03:49 AM
Deciding between... (help appreciated) rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-27-2013 03:53 PM
