Old 04-09-2014, 10:21 AM   #1233
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by FyeaFRS View Post
Going to be running the 4TF218-124 kit engine oil fed kit. Where's the best place to tap for the oil return?
It looks like here is the spot for the feed.
Easier to just get an aftermarket oil pan?
Huh I have never heard of them offering this kit with an engine oil feed. Interesting.
http://www.vortechsuperchargers.com/...n.php?pvk=4729
djdnz is offline   Reply With Quote
Old 04-09-2014, 10:53 AM   #1234
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Someone local has one, forget his FT86 account.
Vortech provides a bung to be welded on the passenger side valve cover. It's a PITA to get to and remove the Valve cover.
Nolan
pheoxs is offline   Reply With Quote
Old 04-09-2014, 10:55 AM   #1235
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
Instead of welding a bung to the valve cover couldn't you just use that oil feed spot FyeaFRS pointed out?
marcoaferrer is offline   Reply With Quote
Old 04-09-2014, 11:54 AM   #1236
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
My guess is you can't use that for return because the pressure is trying to push oil out of that hole.
Old 04-09-2014, 12:03 PM   #1237
marcoaferrer
I actually talking about the feed lol. If he can get the feed from that bung then why go through the hassle of welding a bung on to the valve cover.
Old 04-09-2014, 12:12 PM   #1238
DJCarbine
Thupercharged
DJCarbine's Avatar
Oil drain perhaps?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-09-2014, 01:30 PM   #1239
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
The valve cover bung is for the drain.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
Sportsguy83 (04-09-2014)
Old 04-10-2014, 02:51 PM   #1240
415FRS
Drives: Red SCion FRS
Belt broke again last night. This is the 3rd times i have to replace it. What did everyone do to fix the issue? I know there were few people here had the same problem. Please help, i try to look but didnt find the answer. Thanks
Sent from my HTC One using Tapatalk
415FRS is offline   Reply With Quote
Old 04-10-2014, 02:54 PM   #1241
nelsmar
What pulley size and belt size are you using? My issue was too large of a belt & alignment. Don't forget the upper mount is slotted so that you can align the pulleys.
My flickr - Canibeat
Local magazine scout
Old 04-10-2014, 02:57 PM   #1242
415FRS
I got the sc kit about 7months ago and that was the pulley and belt size that came with the kit. Didnt do any upgrade for the pulley, and everytime the belt break, i replace it with the same size one. Thanms
Old 04-10-2014, 08:25 PM   #1243
DJCarbine
Thupercharged
DJCarbine's Avatar
K060975?
Check the plastic idler pulley next to the supercharger pulley on the bracket
2013 FRS
Vortech V3 11psi
Old 04-10-2014, 08:26 PM   #1244
DJCarbine
Thupercharged
DJCarbine's Avatar
Anyone running colder plugs?
2013 FRS
Vortech V3 11psi
Old 04-10-2014, 08:54 PM   #1245
nelsmar
Try installing a k060970. Vortech changed their belt sizing recently.
Old 04-16-2014, 09:01 AM   #1246
Philly758
Drives: GMC
Before starting my own thread I figured I would post here...
I finished installing my Vortech supercharger this past weekend and tuned it with an off the shelf FA20CLUB tune. The test drive went well, the car drove smooth, no CEL (this thing is awesome!). The next day when I started the car I got a CEL, drove the car home from my brother's when I did the work, plugged in my scangauge and pulled a P0451 code. Cleared it, started it again and went for the test drive, no check engine light no issues. The next day I drove it to work, 45 miles without any issues. I start the car after work and the CEL comes up, pull the same PO451 code, clear it. It felt normal pulling out of the parking lot but quickly felt like stock again, or worse. I think I am stuck in limp/safe mode even though I don't have a CEL currently.
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
So, I am looking for some advice. Has anyone had a similar issue and success resolving it. What could be causing this? Anything I should check? What should I ask my tuner for (disable the code maybe)? If I were to disconnect the battery for 15 minutes or so to permenantly remove the code and get out of limp/safe mode, would I be running the risk of causing any damage?
Thank you. I appreciate your help in advance.
Philly758 is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
