| Mid-Atlantic DC, DE, MD, VA, WV |
#15 | |
Drives: pinto power
Sent from my HTC6500LVW using Tapatalk |
| The Following User Says Thank You to camelflage For This Useful Post: | ecdhunt (04-04-2014) |
#16 |
Drives: 2014 Firestorm Scion FR-S
For the ones that suggest BC, Megan coilovers and the like when thinking of cheap coilovers, what about ST coilovers, which are basically KW V1 Basics? I know you don't get the adjustability, but at ~$900 wouldn't this just about equal a good spring/shock combo (maybe even cheaper) with the added bonus of a properly matched spring rate and shock valving?
Sent from my SPH-L710 using Tapatalk |
#17 | |
Drives: pinto power
#18 |
Exactly how I feel. Don't plan on tracking the car much, so springs and a good set of shocks are the only thing on my mod list. If I decide to track more, I'll run the coil overs for adjustability.
#19 |
Drives: 2013 SWP BRZ Limited
I don't see why so many people opt for coilovers (probably just e-bragging/bling-factor).... Sure you get the adjustability, but how many people will actually use it? Most people just choose one setting and never mess with it ever again, ride height especially since you would have to remove the entire coilover to adjust it in most cases.
Unless you are into autocross or plan on doing track days, springs aren't a bad option as long as you pick a spring that works well with the stock dampers. |
#20 | |
Drives: pinto power
#21 | |
#22 | |
Drives: BRZ and NA
Of course, that purpose may be to slam the car to the ground rather than achieving a lower center of gravity and proper corner weights, but to each his own. |
| Coilovers or Springs? | Ymerej | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-10-2014 12:26 PM |
| springs vs coilovers?? which is best? | FRS-HHH | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 06-11-2013 02:09 PM |
| Coilovers vs. Springs??? | FrSnake | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-18-2013 04:10 PM |
| Coilovers vs Springs – What are coilovers and what’s better? | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-30-2012 12:24 AM |
| coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 08:49 PM |
