Old 04-05-2014, 11:54 AM   #15
evan
Drives: fr-s
Originally Posted by Chen View Post
What the heck just happened?
Don't worry Richard
evan is offline   Reply With Quote
The Following User Says Thank You to evan For This Useful Post:
ZionsWrath (04-05-2014)
Old 04-05-2014, 11:56 AM   #16
evan
Drives: fr-s
Originally Posted by Superhatch View Post
It looks like someone left the bar cranky last night.
Evan, could you possibly make your post a little more informative?
Yup. Sorry about that bud. I probably invited the trolls by being vague. Just tired last night.. I updated my OP to reflect my story.
The Following 2 Users Say Thank You to evan For This Useful Post:
Superhatch (04-06-2014), ZionsWrath (04-05-2014)
Old 04-05-2014, 11:56 AM   #17
evan
Drives: fr-s
Originally Posted by deucethemoose View Post
Avoid it if I want a non-drivable car...
Which means if I want a drivable car, I'll go with an ACT clutch. I feel like the message you were trying to convey was the opposite of what you said...
Yup. I updated my OP.
Old 04-05-2014, 12:26 PM   #18
stockysnail
Just the tip
stockysnail's Avatar
Moral of the story is if you don't have anything nice to say don't say it or perhaps stop and think so you don't show disrespect. Other moral is the Act clutches, even though cheap, are prone to having the 1st gear not work. Exedy it is then. Do you have a link to where you purchased it Evan? I was also considering Clutchmasters but they seemed a little more expensive.
The Following User Says Thank You to stockysnail For This Useful Post:
evan (04-05-2014)
Old 04-05-2014, 01:05 PM   #19
evan
Drives: fr-s
PSA: ACT vs EXEDY street clutches
http://ft86speedfactory.com/exedy-st...h-kit-790.html
@stockysnail.. I had PRE order mine with a 1 week turnaround. It is available from many vendors though.
Old 04-06-2014, 07:12 PM   #20
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Moved to where more people can see this.
The Following User Says Thank You to DarrenDriven For This Useful Post:
PineappleFriedRice (06-23-2014)
Old 04-06-2014, 07:30 PM   #21
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
6 Puck over here working fine... people tune cars thinking it's going to drive as good as stock, it never does. If you really worry about parts working together and being perfect keep it stock
My 2 cent
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
Lakitu (07-07-2018), Ozzman (04-08-2014)
Old 04-07-2014, 03:26 AM   #22
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
I have the ACT 6 puck kit with Street flywheel.
I ran into the exact same problem after about 4000 km on FI car, I already got steel braided clutch lines but I am still running OEM oil.
Was hoping it was just a simple oil change to a better oil as OEM oil got cooked but seems that I might be in need of a new cluch/flywheel kit.
Anyone else with ACT clutchs on there car have any input?
ahaghshenas is offline   Reply With Quote
Old 04-07-2014, 06:30 AM   #23
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I have an act prolite street kit. Been working fine for the last 12,000 miles.
industrial is offline   Reply With Quote
Old 04-07-2014, 10:46 AM   #24
evan
Drives: fr-s
My 2 cent
I'm not sure what meaning your post has other than implying that I have little/no tolerance for the nuances that come with modding. I can assure you that my tolerance is very high. This isn't my first time at the rodeo. I've been into this for the last 17-18 years. Owned many cars along the way.
Not being able to engage 1st gear is an unacceptable problem, modded or not. Do you not agree?
Old 04-07-2014, 07:44 PM   #25
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Not being able to explain why you were not able to engage 1st gear is really killing your cred. PRE took it apart and found nothing wrong at all? That tells me that more than likely there was some kind of install error if the problem was something as drastic as not being able to engage a gear but nothing seemed amiss when disassembled. Especially considering that you were having issues from the very beginning but did not bother to take it to a professional. I'd guess you messed up the install, the shop found the error but said nothing and happily installed the new part.
I'm still trying to wrap my head around how a clutch and flywheel could prevent the engagement of 1st gear. Care to explain?
Old 04-07-2014, 07:50 PM   #26
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Ive been running act clutches in multiple platforms for years. Zero issues, good flywheels, has always held more tq then rated and never busted a clutch disk or rivet unlike other companies ive used.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
Jason@DSG (07-10-2014)
Old 04-07-2014, 07:55 PM   #27
mike the snake
I have the street ACT clutch and flywheel. Not too many miles on it, but it's functioning fine.
If you have trouble getting into 1st at a stop, usually, it's from something dragging (pressure plate, clutch disc, hydraulics) and not completely disengaging and spinning the gearbox, which makes it hard or impossible to get into 1st.
That is not acceptable, of course. Sounds to me like maybe you got a dud.
The Following User Says Thank You to mike the snake For This Useful Post:
evan (04-07-2014)
Old 04-07-2014, 08:17 PM   #28
w00t692
Drives: 2008 Civic Si
ACT clutches are responsible for all sorts of crank walk scenarios on multiple different engines as well. They're trash and i'd NEVER recommend an ACT clutch to anyone ever.
Exedy has always been a quality manufacturer and they make a LOT of different OEM clutches.
w00t692 is offline   Reply With Quote
The Following User Says Thank You to w00t692 For This Useful Post:
evan (04-07-2014)
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Clutches... Synack Engine, Exhaust, Transmission 19 12-16-2012 04:15 PM
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 09:56 PM
