Old 04-04-2014, 12:26 AM   #225
s2d4
s2d4's Avatar
Originally Posted by cslntuee View Post
Will the bigger TB+ tune can get the optimize(better) result?
Thanks.
No.
Old 04-04-2014, 12:31 AM   #226
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Originally Posted by shiv@vishnu View Post
But lost about equal power above that.
The only reason I don't want to immortalize those results now by posting them is because I made some pretty aggressive tuning changes above 6500rpm to regain the lost power.
Yikes. Kinda scary. I was hoping it wouldn't lose so much power on the top end without a tune (maybe only a few at the very top, like the other few results posted before). I wouldn't mind at all sacrificing a few whp at the very top, to gain even more, 10'ish whp, in the mid-high powerband.. but I def don't want to lose, nor trade, an equal amount of 10'ish whp from the top end. I hope your future results will be better
fooddude is offline   Reply With Quote
Old 04-04-2014, 01:25 AM   #227
nelsmar
For the record I only added +2.5 to my cam advance table in the top end, and iirc the ignition & fuel maps were identical, most of my changes were actually in the mid RPM range. And I didn't see a "massive" or "equal" power loss in the top end. Just a slight bit. The average power gained throughout the length of the power band was well above the average power loss in the top end.
The largest loss was ~3WHP @ 7,500RPM. Tapering from 0-1WHP loss @ 7100 or so.
My flickr - Canibeat
Local magazine scout
Old 04-04-2014, 03:03 AM   #228
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Is that with the JDL or just the stock exhaust test?
I would imagine different headers would also affect this as well.
Hopefully someone can get nameless headers and test that, but I'm not holding my breath.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 04-04-2014, 03:29 AM   #229
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I suspect your higher altitude/lower airflow testing condition may skew the results a bit when compared to tests at sea level (like ours). There was very little to be gained through VVT tuning. The OTS Stage 2 UEL map were pretty spot-on. Leaning things out a bit did pick up a couple hp at most. Recovering most of the top end power losses came from rather gratuitous ignition advance changes which is why further road testing is necessary to confirm safety/knock resistance.
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 04-04-2014, 08:18 AM   #230
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by s2d4 View Post
No.
I cannot read Japanese well.
However, I saw some improvement result from the dyno.
http://www.auto-craft.net/shop/produ...?product_id=48
Thanks.
cslntuee is offline   Reply With Quote
Old 04-04-2014, 09:04 AM   #231
Pixie_Niner
Drives: GT86
hmm so it seems that the BPBs will only perform well with specific headers etc?
Would that be the same for exhausts aswell?
Pixie_Niner is offline   Reply With Quote
Old 04-04-2014, 09:45 AM   #232
TiggaPlease
Drives: Asphalt FR-S
Fwiw, we will be offering the BPB at $300 to all our OFT customers who want to/can cash in $100 OFT dollars. We will also offer an OFT+BPB combo package as well. Prices to be released on wed
Any news on the pricing of the combo?
TiggaPlease is offline   Reply With Quote
Old 04-04-2014, 10:08 AM   #233
wparsons
wparsons's Avatar
Thanks.
Forget the TB, it's already huge. Until the engine needs more air than the TB can flow, it won't do anything to help performance at all.
flickr
Old 04-04-2014, 10:44 AM   #234
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
Shiv
Interesting theory Shiv but MotoIQ's tests were done at sea level and their results were basically identical to Marins. Maybe there is something else you did different to get different results from the other three companies? Keep digging... you will find it
Crawford Performance is offline   Reply With Quote
Old 04-04-2014, 10:45 AM   #235
nelsmar
Shiv
http://w1.weather.gov/obhistory/KPHX.html
http://w1.weather.gov/obhistory/KSFO.html
Note the test dates... I tested on 3/29 you tested on 4/2. Both our barometric averages are nearly the same on those days. Both showing roughly 29.9 inHg. Phoenix isn't a very high altitude at all.
edit: weather.gov doesnt have the 39th but shows most dates around there, here is another link for phoenix:
http://www.localconditions.com/weath...85001/past.php
Old 04-04-2014, 10:51 AM   #236
Drives: 2008 STI
As long as the baseline run and the subsequent runs are done in the same weather conditions, the differential between the runs will still be the same regardless.
Old 04-04-2014, 10:57 AM   #237
mid_life_crisis
Drives: FR-S 10 #103 AT
@nelsmar @shiv@vishnu
You two both give a lot to the community. I think it's time for one of you to call the other so you can directly compare notes and come up with the best tune for those of us who freely admit to being clueless when it comes to tuning.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-04-2014, 11:28 AM   #238
Shiv@Openflash
Drives: 2013 FRS
Where MotoIQ's tests done on a filled modified car with a non-stock tune? I don't think we all tested comparable cars in comparable conditions or even on the same kind of dyno.
The car/dyno we used are also used to developer our OTS maps so I have a fair bit of faith it in and in the process applied. Hopefully we will all learn more as more dyno results, from different cars, come in.
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
Squidbelly wants to know the best way to gut a manifold cat regal Engine, Exhaust, Transmission 14 03-07-2014 10:31 AM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
