#211 | |
Drives: FR-S 10 #103 AT
You make a habit of missing self imposed deadlines and people are going to start thinking you've got a life outside the garage. Hell, like you might have a girlfriend or something.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#212 |
We're all waiting....Your life should revolve around ours! LOL
#213 |
Drives: frs
I've asked Shiv more than once about EL, he doesn't answer EL questions. Too bad, I really appreciate what he is doing.
#214 |
Of course he supports UEL more on his free tunes, he sells a UEL header! There's nothing stopping other people from contributing free OTS tunes for any combination of parts.
#215 | |
Drives: Gt-86
Do you think this hood would help the Innovate's clearance with having the BPB's? |
#216 |
Drives: 2013 SWP BRZ
#217 | |
Drives: Gt-86
Yea... just a thought. I haven't seen any other hoods that look like they would help in that location at all. Would be interesting to see if it would work tho |
#218 | |
Drives: 2013 FRS
Anyway, tested the BPB yesterday with both the Phantom and NA (full bolt on- OFH + Custom bat-back) set ups. With a tank full of 93oct. With the Phantom, it doesn't look like a good match. Lost power just about everywhere. It didn't look promising so I didn't bother with custom tuning with the BPBs. I will probably give it a try when more time permits though. But these results make sense as more airflow would suggest shortening the runners are the way to go. So then I removed the Phantom and tested just NA (with the OTS Stage 2 UEL map) and it picked up good power in the ~5000-6500rpm range. But lost about equal power above that. Same peak power (187whp). Still worthwhile to many people who would trade off top end power for a lower RPM power peak. So then I custom tuned the heck out of it to the point where it didn't loose much top end while still making the big gains between 5000-6500rpm. Peak power was the same but the area under the curve was much bigger. So definitely an improvement. The only reason I don't want to immortalize those results now by posting them is because I made some pretty aggressive tuning changes above 6500rpm to regain the lost power. So aggressive that I want to ensure that the mapping is stable down to 91oct. If so, I would consider this a fair test. If not, we would be comparing a conservative tune (without BPB) to an aggressive tune (with BPB). But I can say that the car drives great with the custom tune and the PBPs. Very noticeable gains without the need to rev it out all the way to 7500rpm. Just give me a couple of days to determine if the custom tune is something that is conservative enough to release to the public. For that, I need to burn off some 93oct, fill up with 91 and then put the car through the wringer. When time permits I'll do some testing on a totally stock vehicle with just the OFT and the BPB. That will be necessary in order to release Stage 1 to Stage 2 OTS maps for the BPB. I'll start a new thread (with complete dyno results) after the necessary road tested ![]() Cheers, shiv |
#219 | |
#220 | |
Drives: Toyota Gt86
#221 |
Fanboy
Drives: 2013 ultramarine frs
We need to get a nameless header in shiv's hands
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#222 |
Only if shiv doesn't mind waiting 6 months for it to arrive! LOL only kidding, would be interesting to see
#223 |
The Mechanic
Drives: Civic Turbo,FR-S
ill run the aggressive 93 tune
#224 | |
Drives: Subaru BRZ Limited
Will the bigger TB+ tune can get the optimize(better) result? Thanks. |
| Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 05:01 PM |
| Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 | ZetaVI | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 04-01-2014 05:19 PM |
| Squidbelly wants to know the best way to gut a manifold cat | regal | Engine, Exhaust, Transmission | 14 | 03-07-2014 10:31 AM |
| short blocks? | 350matt | Engine, Exhaust, Transmission | 4 | 11-04-2013 08:37 PM |
| Billet Oil Catch Can #BC-175 by Billet Custom | Tim_Asphalt_FRS | Engine, Exhaust, Transmission | 48 | 10-27-2013 02:29 PM |
