Old 04-02-2014, 05:53 PM   #71
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Originally Posted by omegared19 View Post
On track/auto-x days, I noticed about a 10 degree engine temp drop. I kept testing it, and it varies based on ambient temp, but cold foggy days, about a 8 degree drop. Hot, track days about a 11-13 degree drop
This is the same guy that I linked from page one of this thread. I think someone else linked on page 3 as well...
This thread makes me wonder what under hood pressure is normally at different speeds. Won't the airflow happen anyway regardless of a pressure drop over the fender? There will be a pressure drop considering the air at the front of the car is pressurizing the engine bay and it has no where else to escape so easily?
Regardless of all that stuff, the guy said he saw a temperature drop... not good enough?
EvilBeaverFace is offline   Reply With Quote
Old 04-02-2014, 06:54 PM   #72
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
so can someone enlighten me on where to cut the hole out behind the fender garnish? Do you just cut the whole damn thing out? I'd like to see a pic if anyone has done it. I know there are 6 small holes for the clips to go in, but those holes aren't big enough to let air out?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 04-02-2014, 08:22 PM   #73
Boxer486
Drives: small
Yes, someone cut the whole thing out pretty much.
Boxer486 is offline   Reply With Quote
Old 04-02-2014, 09:50 PM   #74
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Those 6 holes for the mounting clips is part of the fender. It will do no good to cut that area if the front upper frame rail/apron still blocks it.
Behind the fender is this.
Signifigantly cutting that is a HUGE no no stucturally. The existing holes are crush zones so that in an impact/wreck the force is transfered/dampened around and before the passenger. Also with out correct finishing you will be inviting rust into some major areas of the car. I do know the twins use HSS (high strength steel) in the roof supports and front structural areas. I don't remember if the upper rail is one of those areas though.
Old 04-03-2014, 10:51 PM   #75
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Yes, I used those holes to give me a guide on where to cut. Before adding the adhesive strip, I used the mesh as a guide as well to help me measure out how much to cut out.
As for pressure, let's be honest. Our cars have a top speed of 136 mph. If you figure out how to go 200mph, then you'll need to worry about it
omegared19 is offline   Reply With Quote
Old 04-04-2014, 02:29 AM   #76
BRZpower
136mph? i hit 143mph completely stock and average is 140mph not that 4-7mph is a big difference lol.
so can someone show a before an after where its cut?
BRZpower is offline   Reply With Quote
Old 04-04-2014, 02:33 AM   #77
BRZpower
i think with a vented hood this will surely cool the motor. air goes in thru the hood vents and out the side vents.
i see no problems with a bit of water in the engine bay. i already get my engine bay soaked every time it rains from the hood vents. just makes it a bit dirty. so u gotta clean it more often. if the water was a problem you could make covers for the engine bay side of the duct (for when its raining).
Old 04-04-2014, 02:20 PM   #78
omegared19
omegared19's Avatar
The Following User Says Thank You to omegared19 For This Useful Post:
mokinbird87 (04-04-2014)
Old 04-04-2014, 08:58 PM   #79
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
CAD starts today finally.
mokinbird87 is offline   Reply With Quote
Old 04-04-2014, 09:09 PM   #80
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Vented hoods draw air from the engine, not add air.
Old 04-05-2014, 05:28 AM   #81
Boxer486
Drives: small
He could be taking about something like a hood scoop or NACA duct. But yes, most vents are there to relieve pressure from under the hood and assist aero over the car if done right.
Old 04-13-2014, 02:08 AM   #82
mokinbird87
BOXER FR
updated!
Old 05-03-2014, 10:05 PM   #83
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by mokinbird87 View Post
updated!
Anything new?
Installed Mods:
Old 05-03-2014, 11:09 PM   #84
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
This picture made me cringe...
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZNutt For This Useful Post:
kodyo (05-03-2014), NWFRS (06-20-2015)
Vent Side Marker MaximaZero Cosmetic Modification (Interior/Exterior/Lighting) 28 02-23-2014 02:09 AM
BRZ Side Vent Trade woode NY / NJ / CT / PA 4 12-31-2013 11:01 AM
Side vent change Andrew_FRS_DD Cosmetic Modification (Interior/Exterior/Lighting) 1 07-12-2013 05:33 PM
frs side vent lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-02-2013 08:54 PM
Side Vent Swap? Allankh CANADA 0 12-19-2012 02:26 PM
