Old 04-03-2014, 05:29 PM   #57
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
why would you want to ruin the handling of a car thats known for its handling
*puts on flamesuit before the camber gang sees this
ProjectGT86 is offline   Reply With Quote
Old 04-03-2014, 05:37 PM   #58
ProjectGT86
Camber Bro
Old 04-03-2014, 06:06 PM   #59
wheelhaus
wheelhaus's Avatar
-2 to 3 degrees will help handling, not hurt it. We're not talking insane stance nation like the photo you posted.
Old 04-03-2014, 06:25 PM   #60
ProjectGT86
I may be wrong but i actually met the guy who owns the car that i posted, he said he had -3 camber
Old 04-03-2014, 06:27 PM   #61
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That looks like way more than -3, but its not my car. However, if doing tracking/autox/spirited driving camber helps the tire from rolling over on itself and -2 seems to be a happy point where treadwear isnt really hurt as long as your toe is sorted
Sent from my LT30at using Tapatalk
Old 04-03-2014, 06:37 PM   #62
ProjectGT86
I see what youre saying youre right, the camber allows a more even load on the tire when theres cornering force
Old 04-03-2014, 07:12 PM   #63
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
thats my car, when did we meet?
SLICVIC is offline   Reply With Quote
Old 04-03-2014, 07:33 PM   #64
ProjectGT86
We met in a meet in Brooklyn not like a formal greeting but I checked out your car, I used to live in NYC
Or was the meet in New Jersey? It must of been almost a year ago or even more
Old 04-03-2014, 11:10 PM   #65
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Flat road for at least a mile down, and where I did burnout before logging.
Sears alignment printouts (they don't print out exact numbers for these free alignment checks):
Stock + Camber bolts front and rear, little more than 3/4 tank of gas, no driver
My measurements before taking it to sears:
F Toe: 3/8" in R Toe: 1/8" in
FL: -1.8 FR: -2.0
RL: -0.8 RR: -1.3
Removed factory muffler and installed track pipe, zeroed front toe, little more than 1/4 tank of gas, 150lbs driver in seat, no other adjustments made
Got out of the car and remeasured after I saw the toe out.
@mike156 Let's see what numbers you got.
Old 04-05-2014, 06:56 PM   #66
mike156
Drives: EVO
I've got no numbers. I question yours simply because they seem all over the place with no real correlation to anything. Seems like error in the measurements and nothing more. What you are taking from your numbers sugget MASSIVE bumpsteer. Undrivable amounts...
That road has crown in it...most/all roads do so water drains off the side of the road.
Just a question though, did they not have a steering wheel lock on the car while doing the alignment? Because getting in the car with a typical lock on is going to be a bitch, if even possible.
mike156 is offline   Reply With Quote
Old 04-06-2014, 02:11 AM   #67
solidONE
solidONE's Avatar
No steering wheel lock. They place these attachments on the wheels, center the steering wheel and roll it forward in neutral until some indicators turn from red to green on the monitor.
Those were the numbers I measured myself, and they appear to match what sears measured on their machine. Doesnt seem likely that my measurement and sear's measurement were off by the same a mount and in the same way. I'd appreciate if someone else do these same measurements to confirm or deny.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Cheapest way to get more camber on stock suspension Snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-11-2014 08:45 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 04:45 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
