Old 04-03-2014, 02:44 PM   #603
NorCal_Guy
It's turbo time!
NorCal_Guy's Avatar
Drives: 2013 Scion FRS
Originally Posted by -Ozzy- View Post
Installed mine today. No fogging yet.
It's been 2 hours.
Attachment 72656
They will normally fog up under really cold conditions
NorCal_Guy is offline   Reply With Quote
Old 04-03-2014, 04:27 PM   #604
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
Originally Posted by R.K View Post
Do you have HID kit on? What color is it 5k or 6k? Looks really good.
Thanks. 5k.
beaver_scott is offline   Reply With Quote
Old 04-03-2014, 04:35 PM   #605
beaver_scott
I took a second shot of the stock winjet projector light cutoff with 5000k ddm hid kit and my switchbacks covered. I didn't realize how much light scatter the switchbacks showed on the garage door. Name:  ImageUploadedByTapatalk1396553720.509812.jpg
Size:  165.3 KBName:  ImageUploadedByTapatalk1396553730.776090.jpg
The Following User Says Thank You to beaver_scott For This Useful Post:
Rican_D (04-03-2014)
Old 04-03-2014, 05:29 PM   #606
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Originally Posted by Drifty86 View Post
Thank you
NP, obviously I read what you asked for
Rican_D is offline   Reply With Quote
Old 04-03-2014, 07:47 PM   #607
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by beaver_scott View Post
I took a second shot of the stock winjet projector light cutoff with 5000k ddm hid kit and my switchbacks covered. I didn't realize how much light scatter the switchbacks showed on the garage door. Attachment 72988Attachment 72989
The Z's should line up to make 1 Z not 2
Yours:
Z Z
Should be:
Z
also, mine came in today. look great. going to wait to retrofit.
@everyone asking about DDM, I had some horrible experience with them. Had them on my FJ for a while, but had one ballast intermittently not turning on. Always a PITA when you have to keep flipping your lights on and off again to get the light to turn on. RMAd the thing, new ballast, same issues.
I would suggest not cheaping out and going with something from the retrofit source. high quality stuff there.
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
tonystewart (04-03-2014)
Old 04-03-2014, 08:38 PM   #608
beaver_scott
Yours:
Z Z
Should be:
Z
Are you sure about that? Here is a shot of my stock headlights and factory aim has "Z Z" patternName:  ImageUploadedByTapatalk1396568282.655450.jpg
Old 04-03-2014, 09:49 PM   #609
86-tundra
Troll Hunter
86-tundra's Avatar
Are you sure about that? Here is a shot of my stock headlights and factory aim has "Z Z" patternAttachment 73023....
They might night have to align, but they should be much closer than yours IMO
Old 04-04-2014, 02:36 AM   #610
psybre
psybre's Avatar
This seemed like a pretty good walkthrough for how to aim your headlights: http://forums.clubrsx.com/showthread.php?t=464202
psybre is offline   Reply With Quote
Old 04-04-2014, 02:39 AM   #611
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Originally Posted by Gixxersixxerman View Post
I'll post up what we did here in the shop
Stock winjet bulb and projector
Stock winjet projector with upgraded Morimoto XB35 5K bulb
Retrofitted Mini D2S projector running upgraded Morimoto XB35 D2S bulb
As you can see the stock projector doesn't come close to a retrofitted one. These are cheap Q5R replicas or knockoffs, while better then a OEM projector in the cars, and a lot better once they have a hid kit installed in them, they just don't come close to a retrofitted set.. I'll put my retrofitted setup against the shops 10 Series stock HID setup and know mine is better. I have "tuned" my set up and I run 185$ Osram 66240 CBI bulbs.. And Bulbs make a big difference.. Anyone that says a cheap 30$ kit bulb is the same as a quality ORM bulb or even the XB35 bulbs with the handmade German capsules don't know anything.. If your wanting the most out of your lights, then doing a retrofit is the way to go..
Thanks Thomas -
86SPEED is offline   Reply With Quote
The Following User Says Thank You to 86SPEED For This Useful Post:
Brody602 (04-04-2014)
Old 04-04-2014, 03:28 AM   #612
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Yours:
Z Z
Should be:
Z
I'm sorry but I can't let bad information like this stay out there.. There should be two "Z" and they should be the same distance apart no matter how far away your car is from what ever they shine on.. So if your headlights are say 5 feet apart, those "Z" or steps should be 5 feet apart at 1 foot from a wall of 100 foot from a wall.. Or 1000 if your lights are good enough to form that cut off..
I agree with the rest of your statement, I used DDM also until I was I formed.. What's saw is if you know where to look you can buy the same kits for less then 20$ and if you buy in enough bulk like they do a couple bucks..
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
beaver_scott (04-04-2014)
Old 04-04-2014, 09:13 AM   #613
86-tundra
Troll Hunter
86-tundra's Avatar
Nope, they should line up much more than his original post does. In his post they are completely separate and from not far away. I was wrong in saying they should be on top of each other, I was thrown off by how his looked I guess I had forgotten what they should actually look like
Should look more like this
vs his
okay maybe I originally underestimated how close his car is to the garage door. It is a bit deceiving.
Old 04-04-2014, 11:57 AM   #614
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I've measured center to center of lights, used same distance at 25', per Andrew at TRS
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 04-04-2014, 12:44 PM   #615
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
Originally Posted by fteightysix View Post
This is True - The winjet projector is very good (Way better than OE) - When we got the first set and tested them there is a major light output difference with different HID Bulbs - I will let @Gixxersixxerman comment more -
We have tested about 5-6 different bulbs and found that some compare well while others compare above and beyond -
There is a major light output difference in all the Retrofits we have done also - I have watched Thomas "tune them" to get a good crisp light output
@Gixxersixxerman
Are the Winjet LED DRLs as bright as the 10 series or monogram ones?
ProjectGT86 is offline   Reply With Quote
Old 04-04-2014, 01:54 PM   #616
Gixxersixxerman
vs his
I see what your saying now.. There still should be two steps, tho in our case the left one should over lap the right one.. And I'm sure his come close once he backs up some, but the winjet projectors don't make that great of cutoffs to begin with.. They do slope down.. I read your statement as both of those steps should become one..
86-tundra (04-04-2014)
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 11:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 04:26 PM
Winjet headlights fogging up? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 23 05-17-2014 02:26 PM
Has anyone modified the winjet headlights to keep led's on? 86black Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 01:42 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 09:28 AM
