Old 12-27-2013, 06:55 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Winjet headlights fogging up?
Hey i just got my headlights installed and drove for an hour or so home and when i got home i noticed they had fog in them in the very front is this normal or are they defective?
Frs32907 is offline   Reply With Quote
Old 12-28-2013, 07:33 AM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I'd say that's defective.
slicktop is offline   Reply With Quote
Old 12-28-2013, 09:24 AM   #3
FRSLOW
Smells of Rich Mahogany
FRSLOW's Avatar
Drives: 2013 Firestorm FR-S
Yuuuup! Happened to mine as well.
FRSLOW is offline   Reply With Quote
Old 12-28-2013, 10:29 AM   #4
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
Made in China.
Perihelion is offline   Reply With Quote
Old 12-28-2013, 10:30 AM   #5
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Probably nothing baking and a little bit of rtv won't fix.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 12-28-2013, 12:22 PM   #6
Lonewolf
Lonewolf's Avatar
Drives: Moped
I think most folks are going to discover they you are going to have to seal these headlights before installing them to avoid fogging...the price we pay for cheaper made in China stuff...
Old 12-28-2013, 02:15 PM   #7
Frs32907
Talked with chris from phastrack and he said they should burn off after a few days of use so hopefully that works
Old 12-28-2013, 03:20 PM   #8
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Why not post a pic?
Ryan86 is offline   Reply With Quote
Old 12-28-2013, 03:37 PM   #9
HakunaMiata
HakunaMiata's Avatar
Drives: Scion FR-S
Same happened to mine, it just takes a day or two and it will be gone. Haven't had any issues since
HakunaMiata is offline   Reply With Quote
Old 12-28-2013, 03:43 PM   #10
HakunaMiata
Drives: Scion FR-S
It's cause you took the headlights out in the cold dry air and there was humid air still inside them. It will evaporate.
Old 12-28-2013, 04:21 PM   #11
suaveflooder
I have ALWAYS sealed (usually with RTV) aftermarket headlights on all my cars. Seems that only OEM avoids the fog.
suaveflooder is offline   Reply With Quote
Old 02-17-2014, 08:30 AM   #12
Ongor
Drives: 2013 Scion FR-S, Hot Lava
Any news on this? I just got mine installed and they fogged up instantly (in montreal at -17C.. ) Problem is that in this weather, the moisture just freezes after i turn off the lights, so it doesn't leave time for it to evaporate...
Ongor is offline   Reply With Quote
Old 02-17-2014, 09:26 AM   #13
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
this is what i would expect from $400 subpar fakie cheap headlights
OEM or nothing.
GT86drifter is offline   Reply With Quote
Old 02-17-2014, 10:04 AM   #14
Ongor
thanks for the valuable response, i shall fix my headlights with OEM might! (sarcasm off)
I just want to fix these, cuz they look much more sexy than OEM, the light better than OEM, and if the moisture is fixed, they seem to be of good enough quality
Winjet Headlights (Post Your Pics) ecko04 Cosmetic Modification (Interior/Exterior/Lighting) 265 03-20-2021 08:53 AM
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 03:26 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
Norcal GB: Winjet JDM Style Headlights 86_ZN6 Northern California 2 12-11-2013 03:31 PM
