| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#43 |
Drives: DGM brz
yea, you should have no problem with rubbing. i am on 18.9.5 et35 and 265/35s and i only rub on extreme hard corning. also my car sits rather low. you have something else going on there bud.
| The Following User Says Thank You to shultz2 For This Useful Post: | JonnyJames (12-22-2013) |
#44 | |
Drives: 2013 Whiteout FR-S
All suspension I stock FYI |
#45 |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
the offset of +45 is the issue here, as it probably rubs on the struits/inner fender. Get some spacers (5mm should be enough) and the issue should be solved
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | JonnyJames (12-22-2013) |
#47 |
You're welcome. Make sure however that you check how spacers in front will affect handling. You may want to get some spacers in the same size for rear aswell, so both rear and front axle are again "in line" (dont know a better word for it in english, sorry).
#48 |
Drives: Scion FR S
Now there are some decent pictures of the Enkei Wheels. Finally some one that can afford the wheels and a camera.
| The Following User Says Thank You to nethater For This Useful Post: | ngabdala (06-22-2014) |
#49 |
Drives: 2013 Subaru BRZ Limited (WRB)
Thinking of pulling the trigger on these in black, with Hankook V12's.
Is a 245mm tire too wide for the 18x8.5? Does anyone have this setup? I want to avoid any kind of stretch, and it seems like the 235's stretch a little. Also, with stock suspension, I've heard it's not a good idea to stagger the rear. Any opinions on this?
#50 | |
| The Following User Says Thank You to CSG David For This Useful Post: | PMok (04-04-2014) |
#51 |
Codename: Stitch
Pretty sure I shared these pics before but since this is the "official" wheel directory thread here they are again.
![]() ![]() Enkei Raijin wheels, 18×8.5 +45 (symmetrical) + center caps from Enkei Kojin wheels Federal 595 RS-R tires, 225/40ZR-18 Muteki black lug nuts Eibach Pro-Kit lowering springs (I am told the RS-Rs in 225 width are equivalent to around 245 of "normal" tires) ![]()
| The Following 3 Users Say Thank You to PMok For This Useful Post: |
#52 |
Drives: 2003 FR-S
Hi guys,
My Rijan wheels already ordered, now I am still waiting from the wheel shop to notify the arrival date (hopefully next week). Before installing those wheels, do you guys know whether I can use the OEM nuts for the new wheels? I am still shopping the wheel nuts (cannot decide the color and brand at this moment). Thanks. |
| The Following User Says Thank You to Gps360 For This Useful Post: | AZOOZ_95 (05-27-2014) |
#54 | |
That One Guy
Drives: White 2017 BRZ
"I am not bound to win, but I am bound to be true."
#55 |
Codename: Stitch
Nope no rubbing for me... but I think that will be somewhat dependent on what width tire you run, and how much negative camber you have.
#56 |
Drives: White BRZ
With this size wheel and say 245/35 tyres all round will there be any rubbing on the guards?will lower with coil overs to.
| Wheel Directory: Enkei RSF5 18x8.0 +45 | ericmpena | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 85 | 06-18-2022 04:07 PM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
| Wheel Directory: Enkei RS05RR 18x8.5 +42 | dabocx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 206 | 03-02-2018 05:23 AM |
| Wheel Directory: Enkei NT03+M 18x8.0 +35 | Tunz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 45 | 06-16-2016 11:31 PM |
| Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 | Sciby | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 11-10-2014 12:53 AM |
