Old 04-02-2014, 12:51 AM   #71
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by FrsDuke View Post
Take off the heat shields yet?
Yeah I did.
Ima call it a night and give it one more try tomorrow.
I had the car lifted only from the front.
Maybe lifting the car both sides should give me a little more clearance?
How high did you guys set your jack stands for the clearance?
Carlitoz3 is offline   Reply With Quote
Old 04-02-2014, 06:56 AM   #72
FR-S Matt
Originally Posted by Carlitoz3 View Post
Yeah I did.
Sounds like you aren't lifting the motor in the right spot or something. When you loosen the passenger side bolt, the engine should be able to be jacked up a few inches which lets the pipe slide in with ease. Someone should make a video of this as this is the hardest step with their exhaust for both install and removal.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Carlitoz3 (04-02-2014)
Old 04-02-2014, 09:06 AM   #73
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Yeah I did.
I used a lift
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 04-02-2014, 08:04 PM   #74
Carlitoz3
Carlitoz3's Avatar
With ease??
Wish you were my neighbor so you could show me.
I actually unscrewed both engine bolts so I could lift it a little more.
Probably wasn't a good idea:
Everything went back into place after I lowered the engine though.
Old 04-02-2014, 09:11 PM   #75
xjohnx
Grip>Slip
xjohnx's Avatar
With ease??
actually i do recall having to put the back half of the car on jack stands too, so that the rear end of the exhaust pipe could get enough of an angle to squeeze through. Give that a try.
Old 04-02-2014, 10:14 PM   #76
Carlitoz3
Carlitoz3's Avatar
How high did set up your jack stands?
As of right now that's my only hope.
Old 04-02-2014, 10:16 PM   #77
xjohnx
Grip>Slip
xjohnx's Avatar
i don't recall, probably only 1 or 2 clicks, but i'm sure that will vary depending on the jack stand.
Old 04-03-2014, 07:02 PM   #78
Carlitoz3
Carlitoz3's Avatar
Great news, I lifted the back and the pipe slipped right in!
I bolted everything on, turned the car on, but now it's making a *clicking* sound.
It goes away after the car is warmed up.
I re tightened everything, but no luck
Posted up a video so you guys can hear it:
Frs: [ame]http://youtu.be/xoNSVgxRq2U[/ame]
My only guess would be the top of the over pipe is hitting the bottom of the engine.
What do you guys think?
Old 04-03-2014, 07:22 PM   #79
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Frs:
What are you torquing everything to? Had a similar noise when I installed my header until I went in and tightened to about 50% over factory torque spec.
Decay107 is offline   Reply With Quote
Old 04-03-2014, 07:38 PM   #80
Carlitoz3
Carlitoz3's Avatar
Wasn't using a torque wrench so honestly I don't know.
After the car was warmed up, I turned off the car and re tightend everything.
I'll try it again, I just don't want to f up the nut.
Old 04-04-2014, 11:08 PM   #81
Carlitoz3
Carlitoz3's Avatar
Two quickies:
1. The two circle gaskets that came with the overpipe; One goes between the header and the othe other goes between the midpipe correct?
2. I got new oem gaskets for my headers for this instal. Did it matter what side they were facing when I put them on? They look identically the same from both sides.
Old 07-23-2014, 05:59 AM   #82
blubaru
14.7 to 1
blubaru's Avatar
Drives: Galaxy Blue Silica BRZ Limited MT
One is a 2.5 inch front gasket and the other is a 3 inch front gasket. In case you have a different header. The rear end of the overpipe has a donut gasket. It doesn't mater what direction the front gasket faces. Hope this helps
blubaru is offline   Reply With Quote
Old 07-23-2014, 12:07 PM   #83
Ryan@Nameless
Ryan@Nameless's Avatar
Drives: 2014 SWP BRZ Limited
Since this thread got bumped, we ended up with a couple of extra 3" OP/DP in stock with helmholtz resonators.
-Ryan @ Nameless
Ryan@Nameless is offline   Reply With Quote
Nameless Performance Overpipe/Downpipe Combo Jason@Nameless Engine, Exhaust, Transmission 277 04-04-2018 12:37 AM
3" Perrin Resonated Cat-back w/ 3" Nameless Catted Downpipe Kevstra Engine, Exhaust, Transmission 28 05-20-2016 08:38 PM
Resonated or Unresonated on Nameless Overpipe/downpipe ?? ScionFR-S Engine, Exhaust, Transmission 9 12-11-2013 05:04 PM
WTB: Nameless Frontpipe/overpipe + Helmholtz combo LeeMaster Engine, Exhaust, Bolt-Ons 4 04-11-2013 04:42 AM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
