Old 04-01-2014, 06:13 PM   #4089
fenton
Originally Posted by nlowell View Post
Installed the stage 2 UEL tune and kept the ESC turned off (instead of removing the foot switch). Still something going on before 4k RPM - after that looks good. I think this confirms something is going on besides the ESC from 2-4k RPM. I'm taking it to get it looked at tomorrow on a lift to see if an expert can find a leak. Hopefully it's just something simple...
On another note...car feels like a dog! I think I got used to the ESC
Here is what shiv's log looks like with dual dump and tq250.
http://www.datazap.me/u/shivvishnu/t...8-2531&mark=26
fenton is offline   Reply With Quote
Old 04-01-2014, 07:35 PM   #4090
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Originally Posted by fenton View Post
I would be carefull hitting full boost with the ESC on. It is running very lean and the logs that shiv has posted of his FRS do not show that same lean event.
Email shiv directly and ask him about it if you havent already.
Emailed Shiv - they thought it may be an exhaust leak around the 02 sensor but I had a professional check that out today on a lift and found no leaks. I re-flashed the ECU and will test again. I'm thinking that it had to do with me modifying my snorkel and allowing more intake airflow. I'm guessing here, but maybe the ECU needed more time to "learn" with the new change. I'm hoping that re-flashing will expedite this. I'll do some careful 2nd gear logs today on my way home from work to see what it shows now.
nlowell is offline   Reply With Quote
The Following User Says Thank You to nlowell For This Useful Post:
DAEMANO (04-01-2014)
Old 04-01-2014, 11:14 PM   #4091
nlowell
nlowell's Avatar
I re-flashed and did another run on the way home - by the time I saw the AFR spike I let off the gas but was already past the lean section - won't be doing that again anytime soon (at least not until I get a new tune).
http://www.datazap.me/u/nlowell/91-t...zoom=2072-2151
I then ran a pull starting at 4k RPM and damn did that feel strong. AFR looks good as well. I guess until I get a new tune I'll have to keep my foot light below 4k RPM which should be hard at the track Saturday since I usually stay in the 5-7k range the whole time.
Old 04-01-2014, 11:57 PM   #4092
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Did you change anything else? I couldn't imagine the snorkel changing things this drastically. What did you remove to mod the snorkel?
Installed Mods:
Old 04-02-2014, 12:17 AM   #4093
nlowell
nlowell's Avatar
Removed the front bumper, removed the snorkel, cut the snorkel, reinstalled snorkel and bumper, removed air filter to check if it was clean, reinstalled.
Maybe I somehow pissed my crickets off...anyone know what crickets like?
Old 04-02-2014, 12:18 AM   #4094
Sojhinn
Sojhinn's Avatar
Ooh. Check your seating on your filter box.
Installed Mods:
Old 04-02-2014, 10:27 AM   #4095
nlowell
nlowell's Avatar
I just ordered a clean and oil kit for the K&N filter. I'll clean and check it tomorrow when it comes in.
The ESC does push on the filter box more than I'd like but it doesn't look like it causes much mis-alignment. Was your install very tight against the air-box?
Old 04-02-2014, 10:49 AM   #4096
Jac
Drives: Fiat Abarth
Smile
I'll soon be joining the ESC club, delivery estimate is Friday!
Any advice/gotchas before I install from existing owners? Rob recommended i use it daily for a full week before hitting the dyno to let the batteries break-in.
Jac is offline   Reply With Quote
The Following 2 Users Say Thank You to Jac For This Useful Post:
fenton (04-02-2014), Robftss (04-03-2014)
Old 04-02-2014, 11:09 AM   #4097
Sojhinn
Sojhinn's Avatar
I know that the bottom two clips on my box are a pain in the ass. I usually remove the front portion of the air box and attach the rear. Then I clip that to the esc and install.
Installed Mods:
Old 04-02-2014, 11:16 AM   #4098
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Congrats.
Install the compressor and tubing loose (don't tighten the clamps) until it's all in place. Keep the joints tight as you tighten the hose clamps about 80%. After it's all clamped, go back and do a final tighten on the hose clamps.
Get your tune installed as soon as possible, then drive the snot out of it. The boost will overwhelm the traction control, so turn it off,
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
Gums (04-02-2014)
Old 04-02-2014, 02:16 PM   #4099
nlowell
nlowell's Avatar
Congrats! Make sure to test the batteries before you install them as I remember one person receiving a dud. If you have any questions or issues during the install, don't hesitate to ask!
Gums (04-02-2014)
Old 04-02-2014, 03:15 PM   #4100
fenton
What tune are you running it with. The battery break in is important for peak performance.
Other than that, just take your time running the wires into the cabin as someone forgot to tie some down and they melted. Use the ty wraps and looming that Rob provides with the kit.
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (04-02-2014), Gums (04-02-2014)
Old 04-02-2014, 03:30 PM   #4101
nlowell
nlowell's Avatar
Good point, I bought extra loom to protect more of the wires.
Also, I started running the foot switch from the passenger foot well. It would have been much easier starting from the drivers side since the connector is smaller and easier to feed under the radio.
Gums (04-02-2014)
Old 04-02-2014, 04:19 PM   #4102
DAEMANO
Time Traveller
Yes, that someone was me. Make sure there is as little slack as possible in the wires running through the firewall to the WOT and Arm switch. The loom will offer little protection to the wires if they come in contact with the overpipe. Upon reinstall I am shielding that section of wire with something that won't ever melt + insulation to prevent heat transfer if it does and hose clamping the whole section away from any possible contact.
Nothing else I can think of that hasn't been mentioned. Enjoy it. You'll never believe such a changes could be so dead simple.
The Following User Says Thank You to DAEMANO For This Useful Post:
Gums (04-02-2014)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
