Old 04-01-2014, 06:40 PM   #1
BuhhDill
Drives: 2014 Scion FR-S
STS REAR TURBO KIT
I stumbled across this kit on youtube and thought that it was a win across the board.
No extra engine bay heat
No boost lag
Decent price ect.
Im wondering if anyone has seen these kits on a car?
Below is the youtube video link I saw
[ame="http://www.youtube.com/watch?v=fywtKeDXCRM"]STS Turbo 2013 Subaru BRZ - YouTube[/ame]
BuhhDill is offline   Reply With Quote
Old 04-01-2014, 06:41 PM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Its been mentioned before. I don't know of anyone who has bought the kit. Its pretty pricey. "Pending CARB" so they say.
Old 04-01-2014, 06:42 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by BuhhDill View Post
No boost lag
Also @Cross has that kit:
http://www.ft86club.com/forums/showthread.php?t=58591
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Cross (04-01-2014), dabocx (06-30-2014), ZionsWrath (04-07-2014)
Old 04-01-2014, 06:45 PM   #4
Cross
It's the Mad Cow
Cross's Avatar
Boost kicks in about 2800-3000 depends plus I am on really low boost so when I turn it up I will be able to better answer this. I was hoping to do so today but I am waiting to hear from Bill....
Old 04-01-2014, 06:47 PM   #5
gramicci101
Off Topic
How do you have no boost lag when the turbo is that far away from the engine?
Old 04-01-2014, 06:48 PM   #6
Cross
It's the Mad Cow
Cross's Avatar
Pipe size basically.
The Following 2 Users Say Thank You to Cross For This Useful Post:
gramicci101 (04-01-2014), suaveflooder (06-30-2014)
Old 04-01-2014, 07:06 PM   #7
BuhhDill
have you owned other turbo cars prior to this one? how would you compare it? noticable difference with the rear mounted turbo?
Old 04-01-2014, 07:09 PM   #8
Cross
It's the Mad Cow
Cross's Avatar
Turbo MR2's and I have been in a STS Trans AM that was converted to a Front Mount. There was a 500-600rpm spool difference between them but they were also not the same size turbo the front mount was bigger I believe... I would have to check though.
It is hard for me to say as I am on the base tune no revisions due to not being able to get a hold of Bill. I am also only on 4psi for the same reason i want to be safe... but I will say its quite fun.
I do like the oil-less turbo setup.
Old 04-01-2014, 07:16 PM   #9
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
id love to see boost logs !
Old 04-01-2014, 07:17 PM   #10
jshadeck
jshadeck's Avatar
Consider the piping on a fmic, including the pressure drop cause by the fmic itself, all the bends, etc. then consider a pipe the length of the car (almost) and no IC. The heat would be my bug draw to this, everyone seems to be having big issues with heat/turbos on this car.
jshadeck is offline   Reply With Quote
Old 04-01-2014, 07:27 PM   #11
Cross
It's the Mad Cow
Cross's Avatar
I will work on that for my thread.
Jcl (07-01-2014), SmsAlSuwaidi (04-01-2014)
Old 04-01-2014, 07:28 PM   #12
BuhhDill
Very interested in seeing how this set up performs after a tune. Thanks for the info
Old 04-06-2014, 11:52 PM   #13
Fuco
Italian Stallion
Fuco's Avatar
Drives: Scion FR-S
I just had mine installed about two weeks ago. First FRS/BRZ to get one besides the prototype. I love it. Sounds like a jet engine and it can get up to 80 in a couple seconds. It can go up to 12 psi, but I have it set to 8 psi right now.
There is one problem. The engine stalls out occasionally when I'm going about 5 m.ph., I'm not giving it any gas, and it doesn't stall out at 5 psi. Currently the shop that installed it and STS are trying to figure out what's going on.
Fuco is offline   Reply With Quote
Old 04-07-2014, 02:18 AM   #14
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Did you modify the fuel system?
Build Thread
Instagram
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
FRS Rear Turbo Roadstercycle Forced Induction 176 06-18-2015 06:13 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
