Old 04-01-2014, 08:00 AM   #2283
Aaron.H
Aaron.H's Avatar
Drives: 2014 Whiteout FR-S
Hi all
Hope you can chime in.
I bought 17x8.25 XXR 527's
Was wondering if the stock Michelin tire would work (215/45/17)
Think it would be a tiny stretch but want couple second opinion
What size bigger would work? 225/45/17 or 245/40/17?
Car is currently stock height and not tracked
Aaron.H is offline   Reply With Quote
Old 04-01-2014, 08:58 AM   #2284
jourdanc
Drives: Toyota 86 GTS
Hi everyone,
Looking to keep the stock tyres (Michellin Primacy HP in 215/45/17) and keep the stock height.
Is this wheel size ideal?
17x7.0 +38
Any point in have different sizes between the front and rear wheels?
Cheers, everyone!
jourdanc is offline   Reply With Quote
Old 04-01-2014, 03:53 PM   #2285
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by jourdanc View Post
Hi everyone,
17x7.0 +38
Cheers, everyone!
Ideal for what? That size wheel will fit and will be like adding 10mm spacers to your stock wheels. The stock rims are 17x7 et48.
Unless you are trying to go really fast in a straight line, or prefer the looks that wider rear wheels can give you - I would stick to same front and rear, makes it easy to rotate tires.
djdnz is offline   Reply With Quote
Old 04-01-2014, 05:08 PM   #2286
jourdanc
Hi mate,
Thanks for getting back to me. You've made a very good point about keeping the front/rear wheels standard for tyre rotation, I hadn't considered that before.
I just wanted to make sure that they would fit the stock tyres, wouldn't stick out past the arches and wouldn't need additional spacers, etc.
Old 04-14-2014, 12:03 PM   #2287
Gps360
Drives: 2003 FR-S
My Enkei Rijan wheels will be arriving very soon. The wheel shop only sells the ugly chrome nuts which I don't like.
A few questions before I go to pickup the wheels. First, can I use my existing OEM ones for the new wheels (just temporary)? Second, do I need the cone or ball seat for the Enkei wheels?
I know the nut size is 12 x 1.25 mm. Should I pick the open end or close end nut type? Any differences?
Gps360 is offline   Reply With Quote
Old 04-14-2014, 12:10 PM   #2288
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Find your local performance shop and get a set of tuner lugnuts, open or closed is your preference but I prefer closed as the stud is not exposed to the elements. Cone seat for most all aftermarket wheels.
You won't be able to use the stock lugs.
Gorilla makes a great cost-friendly tuner lugnut, McGard are more expensive and have the washer-type seat. I've used both.
My favorite are the spline-drive type.
Like these:
http://www.summitracing.com/int/part...83bc/overview/
or
http://www.mcgard.com/index.php/auto...drive-lug-nuts
Slick is offline   Reply With Quote
Old 04-14-2014, 12:29 PM   #2289
Gps360
Drives: 2003 FR-S
Like these:
or
Just curious, why the OEM nuts are not usable? They are cone seat as well.
Old 04-14-2014, 12:40 PM   #2290
Slick
Slick's Avatar
The "hole" in the wheel is not wide enough in many aftermarket wheels. Once you put a socket over the OEM lugnut, it will either just barely fit and the socket will scratch your wheels, or not fit at all.
You're talking about $40 for a full set of Gorilla spline-drive lugnuts with a special key so that your wheels can't be stolen using a regular socket. Money well spent if you're investing in aftermarket wheels.
Lots of performance shops in Markham should have them in stock.
The Following User Says Thank You to Slick For This Useful Post:
Gps360 (04-14-2014)
Old 04-14-2014, 12:46 PM   #2291
Gps360
Drives: 2003 FR-S
Oh no no no, I am not being cheap out. I just want to know why the OEM wheel nuts do not fit (You just explained to me).
Regarding the tuner nuts, I know most of them will have the paint chips problems.
I really cannot find a store in Markham selling those Gorilla spline-drive lugnuts. Most of them are selling the Muteki and etc. (the fancy ones).
Old 04-14-2014, 12:52 PM   #2292
Slick
Slick's Avatar
Go see Tirecraft (Automotive Import Market) in Markham.
I bought wheels from Phil (the owner) eons ago, good guy, knows his stuff.
495 Denison St, Markham.
[ame="https://www.youtube.com/watch?v=Cm5eKqmQpNo"]Automotive Import Market - (905)477-1771 - YouTube[/ame]
Old 04-14-2014, 01:15 PM   #2293
dunnr
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
fitment tool:
http://www.rimsntires.com/specspro.j...r%20H2%20wheel
dunnr is offline   Reply With Quote
Old 04-14-2014, 02:38 PM   #2294
Gps360
Drives: 2003 FR-S
Oh, this shop. I just remember it now and the store owner. I was a customer when I was still a teenager there.
Thanks a lot, I will try calling this shop
Old 04-14-2014, 02:44 PM   #2295
Slick
Slick's Avatar
Haha, you are probably still younger than I. Iirc, it was about 25 years ago when I first visited his shop. Phil grabbed a set of rare Riken's he had at the time and brought them out to my AE86 to test fit them.
Good luck!
Old 04-14-2014, 03:04 PM   #2296
Gps360
Drives: 2003 FR-S
Good luck!
No age disclosure in this forum please
I was there buying snow tire package but not much choice at the first time. Steel rims were the cheapest package and wheel covers were free of charge. It was a very good deal for a poor student like me at that time.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
