Old 03-28-2014, 11:08 PM   #659
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Tunes are calibrated for specific map sensors. The one that comes with the kit is fine, it's just that their revised tune was made around their map sensor (the red one). Get the wrong map sensor for the tune you have and the car won't even idle, just like what happened with my car when my map sensor failed.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 03-29-2014, 12:48 AM   #660
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Any tuning shop here in Deep South TX can install and tune this kit? Thanks in advance.
zoth is offline   Reply With Quote
Old 03-29-2014, 02:15 AM   #661
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Whats the difference with this map sensor? I may have missed it but what makes you need this map sensor over the one they sent.
sent from your mom
The paperwork that came with it described it as "MAP Sensor, Hondata, 4 Bar K S". Not sure what the Denso MAP Sensor that came with my original kit is spec'd at.
mit_peid is offline   Reply With Quote
Old 03-29-2014, 03:35 AM   #662
CSG Mike
CSG Mike's Avatar
This made me LOL...
Old 03-31-2014, 04:53 AM   #663
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Koyorad with KW kit?
I just wanted to see if any of you used this radiator with the KW and/or ran into any fitment issues, I am about the pull the trigger on the radiator before ordering my KW kit and wanted to hear your opinions
glamcem is offline   Reply With Quote
Old 03-31-2014, 05:00 AM   #664
sw20kosh
Drives: 2013 Black FR-S
This made me LOL...
I don't get it.
Old 03-31-2014, 03:16 PM   #665
captain_jack
captain_jack's Avatar
I'm wondering the same thing, that's my next upgrade as is the oil cooler
may the schwartz be with you....
Old 03-31-2014, 05:04 PM   #666
glamcem
glamcem's Avatar
I will probably upgrade the oil cooler and radiator before the kit, so it will be ready to use for track ..once I install them I will report back
Old 03-31-2014, 09:05 PM   #667
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I though people were getting adequate cooling out of the stock radiator. Oil is an issue but water was fine.
digital_assassin is offline   Reply With Quote
Old 03-31-2014, 09:46 PM   #668
captain_jack
Well being in AZ im not sure that it is adequate in rush hour traffic when its 115 outside..... Thats why i plan on upgrading mine.
sent from your mom
Old 04-01-2014, 02:27 AM   #669
digital_assassin
I tend to forget how hot it was living in the furnace. Man I don't miss that place at all. Except for a few restaurants like Aunt Chiladas, Papa Deux, Fajitas, and the AZ staple (Insert name)bertos. Other than that the heat just kills me now every time we go back to visit family which for whatever reason always seems to be in the middle of the summer.
Old 04-01-2014, 02:30 AM   #670
CSG David
CSG David's Avatar
These guys are professional racecar drivers. Get with the program man hahaha.
Old 04-01-2014, 03:45 AM   #671
glamcem
glamcem's Avatar
well...
http://www.ft86club.com/forums/showp...51&postcount=1
The radiator we chose was an OTS Koyo unit designed to be plug and play for the FR-S it is about 3x the thickness of the factory radiator. One of the main reasons for this addition was that we were very unhappy with factory cooling in even the stock car during idle situations. And when we did our first autox and dyno the car seemed to have temp spikes after hard runs which caused surges of 217-220F. The factory setting of the radiator fans is set for 212F before they kick on. Often the temps would surge well beyond that before the fans dropped the temps. Clearly this is bad if you are going to run any type of forced induction. The Koyo unit may not be the highest quality to meet cooling snob requirements however the surface area and core are much larger than OEM for a very reasonable cost which means, the radiator will cooler quicker and won’t heat soak as fast.
Old 04-01-2014, 12:53 PM   #672
CSG David
CSG David's Avatar
Are you logging temps to validate your concerns? If it is necessary for your application, then pick up a radiator.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
