Old 03-31-2014, 06:20 PM   #4159
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Calum View Post
On what fuel are you expecting to make those numbers?
Are there any details on the exhaust?
They are on E85. They expect 300 on E85.
The Following User Says Thank You to sw20kosh For This Useful Post:
Calum (03-31-2014)
Old 03-31-2014, 06:25 PM   #4160
Calum
That Guy
Drives: 2013 asphalt FRS MT
Damn. I was getting my hopes up for a second there.
Old 03-31-2014, 06:33 PM   #4161
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Maybe with the addition of a turbo on top!
Exhaust is a single 2.5" cat back. Weighs 12lb in the front, rear section switches from al to SS with a single clamp. Al 3.5 lbs for auto-x, SS for street @ 9lb. Quiet in comparison. I've been DDing this setup for over 10k miles including all salty winter. It won't be cheap, so just for folks concerned about weight.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Calum (03-31-2014)
Old 03-31-2014, 09:23 PM   #4162
DriftEm
DriftEm's Avatar
Originally Posted by xjohnx View Post
Not a fan of the Perrin? I've been considering giving it a try. It sounded great on @DriftEm's video. Wonder if he noticed any power gains.
I installed the perrin at same time as IC and 70mm pulley, so I can't really say if it made a difference, but it sounds good
DriftEm is offline   Reply With Quote
Old 03-31-2014, 09:26 PM   #4163
DriftEm
DriftEm's Avatar
ok guys, here is a comparison between a stock air box and perrin CAI.
[ame]http://youtu.be/LZMC_LvMoEA[/ame]
The Following 3 Users Say Thank You to DriftEm For This Useful Post:
Area86 (03-31-2014), Lawnik (03-31-2014), whataboutbob (03-31-2014)
Old 03-31-2014, 09:28 PM   #4164
whataboutbob
AutoX-10/10ths every run
Wow, that was a nice looking red FR-S in that video.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
DriftEm (03-31-2014)
Old 03-31-2014, 09:28 PM   #4165
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
I have a perrin intake (2.5in) on mine. Not sure if it adds any power but it definitely does enhance the whine
Sent from Samsung Galaxy Note 3
Area86 is offline   Reply With Quote
Old 03-31-2014, 09:33 PM   #4166
DriftEm
DriftEm's Avatar
Yeah, and the Red FR-S race line looked better too I need to get a ride with you to learn the race line
The Following User Says Thank You to DriftEm For This Useful Post:
Old 03-31-2014, 09:34 PM   #4167
xjohnx
Grip>Slip
xjohnx's Avatar
@DriftEm - are you on the 2.5 or 3?
Old 03-31-2014, 10:08 PM   #4168
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by moto-mike View Post
Not trying to dodge it, but we just haven't had the time to take it off the car and make the fixture. For locals I can just do it right on the car so it isn't a big deal, but I'd hate to send one out and have it not fit. Once we have the car back on the dyno now that we have the mapping squared away with that MAP issue, it should hopefully break 300 proper (though I'd be content with the 285 we did last year on e85) and then we will tear down the intake and exhaust and make fixtures for everything. This winter absolutely kicked our butts with the cold.
Makes sense. I figured there was a reason, thats as good as any. Just curious on how it looks, because if its something I like i'd take the drive if I had to in order to get it haha.
xxscaxx is offline   Reply With Quote
Old 03-31-2014, 10:11 PM   #4169
DriftEm
DriftEm's Avatar
2.5"
Old 04-01-2014, 11:51 AM   #4170
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Kodename47 View Post
@moto-mike just for you.....
Wire type IAT sensor and MAP sat in the manifold. The manifold had to be modified (drilled) to allow the sensor to fit.
Was this the IAT sensor you used?
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Old 04-01-2014, 03:45 PM   #4171
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Is anyone here using the fa20club intercooler? I know the tank and the heat exchanger are different but how is the quality if the brackets tubes etc?
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 04-01-2014, 03:46 PM   #4172
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
They are shit quality. I returned mine and got the innovate intercooler instead. If you want a heavy ass heat exchanger that only mounts to the bottom plastic part of the bumper, has jacked up fittings that won't seal properly, cheap hoses, and pump wiring harnesses that are too short, feel free to purchase it....let's not forget that you will get each piece separately over the course of 2-3 months, as I did.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
calispec (04-01-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
