Old 03-27-2014, 05:04 PM   #2269
jshadeck
jshadeck's Avatar
Originally Posted by tiz22 View Post
I'm thinking of the Brembo BBK down the line...Will that fit in a 17" wheel?
If I go with 18"s and find the ride quality more rough...Are there any suspension upgrades I can do to improve it? I've heard so many different opinions on coilovers
Im not sure about brembo bbk fitment, remember backspacing also applies with bbks
Good coilovers should be adjustable to give you ride quality to a point, and then stiffer for track days, maybe someone w more coilover experience can chime in however..
jshadeck is offline   Reply With Quote
Old 03-27-2014, 07:59 PM   #2270
rome_brz
Drives: Subaru BRZ
Hey wheel aficionados!
I'm close to placing an order for TWS T66-F in the following fitment:
F: 18 x 8.5 +42
R: 18 x 9.0 +44
OR
18 x 9.0 +44 all around
What I wanted to know is will both these options fit with stock suspension? I do eventually plan on upgrading to coilovers but not sure how far down the line this will be.
rome_brz is offline   Reply With Quote
Old 03-28-2014, 11:06 AM   #2271
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
As with any adjustable suspension you have a shitton of options to 'tune' the suspension, and the only way to truely know what is going to happen is to go out with tools and find a bumpy road and feel the changes. I have good knowledge of suspension on other types of chassis.
Preload, compression, rebound, etc will all affect ride. You can undo all the preload for more spring in the suspension, and soften the compression and the rebound to make the car literally bounce when it hits a bump. Likewise you can stiffen all that and make the car a rock. You can do everything in between.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 03-30-2014, 04:12 AM   #2272
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
will this fit ? 18 X 8.5, 55 OFFSET, 5X114 LUG PATTERN
ucsmfu is offline   Reply With Quote
Old 03-30-2014, 04:35 AM   #2273
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Rule of Thumb: Add 4" to the rotor size to find the required wheel size for a given BBK.
That's a general guideline; it certainly doesn't mean that every wheel of that size will work. BBK manufacturers provide templates to help with this. More here: http://www.stoptech.com/technical-su...ment-templates.
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
tiz22 (03-30-2014)
Old 03-30-2014, 05:56 PM   #2274
MObrz5
Drives: 2014 Satin White Pearl BRZ
So I finally ordered my SSRs in 18x9.5 +43 squared...but I just realized they put it down for the Super Low Disc. Will the super low disc cause any fitment issues? I dont know if this matters but ill be on no more than a 1.5" drop on coilovers. Hopefully someone can chime in asap so I can call to see if I could change it tomorrow! Thanks
MObrz5 is offline   Reply With Quote
Old 03-30-2014, 06:46 PM   #2275
djdnz
1337
Drives: 2013 BRZ WRB S/C
Not without adapaters, stock bolt pattern is 5x100. You would need 5x114 to 5x100 adapters.
If possible I'd stick to wheels that come in 5x100.
djdnz is offline   Reply With Quote
Old 03-30-2014, 08:27 PM   #2276
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
tempted by this
http://www.ebay.com/itm/SUBARU-IMPRE...20fb05&vxp=mtr
Old 03-30-2014, 09:04 PM   #2277
djdnz
1337
If you have your heart set on them, then you will need adapters. They are not hard to find. They will add about 15mm to the thickness (depends on the adapter) which is a good thing because those rims at that offset would not fit (at least on springs) without a spacer.
Old 03-30-2014, 09:07 PM   #2278
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
15mm will set the wheels close to stock height ?
thanks
Old 03-30-2014, 09:27 PM   #2279
djdnz
1337
thanks
Stock height? The wheels be closer to flush than stock. Are you planning on lowering?
Stock wheel is shown in orange, the one you are proposing with 15mm adapters would look like the green. They should be pretty close to flush which is nice.
Old 03-30-2014, 10:18 PM   #2280
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
I'm not planning to lower the car, so there's less wheel gap with these 18's and spacers,
Old 03-30-2014, 10:39 PM   #2281
djdnz
1337
Wheel gap is not dictated by the offset, or the wheel. You can affect it by changing tire size, but that messes up your speedometer.
If you want to reduce wheel gap you have to lower it.
All I'm saying is that the wheel will be less sucked into the wheel well. You are still going to have the same wheel gap as stock.
Old 04-01-2014, 12:31 AM   #2282
phuthinhon
Drives: 13 BRZ
I'm planning on buying 18x8.5 +44 for the front and back wrapped in either 225/40/18 or 235/40/18. What do you think will fit best and will I rub on stock suspension? I don't plan on lowering the car yet but I might get springs in a year time maybe to lower it from 0.5 to 1inch max.
phuthinhon is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
