Old 03-28-2014, 07:54 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Need help installing my avo turbo kit
So I just finished purchasing the avo stage 1 kit. Any tips on what I should look out for when installing, what tools I'm going to need, what I should be careful with?
ANY VIDEOS on how to install it?
Astroboy is offline   Reply With Quote
Old 03-28-2014, 09:57 PM   #2
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Go here, and read. And then....read some more. Lots of useful info.
http://www.ft86club.com/forums/showthread.php?t=42482
gdrider77 is offline   Reply With Quote
The Following 3 Users Say Thank You to gdrider77 For This Useful Post:
Draco_PR23 (04-01-2014), SkAsphalt (04-04-2014), Sportsguy83 (03-31-2014)
Old 03-28-2014, 11:28 PM   #3
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Like @gdrider77 said, follow that link and read up. On page 21, I made a list of little things that came up during my install.
Truth be told, the install isn't all that hard. Personally, I found the hardest part to be the oil pump install. It's in an awkward spot, so take your time or you'll get sealant everywhere.
-Jack Stands
-Basic socket set
-Basic hand tools
-Toyota FIPG Sealer (for the oil pump install)
-A bit of extra oil
-Subaru Super Blue coolant
-Drill with a stepped drill bit (to widen the holes on the crash beam and washer bottle mount)
-Rivnut tool or the knowledge on how to set a rivnut with a bolt/nut/wrench (youtube it)
It also helped to know what your'e getting into. I read this a few times before I started:
http://www.evasivemotorsports.com/me...it_install.pdf
**for the actual install, use the instructions that come with your kit. These may be out dated.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 03-29-2014, 06:10 PM   #4
onzippy
Drives: 2014 FRS
I just finished installing mine and doing some final adjustments last weekend. Went really well I think.
I've got a lot of hand tool around but the thing I had to run out and buy was a set of crowfoot wrenches for the oil fittings. Just couldn't get in there with a regular wrench or socket without taking a bunch more stuff off. Good luck and have fun. It's worth it. And use a lot of ziplock bags to separate all the little scews and pop-its when taking the front end apart.. There's sooooo many.
onzippy is offline   Reply With Quote
The Following User Says Thank You to onzippy For This Useful Post:
Astroboy (03-29-2014)
Old 03-31-2014, 01:39 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would check the flatness of the manifold flanges first and make sure you only use the AVO approved gaskets.
The Following 5 Users Say Thank You to King Tut For This Useful Post:
Astroboy (04-02-2014), Draco_PR23 (04-01-2014), Nasty Sausage (03-31-2014), onzippy (03-31-2014), Sportsguy83 (03-31-2014)
Old 03-31-2014, 07:18 PM   #6
onzippy
Drives: 2014 FRS
King Tut has great advice. I didn't check the flatness of the manifold before I installed it but the kit I got beginning of March came with new manifold gaskets so that was great.
You might also want to leave the under cover off for a few days after install just to make it easy to check everything is still in the right place and that manifold bolts are still tight. They will settle in after a few heat cycles.
The Following 2 Users Say Thank You to onzippy For This Useful Post:
Nasty Sausage (03-31-2014), SkAsphalt (04-04-2014)
Old 04-01-2014, 04:01 PM   #7
qtwre
Drives: White FR-S
I'm sort of disappointed that AVO hasn't sent out the gaskets to those of us who have an earlier kit. Is that unreasonable?
qtwre is offline   Reply With Quote
Old 04-01-2014, 04:07 PM   #8
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Probably the biggest thing people don't do.
Ask for a checklist of parts, go through the checklist line by line, make sure you go through all the parts and that they are the correct parts. Please do this well beforehand, prior to tearing down the car to install it.
I've been shipped incorrect parts before, and a friend of mine didn't have some of the gaskets/vbands.
Ironsquid is offline   Reply With Quote
The Following 3 Users Say Thank You to Ironsquid For This Useful Post:
Astroboy (04-01-2014), SkAsphalt (04-04-2014), STV3 (04-04-2014)
Old 04-01-2014, 06:27 PM   #9
Astroboy
Astroboy's Avatar
Drives: None
Will I have to do some data logging beforehand? Or can I just install it than tune it later
Sent from my LG-D800 using Tapatalk
Old 04-01-2014, 11:02 PM   #10
gdrider77
gdrider77's Avatar
You can simply install and tune after. Wouldn't hurt to datalog some baseline stuff, but not necessary.
The Following User Says Thank You to gdrider77 For This Useful Post:
Old 04-03-2014, 05:48 PM   #11
Astroboy
Astroboy's Avatar
Drives: None
Size:  46.2 KBName:  uploadfromtaptalk1396561663748.jpg
Size:  48.7 KBName:  uploadfromtaptalk1396561687408.jpg
Old 04-03-2014, 05:55 PM   #12
protpibe
protpibe's Avatar
Nice!
The one T-Bolt clamp I haven't replaced yet is the one on the Turbo inlet (PIC 2). Can you do me a giant favor and measure the diameter? The only thing I can offer is a "thanks" on your post lol
Old 04-03-2014, 05:59 PM   #13
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by protpibe View Post
Nice!
Yea I'll get the measurements, give me some time ok
The Following User Says Thank You to Astroboy For This Useful Post:
protpibe (04-03-2014)
Old 04-03-2014, 06:19 PM   #14
protpibe
protpibe's Avatar
Thanks man, you're a beauty!
This is the measurement I need
Just confirming we're talking about the same thing!
Thanks again
The Following User Says Thank You to protpibe For This Useful Post:
Astroboy (04-03-2014)
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 10:58 PM
Installing a hood for the fr-s? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-16-2013 11:06 AM
installing harness andrew5826 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-25-2013 10:41 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
tips for installing amp and sub brichard0625 Electronics | Audio | NAV | Infotainment 4 05-19-2013 07:25 AM
