Old 03-29-2014, 11:24 AM   #43
Lonewolf
Lonewolf's Avatar
Drives: Moped
Jeeze, are these goodies ever coming out?!
Old 03-29-2014, 01:24 PM   #44
zooki
Drives: waiting on a 2021...
Originally Posted by mid_life_crisis View Post
Nah, you would have four throttle bodies (duh), each with its own MAF and install individual exhaust probes per cylinder. A carefully designed and adjusted manual linkage would cause all four throttle bodies to open the same amount, actuated by the throttle by wire system. There would be a secondary ECU. The secondary ECU would monitor the four intake and exhaust sensor pairs as well as the throttle position and control the injectors.
This would allow the ultimate in mix control: optimized per cylinder. It could also constantly compare the four MAF values and send up a flare if the values got too far apart for some reason (probably mechanical failure in the linkage).
Yea, but then you would have to have 4 CAI's and 4 air filters stuck in front of the radiator...'cuz that's the only way to make a CAI make MOAR power....
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 03-29-2014, 01:33 PM   #45
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
No man, velocity stacks.
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-29-2014, 02:01 PM   #46
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
- AdrianG
Bro, do you even lift?
IAmNotTheDriftKing is offline   Reply With Quote
Old 03-29-2014, 04:44 PM   #47
350matt
Drives: toyota mr2/ Toyota GT86
what would we expect to see from Cosworth then?
more to the point what do we want?
350matt is offline   Reply With Quote
Old 03-29-2014, 05:25 PM   #48
Calum
That Guy
Drives: 2013 asphalt FRS MT
The impossible.
Old 03-29-2014, 05:32 PM   #49
NLS8520
Drives: N/A
Originally Posted by Maxim View Post
Is this going to be a race-only type package or would it be a kit with internals, etc that you could put in your street car?
I'd be horribly interested in upgrading the engine, staying NA, and putting out in the neighborhood of 250hp. Once the ECU is cracked and the bolt-ons are done, this seems like the next step....I fully intend to turn my FR-S/BRZ into the performance equivalent of a Cayman (not a Cayman S).
^ This.
NLS8520 is offline   Reply With Quote
Old 03-30-2014, 06:06 AM   #50
350matt
well without putting the revs up that not going to happen and increasing the rpm expensive as you need to embark on some analysis and destructive testing to establish whether the stock bottom end will go bang at 9,000 rpms
and having seen the guts of one of these I'd say the valve followers are going to need some work as its only the same design as the toyota V6 which spits its followers out at 8000 + rpm
consequently you end up charging several thousand to replace parts to get the revs up safely and pick up 30 bhp over the bolt on kits ?
so its not financially viable as who is going to spend 4-5K on a 30 bhp upgrade when you fit a superchgarger for the same amount and pick up 100-130 bhp with a wider power band and a better more usable engine ?
is anyone revving these lumps high on a day to day basis or during a race series?
as I haven't heard of people doing 8500rpm except for the odd nutter on a very occasional basis / missed gear scenario
Old 05-23-2014, 02:14 AM   #51
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
delet
clayrush is offline   Reply With Quote
Old 05-23-2014, 03:21 AM   #52
Fastbrew
Drives: 2014 Pearl White BRZ
Nameless is supposed to be involved in part of this.
Fastbrew is offline   Reply With Quote
Old 05-26-2015, 08:25 AM   #53
GT86_PRAGUE
Drives: GT86
Originally Posted by DanPO View Post
Just thought I would send an email to Cosworth to see if they are doing anything on the BRZ/FRS motor. They replied with:
"Yes, we will have a product offering for this motor in both NA (Natural Aspiration) and FI (Forced Induction) trim."
Not sure if this is new news to anyone but we all need something from this company to lower compression and have forged pistons/rods for Turbo/SC.
COOL.
Any news on this?
GT86_PRAGUE is offline   Reply With Quote
Old 05-26-2015, 08:30 AM   #54
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Originally Posted by GT86_PRAGUE View Post
Any news on this?
That post is from 3 years ago... have you not seen the Cosworth SC or the header/exhaust combo? That's what they meant in their message to the OP.
2016 Camaro SS is offline   Reply With Quote
Old 05-26-2015, 08:46 AM   #55
GT86_PRAGUE
Drives: GT86
I have seen stage 2, but I was asking about stage 3.
I know it was somehow announced, but nobody knows where it will be ready. Thats what interest me.
Old 05-26-2015, 09:34 AM   #56
2016 Camaro SS
Drives: Fast
Haven't seen anything on stage 3 or if there are plans for it. The biggest hurdle they will have for a stage 3 with internals is the oil pressure.
GT86 Confirmed Pricing Jayvelliott Scion FR-S / Toyota 86 GT86 General Forum 42 01-31-2012 05:21 AM
Confirmed NZ spec will called '86' bricktop AUSTRALIA 2 01-31-2012 12:41 AM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
