Old 03-27-2014, 02:54 PM   #1
FullBlown
FullBlown's Avatar
Drives: Scion FRS
FBM Stage 1 and Stage 2 Head packages
Here is the finished product of our Stage 1 and stage 2 FA20 Cylinder head packages
Our Stage 1 is designed for street and strip use with the same port treatment as our stage 2.
Our Stage 2 is designed for competition/race use but is still street friendly. It includes nothing but the best materials available to withstand high amounts of boost and anti-lag. This is the same package used in our shop car.
-----FBM Stage 1 Fa20 Head package ----
- FBM Competition port and Polish intake and exhaust ports
- Competition Valve Job
- Resurfaced and Clean and assembly
- Ferrea 6000 series Valves
- Ferrea Single Valve Springs
- Ferrea Tool Steel Retainers
- Ferrea Seat locators and new valve stem seals
Stage 1 Retail = $2495 plus core
-----FBM Stage 2 Fa20 Head package ----
- Ferrea Comp Plus Valves
- Ferrea Dual Valve Springs
- Ferrea Titanium Retainers
Stage 2 Retail = $2995 plus core
Stock Exhaust Flow @ .500 lift = 170
FBM Stage 1 & 2 Exhaust Flow @ .500 = 220
Stock Intake Flow @ .500 lift = 280
FBM Stage 1 & 2 Intake Flow @ .500 = 305
FullBlown is offline   Reply With Quote
The Following 24 Users Say Thank You to FullBlown For This Useful Post:
AZFA20 (03-27-2014), Brody602 (03-28-2014), Calum (03-27-2014), Creole (03-27-2014), crook (03-27-2014), Dimman (03-27-2014), Dipstik-sportech (03-27-2014), diss7 (03-28-2014), ftc~brz (03-28-2014), JonAvalon (03-27-2014), King Tut (03-28-2014), Lawnik (03-27-2014), mack4477 (03-29-2014), midnight23 (03-28-2014), NickFRS (03-27-2014), Nomed Alucard (03-27-2014), OjiGeorge (03-27-2014), shiro (09-25-2014), SkAsphalt (03-28-2014), Sportsguy83 (03-27-2014), The Racers Line (03-27-2014), Turdinator (03-27-2014), woode (03-27-2014), Zach3794 (03-27-2014)
Old 03-27-2014, 02:57 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Dammnit..... ridiculous as usual... great work!
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
FullBlown (03-27-2014), hunter3232792 (03-27-2014)
Old 03-27-2014, 04:02 PM   #3
crook
crook's Avatar
Drives: storm black GT
Is there going to be cams on the horizon or does stock seem to be more than enough? Also are you guys going to do a complete long motor for us Aussie guys to just import?
crook is offline   Reply With Quote
Old 03-27-2014, 04:17 PM   #4
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
+1 on cams..
any discounts if ordered with your guys' short block as well?
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 03-27-2014, 04:18 PM   #5
sw20kosh
Drives: 2013 Black FR-S
I don't suppose dyno charts would follow? Stock vs. New Heads?
The Following User Says Thank You to sw20kosh For This Useful Post:
woode (03-27-2014)
Old 03-27-2014, 04:18 PM   #6
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Mild regrinds are in the works and a complete short block is available
The Following User Says Thank You to FullBlown For This Useful Post:
crook (03-27-2014)
Old 03-27-2014, 05:27 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
paging Dr. @Dimman ^^
oh, and @arghx7 might be interested in those numbers as well.
How would these packages do with a high RPM NA setup?
How well do the ported ports lineup with the OEM intake manifold? Will the FBM intake manifold be required to avoid reversion?
The Following User Says Thank You to Calum For This Useful Post:
Dimman (03-27-2014)
Old 03-27-2014, 05:38 PM   #8
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We might have a car here that we will be testing for NA pretty soon. I don't think the FBM IM will be required but we will test all sorts of combinations when they are done.
Calum (03-27-2014)
Old 03-27-2014, 05:39 PM   #9
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
Not a bad price to get the block and head built by Full Blown! this is awesome ; cams and the intake manifold will complete this!
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
The Following User Says Thank You to Black86 For This Useful Post:
Old 03-27-2014, 05:46 PM   #10
Calum
That Guy
Oh yeah, is that the price per head, or per engine? I'm assuming it's for two heads, but one never knows.
Old 03-27-2014, 05:47 PM   #11
FullBlown
FullBlown's Avatar
Drives: Scion FRS
It is for a pair of heads
The Following 4 Users Say Thank You to FullBlown For This Useful Post:
Calum (03-27-2014), Nomed Alucard (03-27-2014), Sportsguy83 (03-27-2014), troek (09-25-2014)
Old 03-27-2014, 06:33 PM   #12
arghx7
Drives: car
Can we get some kind of baseline comparison with the stock heads, preferably overlaid with the stock lift profile? You're listing at .500 inches of lift and I don't even know if the stock cams have that much lift.
The Following 2 Users Say Thank You to arghx7 For This Useful Post:
Calum (03-27-2014), Dimman (03-27-2014)
Old 03-27-2014, 07:08 PM   #13
mike the snake
Is this like your shortblocks, where we send in our heads as cores, or is this price for the pair of heads outright?
Very tempting, for 6 grand I could have a total monnster!
Reground cams would require custom shimming, correct?
I need to get my car sorted out as it is first though.
Old 03-27-2014, 07:48 PM   #14
NickFRS
Drives: 2013 Asphalt FRS
Must have..... Shipping a full block sounds expensive though...
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
zooki (11-12-2014)
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 01:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
