Old 03-26-2014, 10:12 AM   #337
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
Yes. Test it with FI. I wanna see gains with a turbo.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
The Following User Says Thank You to Boss Paco For This Useful Post:
SkAsphalt (03-26-2014)
Old 03-26-2014, 10:14 AM   #338
Slowbaru
Slowbaru's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by wparsons View Post
Good review, just wish their dyno included the AFR as well.
Not to be a negative nelly, but 4whp is a far cry from the claimed 19hp. Yes the area under the curve increase is far more impressive than the peak hp gain suggests, but it leads me to suspect that the crawford dyno with the PB was a tuned run vs a totally stock car on the baseline.
I agree, but peak gain was 11.5 on a conservative dyno.
Slowbaru is offline   Reply With Quote
Old 03-26-2014, 10:32 AM   #339
TwinturboCamry
Drives: 4 wheels
Can I stack two sets of power blocks together and double the power?
TwinturboCamry is offline   Reply With Quote
The Following 12 Users Say Thank You to TwinturboCamry For This Useful Post:
Account Attempt No. 4 (04-14-2014), Cop (10-09-2014), dphan (04-15-2014), enjoi23 (04-20-2014), immaculate (03-26-2014), jeebus (03-26-2014), King Tut (03-26-2014), kodyo (03-26-2014), Kristjan (03-26-2014), Propaganda (03-26-2014), SmsAlSuwaidi (03-27-2014), Sportsguy83 (03-27-2014)
Old 03-26-2014, 10:45 AM   #340
TwinturboCamry
Drives: 4 wheels
pls respond
The Following 6 Users Say Thank You to TwinturboCamry For This Useful Post:
Account Attempt No. 4 (04-14-2014), enjoi23 (04-20-2014), kodyo (03-26-2014), Kristjan (03-26-2014), RavioliG (03-26-2014), Sportsguy83 (03-27-2014)
Old 03-26-2014, 11:04 AM   #341
xjohnx
Grip>Slip
xjohnx's Avatar
Someone pass the sawzall, lets see how they do with the innovate!
Old 03-26-2014, 11:05 AM   #342
nelsmar
i have attached the dyno from motoiq but with some markings.
I want you to look over both. Note that the cursor on the crawford dyno is at roughly 6,359 RPM. This is showing the power at that RPM not the peak RPM. The 4WHP gain was "4WHP @ peak" Not "4WHP Peak gain". There is a significant difference. If you look at the green lines i drew thew are exactly the same size (i copy and pasted). This line indicates roughly 9WHP @6,200RPM gain. This is a rough estimate of the peak gain, not gain at peak. If you do rough estimates the right green line is roughly 149WHP. The baseline however shows roughly 140WHP. 149/140 = 6.4% gain. Mind you I am estimating numbers. As I don't have the original plot to use to verify exact numbers. And in fact I am WRONG here is a quote from the article:
Torque was 126.2 lb/ft @6200 rpm, a gain of 8 lb/ft. The peak power gain was 11.5 hp @ 6200 rpm and peak torque gains were pretty much 8 lb/ft.
So if this is the case then lets calculate our HP @ 6200.
126.2/5252 * 6200 = 148.9HP.
148.9 - 11.5 = 137.4
What is our % gain?
148.9 / 137.4 = 8.36%.
Now lets repeat this using crawfords dyno in which we have the numbers written on the chart.
206.11HP at peak gain @ 6359RPM.
187.88 baseline @ 6359.
What is Crawfords % gain?
206.11/187.88 = 9.7% gain.
So sure crawford saw roughly a 1.32% higher gain than this user. But thats pretty damn close.
This is a great example of "reading" the text from a dyno's gain reports vs actually analyzing the report. If you want to actually view gains via text it is best to use AVG WHP/WTQ gains to do comparison and use them in % not WHP. It looks like crawford is trying to use a compensation to compare to a dynojet or something of the sorts which is why their dyno is reading so high. Again if you look at their chart you will see AXLEPOW VS POWER which is corrected vs uncorrected. This is why simply posting "my car has xxWHP/xxWTQ" is rubbish. Because maybe you have a linear tq curve, or a flat tq curve and the difference is quite big when actually driving the car.
So what am I saying?
Yes I do see the 19WHP gain. If you were to get the same % gain that crawford saw you would see 13.3WHP peak gain. This article posts an 11.5 gain. This is fairly close.
If this is sustained post tuning then this is an extremely good power / $$ ratio mod for NA cars.
My flickr - Canibeat
Local magazine scout
The Following 20 Users Say Thank You to nelsmar For This Useful Post:
akyp (03-26-2014), Andrew025 (03-26-2014), Bach415 (03-26-2014), Boofneenee (03-26-2014), calmtigers (09-13-2014), Captain Snooze (03-26-2014), chanomatik (04-16-2014), Cop (10-09-2014), CSG David (03-26-2014), DAEMANO (03-27-2014), dphan (04-15-2014), GT86_PRAGUE (12-22-2014), industrial (03-26-2014), makinen (03-27-2014), Namuna (03-26-2014), pcuerpo (09-14-2014), SkAsphalt (03-26-2014), StormMcCloud (03-26-2014), Turdinator (03-26-2014), Yobiwan (03-26-2014)
Old 03-26-2014, 11:09 AM   #343
nelsmar
pls respond
I know you are kidding... but... LOL possibly.
Originally Posted by sw20kosh View Post
This has been done a lot on rotary engines. You alter the shape of the torque curve by adjusting the length of the intake runners. They actually chop off sections of their intake runners to shorten them to extend the torque curve further to the right.
What crawford has done is altered the torque curve (notice the HP peak shift to the left and look at where torque starts to fall off up top) and if it truly is a stock ECU tune... the ECU/engine loves the heck out of this new intake runner length. You get a much sharper/drastic high rpm fall off of torque from this peak though (fall off of torque is now at ~6400 vs the stock ~6700 rpm.
The basic principle:
Has any OEM played with variable intake runner length technology?
Old 03-26-2014, 11:18 AM   #344
Boxer486
Drives: small
So how tall are the spacers exactly?
Boxer486 is offline   Reply With Quote
Old 03-26-2014, 11:35 AM   #345
nelsmar
35.8MM
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Boxer486 (03-26-2014), unsurety (05-09-2014)
Old 03-26-2014, 11:52 AM   #346
White64Goat
pls respond
three stacks................
Old 03-26-2014, 12:06 PM   #347
White64Goat
Originally Posted by Thorpedo View Post
I'm not digging that loss above 7k...
If max HP is now at 6300-6400 instead of 7000, how is that a negative? Seems like less wear and tear on the internals to me. I know you'd like to see the HP continue to go up, but if this mod lowers the rpm's with the same amount of peak HP, it seems like a benefit to me.
Old 03-26-2014, 01:05 PM   #348
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
Attachment 71968
What is our % gain?
Thanks dude, its good to see that you get it.
Crawford Performance is offline   Reply With Quote
The Following 4 Users Say Thank You to Crawford Performance For This Useful Post:
CSG David (03-26-2014), Grymm86 (03-26-2014), nelsmar (03-26-2014), Turdinator (03-26-2014)
Old 03-26-2014, 01:09 PM   #349
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Very curious to see fi results
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following 2 Users Say Thank You to kiichiro For This Useful Post:
Boss Paco (03-26-2014), captainzib (03-26-2014)
Old 03-26-2014, 01:35 PM   #350
wparsons
wparsons's Avatar
I'm not going to argue with you on most of that, because you are right. I was reading the posted chart wrong, I just scanned quickly and assumed the power numbers shown in the right sidebar were the peak numbers, not the numbers at ~6400rpm.
Before: 187.88
After: 206.11
That's a delta of 18.23hp and is the number I was talking about compared to the 4whp motoiq got. Blame it on tired eyes not reading the graph right
flickr
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
