Old 03-25-2014, 07:17 PM   #855
phrosty
@shiv, any idea why OFT wouldn't turn up any fault codes? Perhaps I'm misinterpreting this function.
phrosty is offline   Reply With Quote
Old 03-25-2014, 07:35 PM   #856
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I'm guessing that the check engine light isn't powertrain related (the OFT only reads powertrain codes at this time). That CEL may be transmission control related. It's not unusual to get a code after a flash if you have a 6AT. It's triggers during the flash process. It will go away by itself after a few drive cycles.
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 03-25-2014, 07:52 PM   #857
phrosty
Shiv
Yea, it's transmission related -- P0700. I haven't flashed anything yet, but I have read my ECU. Would that cause it?
Old 03-25-2014, 08:01 PM   #858
Shiv@Openflash
Drives: 2013 FRS
It's possible that the reading process may have trigged that code since the ECU goes into a diagnostic mode during the read process when it may lose communication with the TCU. We don't have a 6AT ourselves nor have we flashed more than a few ourselves. Perhaps some more 6AT OFT users can chime in?
Either way, nothing to worry about. It should go away by itself.
Shiv
Old 03-25-2014, 10:18 PM   #859
Captain Insano
I had a p0700 too on first flash. I have never had a cel on my 6AT until that first flash.... it was actually before the first flash as i checked my code functionality immediately prior to flashing. I cleared the p0700, flashed stg1, and no codes for anything since. I have been logging since with OFT and no CELs or problems and logs are good.
I searched around and it did look like a trans related code, but I could never find exactly what it means. So far I have assumed it is a harmless code. It has never come back.
Captain Insano is offline   Reply With Quote
The Following 2 Users Say Thank You to Captain Insano For This Useful Post:
phrosty (03-26-2014), Shiv@Openflash (03-25-2014)
Old 03-26-2014, 12:23 AM   #860
phrosty
My original ROM is a ZA1J700D -- is OFT able to update me to the more recent versions?
Old 03-26-2014, 01:17 AM   #861
frsqc
Drives: raven FRS
every tune you upload will have the A01C ROM integrated in it. Just pick the file with your rom such as stage 1 700D, and the a01c rom will be implemented.
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
The Following 2 Users Say Thank You to frsqc For This Useful Post:
Migero86 (03-26-2014), phrosty (03-30-2014)
Old 03-26-2014, 12:34 PM   #862
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Quick question. I know you guys have a map developed for your own UEL header.
What about the Nameless EL header? Or an EL header in general? Just curious as to if I would be able to use the OFT for a good tune to pair with the Nameless header and 2.5" exhaust.
Thanks in advance.
Old 03-26-2014, 12:53 PM   #863
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
There are OTS tunes for EL headers in the archive on their website. You would want to use the Stage 2 EL bin
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
TylerLieberman (03-27-2014)
Old 03-27-2014, 12:16 AM   #864
TylerLieberman
Drives: '24 GR86
- AdrianG
Thanks. Just curious if anybody has actually used the two together and what kind of results they've gotten.
Old 03-30-2014, 11:15 PM   #865
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
I have an Automatic and running a stock engine with no current plans to modify. Will I still benefit from OFT?
-Z
zinzan is offline   Reply With Quote
Old 03-30-2014, 11:19 PM   #866
Captain Insano
Yes. Reference stg1 91-93 oct map dyno results. Also stg2 EL header E85 tune can be used on a bone stock car running E85.
Also the car will run more smooth. Also if you have an early built vehicle the retune will correct a 5200+ RPM on/off throttle knock bug in the OEM tune -that only applies to early built MY13s.
Old 03-30-2014, 11:27 PM   #867
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
So I'm pretty sure I read this earlier but just want to be sure... I would run the e85 el tune on my FRS with a drop in filter and stock otherwise and be perfectly fine right?
jebuwh is offline   Reply With Quote
Old 03-30-2014, 11:29 PM   #868
Captain Insano
Yes... but you should always monitor with logging to be safe. Lots of people running with that setup without issues. His tune for E85 is supposed to be designed for E60+.
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
