#856 | |
Drives: 2013 FRS
Shiv |
#857 | |
#858 | |
Drives: 2013 FRS
Either way, nothing to worry about. It should go away by itself. Shiv |
#859 |
I had a p0700 too on first flash. I have never had a cel on my 6AT until that first flash.... it was actually before the first flash as i checked my code functionality immediately prior to flashing. I cleared the p0700, flashed stg1, and no codes for anything since. I have been logging since with OFT and no CELs or problems and logs are good.
I searched around and it did look like a trans related code, but I could never find exactly what it means. So far I have assumed it is a harmless code. It has never come back. |
| The Following 2 Users Say Thank You to Captain Insano For This Useful Post: | phrosty (03-26-2014), Shiv@Openflash (03-25-2014) |
#860 |
My original ROM is a ZA1J700D -- is OFT able to update me to the more recent versions?
#861 | |
Drives: raven FRS
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
#862 |
Drives: '24 GR86
Quick question. I know you guys have a map developed for your own UEL header.
What about the Nameless EL header? Or an EL header in general? Just curious as to if I would be able to use the OFT for a good tune to pair with the Nameless header and 2.5" exhaust. Thanks in advance.
#863 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
There are OTS tunes for EL headers in the archive on their website. You would want to use the Stage 2 EL bin
- AdrianG |
| The Following User Says Thank You to AdrianG For This Useful Post: | TylerLieberman (03-27-2014) |
#864 | |
Drives: '24 GR86
Thanks. Just curious if anybody has actually used the two together and what kind of results they've gotten.
#865 |
Drives: Subaru BRZ 2014 Limited WRB
I have an Automatic and running a stock engine with no current plans to modify. Will I still benefit from OFT?
-Z |
#866 |
Yes. Reference stg1 91-93 oct map dyno results. Also stg2 EL header E85 tune can be used on a bone stock car running E85.
Also the car will run more smooth. Also if you have an early built vehicle the retune will correct a 5200+ RPM on/off throttle knock bug in the OEM tune -that only applies to early built MY13s. |
#867 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
So I'm pretty sure I read this earlier but just want to be sure... I would run the e85 el tune on my FRS with a drop in filter and stock otherwise and be perfectly fine right?
#868 |
Yes... but you should always monitor with logging to be safe. Lots of people running with that setup without issues. His tune for E85 is supposed to be designed for E60+.
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
