Old 03-25-2014, 01:33 AM   #295
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
Those are some really bizarre looking changes in the powerband. You now a higher peak torque before the dip, and gain quite a bit more torque after the dip. Gains in low end torque do make sense for longer intake runners. The parts resemble tumble delete valves to me. The idea might have come from that, even though we dont have tumble valves.
I'm curious to see how much this powerband will change with tuning. I'd imagine there are a lot of games to be played with the cam phasing.
P@ul is offline   Reply With Quote
Old 03-25-2014, 01:53 AM   #296
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
subscribed. next paycheck...
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 03-25-2014, 02:21 AM   #297
nelsmar
Originally Posted by Turdinator View Post
Thank you for the photos. I like how you can't really see them.
I wonder if the grimmspeed strut bar would still fit. Do you know how tall the blocks are?
I had measured yesterday but I forget... iirc ~37mm.
My flickr - Canibeat
Local magazine scout
Old 03-25-2014, 03:03 AM   #298
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Holy Dejavu! I was just describing these to a friend as a tvg delete knock off.
@nelsmar will these be tested with a header as well? or just stock/tune vs block/tune?
Really, 4 dynos would be the best when you get to it, but I don't want to push you.
Stock, Stock + tune, stock + blocks, Stock + blocks +tune. It will give an idea of how successful the part is vs how much of it is leaning afr out.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 03-25-2014, 03:10 AM   #299
Vic
63 Auto Body
Vic's Avatar
Drives: 2013 SCION FR-S WHITEOUT
going to take my chances with this one too, I have a grimmspeed strut bar and from that picture it looks like the bar might be in the way. im scareddd
Vic is offline   Reply With Quote
Old 03-25-2014, 05:43 AM   #300
nelsmar
I will be doing:
1. Stock
2. Stock + K&N Filter
3. Stock + K&N Filter + Tune
4. Blocks + K&N Filter
5. Blocks + K&N Filter + Tune
6. Blocks + K&N Filter + JDL UEL Header (1-2 weeks after the first testing)
7. Blocks + K&N Filter + Tune + JDL UEL header (1-2 weeks after the first testing).
8. Blocks + K&N Filter + Tune + JDL UEL Header + E85 (2-4 weeks after testing).
"Untuned" Will be a rom i modified to disable fuel trims (so learning doesn't swing things), cam profiles locked to "low detonation" and IAM set to 1.0. That way it gets the highest baseline possible.
Is that detailed enough for ya?
I want to find out precisely what it takes to get to 200WHP on 91 with a balanced powerband. Both the JDL UEL & these blocks seems to peak at similar RPM's so I am curious how it will turn out vs completely stock.
The Following 12 Users Say Thank You to nelsmar For This Useful Post:
86-tundra (03-25-2014), acollite (03-25-2014), Bach415 (03-26-2014), Captain Snooze (03-25-2014), ck-GT86 (03-25-2014), FrsDuke (03-25-2014), mxsled (03-26-2014), pcuerpo (09-14-2014), Scottemad123 (03-25-2014), Simon99 (03-25-2014), Turdinator (03-25-2014), Yobiwan (03-25-2014)
Old 03-25-2014, 06:16 AM   #301
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I'm hoping that the JDL headers will extend the peak of the blocks. If that happens it would be so sweet as to render your blood sugar level off the scale. I just hope that they don't do some weird space time continuum thing and end up cancelling each other out. Btw, if you have time could you test an LS1 swap with and without blocks?
Originally Posted by nelsmar View Post
TouchMyHonda (03-25-2014)
Old 03-25-2014, 08:26 AM   #302
Turdinator
Señor Member
Turdinator's Avatar
Yeah I agree that if a header can flesh out the torque curve with a tune and the power blocks it will make for a killer bolt on setup.
@nelsmar you are quickly becoming a hero of mine
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 03-25-2014, 09:29 AM   #303
Wepeel
Drives: '13 BRZ Ltd
That's a bizarre dyno. 2-3k RPM looks really weird, maybe like there's some knock correction going on there, but even the stock curve - normally there's a nice broad hump from 2-3k RPM.
The spacers seem to actually make the torque dip worse, extending it maybe 3-400 RPM, then it comes on strong from 5300-6300, and then drops again. So far it seems like these are good only for improving power from 5300-6300. Stock is better 4000-5300, and 6300 to redline.
Wepeel is offline   Reply With Quote
Old 03-25-2014, 10:05 AM   #304
Luis_GT
What? I see a shortened dip on the dyno charts
Old 03-25-2014, 10:10 AM   #305
Wepeel
Drives: '13 BRZ Ltd
Oh derp me. The flash spot tricked my eyes. Looks like a nice improvement from 4000 - 6300.
Old 03-25-2014, 11:23 AM   #306
Hawaiian
That guy
Hawaiian's Avatar
I will be doing:
1. Stock
Ultramarine mt FR-S
P&L stage 1 turbo
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
Cop (10-09-2014), TouchMyHonda (03-25-2014)
Old 03-25-2014, 12:31 PM   #307
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
I will be doing:
1. Stock
based nelsmar
86-tundra is offline   Reply With Quote
Old 03-25-2014, 12:44 PM   #308
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Thorpedo View Post
I'm not digging that loss above 7k...
As others have stated, everything is a compromise.
I think without a tune, this is a decent mod for a street car. More usable power earlier... and you'd just short shift at 7K instead of redline.
Around 1.5" tall.
There's definitely a better low end, but what was telling was that my car was on the dyno for about 40 total miles to test. Several other things were tested, but over the course of 2 days there were more than 30+ pulls.
MotoIQ uses a SuperFlow dyno, which apparently reads a consistent ~10HP less than a comparable DynoJet. That said, my stock car put down around 148RWHP on their dyno, compared with around ~142-144 for most of the other FRS/BRZs they've tested.
-alex
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
