Old 03-24-2014, 08:12 PM   #1191
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
If anyone wants a ride along in a car with the kit installed with the gtx2867 I'm in the Vancouver area, but will be in Calgary a few times over the spring/summer.
OjiGeorge is offline   Reply With Quote
Old 03-24-2014, 09:40 PM   #1192
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Sounds good. The owner seems a little sketchy to me and doesn't have many posts, but I am somewhat interested in the kit.
Looks like my friend is fixin to purchase the kit tomorrow. Everything seems legit, phone calls and extensive photography. Only thing missing is the 550 injectors.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-24-2014, 09:52 PM   #1193
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Nice
Ask him to get ID 1000cc
I love boost!!!!!!
Old 03-25-2014, 07:58 AM   #1194
Dipstik-sportech
Dipstik-sportech's Avatar
I might know someone with some 550 injectors
The Frozen North
Old 03-29-2014, 04:23 AM   #1195
OjiGeorge
OjiGeorge's Avatar
Thank you Shift Autosport in Vancouver BC! Can't wait for Monday to pick her up. And thank you LJ at FullBlown for your incredible customer service in getting this kit installed and running properly!
Old 03-29-2014, 04:35 AM   #1196
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Did they do all the tuning as well? What fuel did you tune it to? I'll be curious on your final #s
glad you settled on a kit, and a good one to look forward to your impressions and thoughts as time goes on!!
Old 03-29-2014, 05:56 AM   #1197
OjiGeorge
OjiGeorge's Avatar
Numbers won't be super high yet as I'll be running the base map for a while until I install a new clutch and refill the bank account. Currently running the new FB SD tune (which looks to be quite conservative and slightly on the rich side to be safe) and am on a 6 PSI wastegate spring. Once I have a few more pennies will see if we can squeeze a few more ponies out of her. Shift was guessing I'll be getting around 250whp in current form. She will be on the dyno over the weekend to ensure everything is running smoothly. But from the test drive done by Shift they said it's feeling great, and even running smoother than even the VCMC car!
Old 03-29-2014, 10:08 AM   #1198
FullBlown
FullBlown's Avatar
Drives: Scion FRS
That is awesome bud, we spent quite a bit of time on the new SD tune. Send me some logs and we can dial it in.
FullBlown is offline   Reply With Quote
Old 03-29-2014, 12:20 PM   #1199
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Does anyone have their skidplate on with an open dump wastegate?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 03-29-2014, 12:30 PM   #1200
FullBlown
FullBlown's Avatar
Drives: Scion FRS
If you choose to run the skidplate, we suggest cutting a hole where the dump tube points at so its not deflecting off the skid plate.
Old 03-29-2014, 12:32 PM   #1201
Dipstik-sportech
Yeah I didn't do that and mine melted the plastic it's attached too
The Frozen North
Old 03-29-2014, 12:36 PM   #1202
Reaper
Reaper's Avatar
Drives: violent
Originally Posted by FullBlown View Post
If you choose to run the skidplate, we suggest cutting a hole where the dump tube points at so its not reflecting off the skid plate.
What size hole do you guys recommend?
Old 03-29-2014, 12:41 PM   #1203
FullBlown
FullBlown's Avatar
Drives: Scion FRS
we use a 2.5" hole saw
Old 03-29-2014, 01:02 PM   #1204
mike the snake
I used a 3" hole saw, it worked perfectly and cut through the aluminum easily.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
