MisterSheep
Old 03-24-2014, 08:19 PM   #43
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Originally Posted by Marusich View Post
Been doing some reading and it sounds like it's probably not that good. Curious though how the F-type goes about it safely.
There is no reason for it to hurt the exhaust valves. The unburnt fuel should be igniting in the hot exhaust well after the valves. Its not enough of a back pulse. Again its done in many OEM cars these days in the same manor with no issues long term.
Proof is offline   Reply With Quote
The Following User Says Thank You to Proof For This Useful Post:
invaliduser (03-24-2014)
Old 03-24-2014, 10:46 PM   #44
carlitosway6891
Drives: white out project fr-s
here we go.....this video was taken at night so its more of a sound clip than a video but you get the idea =) the first half of the first video is me warming up the car, the second half is me beating on it a little. i was trying to get as much popping as i could so normally it wouldn't pop that much
[ame]http://youtu.be/kKbCCrdqrCI[/ame]
and here is the in car video.
[ame]http://youtu.be/HmvqDhd2FBo[/ame]
carlitosway6891 is offline   Reply With Quote
The Following User Says Thank You to carlitosway6891 For This Useful Post:
Sargy (03-26-2014)
Old 03-26-2014, 01:49 PM   #45
Marusich
Marusich's Avatar
I wanted to try for something a little more subtle, but still present, so I went with 15 instead of -10 and adjusted the overrun also. Very pleased with the results.
Marusich is offline   Reply With Quote
Old 03-26-2014, 01:59 PM   #46
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
I made the adjustments last night and its still adapting. I can make my car sound like its making orville redenbachers in my trunk on command... lol
Migero86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Migero86 For This Useful Post:
carlitosway6891 (03-26-2014), mr. slim (03-26-2014)
Old 03-26-2014, 06:28 PM   #47
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
Can some one upload they're files?
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Old 03-27-2014, 01:44 PM   #48
shif7i7down
Erected Member
Drives: frs
The file it self is just the ots map with the added adjustment which takes roughly 1minute to implement. But if you must have it., PM me your email and the ots map that youre currently using, I can send you a moded version.
With that said, I however can not be held responsible for anything that could or may happen to you and or your vehicle by using any files that i send you
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
mr. slim (03-27-2014)
Old 03-27-2014, 02:34 PM   #49
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
i would do it myself, but i don't understand why romraider dont want to be installed on my pc!
Walla Walla is offline   Reply With Quote
Old 03-27-2014, 02:40 PM   #50
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
My romraider install file would not work until I updated my java. Just throwing that out there.
bee_are_zee is offline   Reply With Quote
The Following User Says Thank You to bee_are_zee For This Useful Post:
Walla Walla (03-27-2014)
Old 03-27-2014, 03:15 PM   #51
Sargy
Long Distance Driver
Sargy's Avatar
This sounds great. thanks for sharing!
Sargy is offline   Reply With Quote
The Following User Says Thank You to Sargy For This Useful Post:
carlitosway6891 (03-30-2014)
Old 03-27-2014, 03:44 PM   #52
Migero86
Migero86's Avatar
As he sets yours rev limiter to 3000 rpm Just kidding...
The Following 3 Users Say Thank You to Migero86 For This Useful Post:
carlitosway6891 (03-27-2014), gonzo (03-27-2014), mr. slim (03-27-2014)
Old 03-27-2014, 03:49 PM   #53
carlitosway6891
i had the same issue too till i updated JAVA
The Following 2 Users Say Thank You to carlitosway6891 For This Useful Post:
mr. slim (03-27-2014), Walla Walla (03-27-2014)
Old 03-27-2014, 03:56 PM   #54
gonzo
Drives: frs
Fuck ya! Because racecar
gonzo is offline   Reply With Quote
Old 03-27-2014, 06:34 PM   #55
gonzo
Drives: frs
What did you put the overrun RPM delta at? did you change any other overrun parameters?
Old 03-27-2014, 06:37 PM   #56
gonzo
Drives: frs
Originally Posted by andrew5826 View Post
after messing with the ignition maps, i started looking into fueling. with the overrun enrich rpm delta activation set to 6000, the pops were alot more aggressive and rally sounding, as opposed to before where it sounded like you were running over a bunch of pop cans.
Have you tried setting the overrun enrich rpm delta activation lower to say, 4k? That should allow for the popping at a lower rpm rev, right?
Also, is there a parameter to change how long the overrun condition lasts? That way we can set it to pop fewer times each rev.
Finally, can you change how much fuel is injected during the overrun condition? Might be able to get those flames if you set this higher and delete the cats
The Following User Says Thank You to gonzo For This Useful Post:
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
