Old 11-15-2012, 02:22 AM   #29
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I'm glad I stumbled onto this thread. Tonight I picked up a pair of 14mm Eibach eccentric bolts from a friend for cheap. This gives me the option to use crash bolts up top if I really want later on. But I'm happy to hear that toe change is so minimal when adjusting camber as much as you guys are.
Could someone clarify for me that since I'm installing in the lower hole (instructions are for upper...but different car), I will orient the tab opposite the instructions? i.e. tab out for negative camber. I'm sure it'll make more sense when I get in there, just like to know ahead of time.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-15-2012, 07:13 AM   #30
celica73
Tab in the opposite direction. It took me a while to convince myself. I also found that the small inner tab was bent to the outside just enough that I couldn't get it all together - it wouldn't fit in the strut hole. I bent the inner tab towards the inside just a hair and it went together right away.
The Following User Says Thank You to celica73 For This Useful Post:
2point0 (11-15-2012)
Old 05-26-2013, 12:50 PM   #31
Xdragonxb0i
Drives: ex500r
Can anyone give me the part number for oem crashbolt? This is only for the front right?
I'm not sure if I will need them. Since I got the full ground control kit with camber plates and etc.
Xdragonxb0i is offline   Reply With Quote
Old 05-26-2013, 01:09 PM   #32
2point0
2point0's Avatar
Not sure of the number, but the "crash bolt" is the lower 14mm strut bolt placed in the upper 16mm hole. With camber plates, the little gain you get from the bolt is likely to be useless.
Old 11-30-2013, 05:49 PM   #33
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
do the crash bolts come stock with the BRZ? If so are they pre-installed or would they come in a plastic package along with the car?
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline   Reply With Quote
Old 11-30-2013, 07:47 PM   #34
celica73
Not included.
ShoGun (12-01-2013)
Old 03-14-2014, 02:44 PM   #35
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Just to make sure, are these the correct bolts needed to add camber?
And yeah, it's an old thread and stuff.
Thrustin is offline   Reply With Quote
Old 03-14-2014, 03:15 PM   #36
2point0
2point0's Avatar
Looks right, but I don't know the actual part number offhand. I'm sure there's a thread on here with the service manual page.
But the diameter is right. Use that 14mm bolt in the upper 16mm hole and now there's wiggle room to adjust.
If you're doing this for stock autocross classing, right on. If not, take those back and just get a set of actual camber bolts (eccentric bolts). They will provide more range to adjust and be easier for a shop to set to a certain spec. I put mine in the lower hole so that I'd be pushing inwards slightly less and not worry as much about hitting the spring perch. Of course, now I'm on spacers so it's a moot point.
The Following User Says Thank You to 2point0 For This Useful Post:
Caspeed (04-17-2015)
Old 03-14-2014, 03:29 PM   #37
Thrustin
It's for C Street.
The Following User Says Thank You to Thrustin For This Useful Post:
2point0 (03-14-2014)
Old 03-24-2014, 05:04 PM   #38
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
I've never changed alignment specs with a car before.
After installing these bolts, what do you tell the service shop when you bring the car in for alignment? Run as much negative camber as you can get out of the front and align the rear to OEM specs? Anything else?
Apex_BRZ is offline   Reply With Quote
Old 03-24-2014, 05:12 PM   #39
was385
Drives: MT WRB BRZ Limited, 2007 911s
I had them max out the camber bolts, run a bit of toe out in the front and a bit of toe out in the rear (1/8" total for each). That last part is personal preference, however I'd definitely recommend maxing out the camber bolts because it's still pretty mild.
was385 is offline   Reply With Quote
Old 03-24-2014, 05:45 PM   #40
Apex_BRZ
What kind of increased wear have you seen with the Toe Out adjustments?
I read this on Tire Rack:
A toe setting that is just a little off its appropriate setting can make a huge difference in their wear. Consider that if the toe setting is just 1/16-inch off of its appropriate setting, each tire on that axle will scrub almost seven feet sideways every mile! Extend it out and you'll discover that rather than running parallel to each other, the front tires will scrub over 1/4-mile sideways during every 100 miles of driving! Incorrect toe will rob you of tire life.
While I'd like to add Toe Out while I'm there, I'm concerned about tire wear as well.
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
RTR Wheel Alignment simpleisbest Tracking / Autocross / HPDE / Drifting 61 11-07-2012 07:48 PM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 03:58 PM
