Old 08-18-2012, 11:07 PM   #1
jdub512
jdub512's Avatar
Drives: Whiteout SCION FR-S
Rubber plugs for side sills
So after I drove my new FR-S home a few days ago, I noticed a package in the glove compartment. It says "To Pre-Delivery Inspector," Insert these rubber plugs into the holes of the side sills. I just thought they were extra pieces not used but curiosity got the best of me so I googled "rubber plug side sill" and found this link (BRZ forum):
http://www.**************.com/9-suba...ill-plugs.html
The dealer didn't install them during the PDI. If you look under your car just in front of the rear wheels (under the door area) you will see where these plugs go (see pic below). The BRZ forum describes what they are used for but you have to register on the site to see the pics. I took these photos myself. In any case, if you do find these plugs in your car still in the package...you now know where they go!
Be careful and wear gloves as there is a lot of grease and lubrication around the hole.
From the BRZ forum: (These plugs are simply a body fill plug. They are part of a standard PDI process to install before delivery. It is always a toss up to where they get installed or not. All they do is plug the frame rail holes. Some of us dont install them because if water gets in the frame rail it wil lhave no where to exit promoting rust and corrosion. Its more of a catch 22. If the plugs are there water shouldnt be able to get in. Its all personal preference to whether or not you want them in. I do know the holes are there for transport purposes for when they are tied town to the boats for shipping and for the transport trucks to deliver them. Thats why the plugs are not installed until they arrive at the dealer. )
jdub512 is offline   Reply With Quote
The Following User Says Thank You to jdub512 For This Useful Post:
Bonburner (08-18-2012)
Old 08-18-2012, 11:11 PM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I can't find the previous thread with this but thanks for bringing this back to light!
surprisingly my PDI dept guys at power cerritos scion did this already ~
Old 08-18-2012, 11:26 PM   #3
n2oinferno
Praise Helix!
n2oinferno's Avatar
Different car, but same story.
My wife and I bought a used 2007 Camry in 2010. Guess what I found just a few days ago in the glove box, underneath the original window sticker?
The Following User Says Thank You to n2oinferno For This Useful Post:
racecat (03-23-2014)
Old 08-18-2012, 11:42 PM   #4
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
oh man, i heard these things increase horespower!!!
jk
mikeg7827 is offline   Reply With Quote
Old 08-18-2012, 11:50 PM   #5
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
here is the thread
http://www.ft86club.com/forums/showthread.php?t=11523
|-Goku-| is offline   Reply With Quote
Old 08-21-2012, 07:29 PM   #6
Turbowned
Turbowned's Avatar
Yep, did these for a customer's BRZ because the PDI inspector overlooked them.
Old 03-23-2014, 04:12 PM   #7
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
I assume if the plugs aren't in the glove box then there is a good chance that they are already installed ?
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 03-23-2014, 06:32 PM   #8
fistpoint
Drives: Supercharged Golf Cart
Lean under your car and look. It doesn't take special tools to bend over...they are clearly visible by just looking.
If they aren't there, go back to your dealer or any Toyota/Subaru dealer and ask for them.
fistpoint is offline   Reply With Quote
Old 03-23-2014, 06:34 PM   #9
Young_makaveli
Drives: 2013 frs
I looked and I also felt the rubber on the passenger side .. I'll have to check the driver side later
Old 03-24-2014, 04:47 AM   #10
Young_makaveli
Drives: 2013 frs
Is this it.?Name:  uploadfromtaptalk1395647243364.jpg
Old 03-24-2014, 04:59 AM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Yeah, that's it. My dealer, Toyota One of Oakland, managed to get one right and one wrong. It also took four visits to the dealer to get the USB port working. Such is life.
Old 03-24-2014, 05:18 AM   #12
Young_makaveli
Drives: 2013 frs
What do you mean one right and one wrong?
Old 03-24-2014, 07:04 AM   #13
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Mine were missing completely and there were none in the glove box. Ended up buying a pair and installing myself. Part number is SU003-02911. IIRC they were a couple of dollars each but the dealer didn't charge me when I told them they were supposed to be part of the pre-delivery prep.
Not my dealer's fault, car was sourced from a different dealer who failed to install them. Everything else was done fine so no complaints.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 03-24-2014, 12:29 PM   #14
EAGLE5
Dismember
EAGLE5's Avatar
One in the correct hole. One in the wrong hole, jammed in.
Kind of like a movie I once saw...
The Following User Says Thank You to EAGLE5 For This Useful Post:
kodyo (03-24-2014)
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 128 02-27-2019 08:25 PM
Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) Moto-P BRZ Photos, Videos, Wallpapers, Gallery Forum 109 08-19-2014 11:56 PM
What do you think about these door sills? yospeed Cosmetic Modification (Interior/Exterior/Lighting) 66 09-28-2012 06:30 PM
Custom Door Sills danthedirt Cosmetic Modification (Interior/Exterior/Lighting) 13 07-23-2012 08:54 PM
Little request: FR-S vs GT86 vs BRZ side by side photos! EJ20 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 12-02-2011 01:53 AM
